Ventuz 6 Quick Guide
  • Ventuz 5 Migration Guide
Ventuz 6 Designer
Ventuz 6 Node Reference
Ventuz 6 Configuration Editor
Ventuz 6 Director
  1. Single Statement
  2. Multiple Statements
  3. Examples
  4. Available Name Spaces
Expressions
Double Expression Provides the possibility to write logical C# expressions with a Double as resulting output value.
Boolean Expression Provides the possibility to write logical C# expressions with a Boolean as resulting output value. Additional it provides True and False Event outputs.
Single Statement
   return EXPRESSION;
Multiple Statements
   STATEMENTS
   return RESULT;
Examples
(A == 6) ? 1:0 Return 1 if A is equal to 1.6, otherwise return 0.
(A != B) ? 1:0 Return 1 if A is not equal to B, otherwise return 0.
(A >= 0) ? 0 : A Return 0 if A is greater than or equal to 0, otherwise return A.
   int b = 0;
   for(int i = 1; i <= A; i++)
	b = b + i;
   return b;
Results in the sum of all numbers from 0 to A.
   int b = 1;
   if(A<=1) return 1;
	b = b * i;
   return b;
Results in A! (the faculty of A). Note that there are two return statements - one of which will only be reached if A is 1 or less.
	int result = 0;
        result += A[i];
   return result;
Returns the sum of all elements in the numeric array A. Only succeeds if the input is an array type.
   var dt = System.DateTime.UtcNow.AddHours(TZ);
   var s1 = dt.ToString("MMMM d, yyyy HH:mm:ss", System.Globalization.CultureInfo.InvariantCulture);
   var s2 = dt.ToString(" tt", System.Globalization.CultureInfo.InvariantCulture).ToLower();
   return s1 + s2;
This expression produces a string output like this: June 3, 2015 09:35:48 am
using System;
using System.Linq;
using System.Xml.Linq;
Since the System namespace has been made available, all functions in the ​Math Namespace, the​Convert Class and all ​String operations are supported.
  • Script nodes
