Severe Limitations:
Limited Use:
Web BrowserMGPU: , Cluster:
  1. Usage and Interaction
  2. Input
    1. Multitouch ´
    2. Mouse
  3. Browser Functionality
    1. Browser Cache
  4. Progress and Status
    1. Content
    2. Cursor
  5. JavaScript
    1. Methods/Events
    2. Execute On Load
    3. Transparent Background
  6. WebBrowser Settings(Ad Blocker, Audio etc.)
  7. Debugging
  8. Limitations
The Web Browser node renders web pages into a texture so their content can be used inside a Ventuz scene. This is done based on the ​Chromium Embedded Framework CEF.
The TrackingMode defines which input interaction is sent to the node and is similar to the behaviour within the Interaction Rectangle:
  • All: Tracks all mouse and touch events in the 'air space' of the node even if other interaction nodes are covering parts of it and all keyboard events even if mouse or touch are outside the 'air space'.
  • NonCaptured: Tracks all interaction events that are not registered elsewhere by any other interaction nodes (covering the Interaction Rectangle). For remoting other applications or using scripts, it can be interesting to just track touches that are not used by any of Ventuz's interaction nodes.
  • NonCapturedWithAllKeys: Like the NonCaptured mode but with the exception that all keyboard events are tracked.
Input
The Web Browser Node collects all interaction data. Even if other rendered objects are in front, the input data is used in the Web Browser.
Multitouch ´
​Chromium Embedded Framework CEF can handle maximum 16 inputs per browser.
Mouse
Code Description
13 Return
9 Tab
8 Backspace
127 Delete
27 Escape
The unicode values for the most commonly used characters can be found ​here and ​here. Additional information on other character sets can be found ​here.
  • Load: Load the URL/HTML specified in the NavigationURL or NavigationHTML respectively.
  • Reload: Reloads the current content (same as pressing F5/Refresh in a dedicated browser application).
  • Stop: Stops/interrupt the current loading process.
  • Forward: Go one page forward in the navigation history.
  • Backward: Go page backward in the navigation history.
Browser Cache
%TMP%\Ventuz
Progress and Status
Content
  • CurrentURL: The URL of the currently displayed HTML page.
  • TargetURL: If the cursor hovers over a link, this provides the URL the link leads to.
  • Title: The title of the currently displayed HTML page.
  • Tooltip: If the content contains a tooltip for the current position of the cursor, it will be provided in this property.
Cursor
0 Pointer (default)
1 Cross 2 Hand 3 Ibeam 4 Wait
41 Custom
JavaScript
The Web Browser node supports the ​JavaScript scripting language both as part of the content as well as a means of interaction between Ventuz and the site content. This is done by defining input/output properties, methods and events in the Custom Model editor at the bottom of the Property Editor.
Methods/Events
<html>
<head>
<title>Method Test</title>
</head>
<body>
function CalculateSquare() {
  var result = ventuz.value * ventuz.value;
  document.write("The square of " + ventuz.value + " is " + result + "<br>");
  ventuz.Result(result);
</script>
</body>
</html>
Execute On Load
The property WebBrowserJavaScript can optionally contain a ​JavaScript snippet that is injected and executed on every loaded page. This opens many possibilities to operate on external pages.
Example 1:
Example 2:
Creates two methods called UP and DW in the Custom Model to invoke the defined JS functions. The displayed window will scroll up/down when Ventuz invokes these methods. (See also function ​scrollBy())
Allow ventuz:// URLs from External OriginsAllows you to reference assets inside a Ventuz Project from web pages outside the project
Debugging PortEnable and specify port for remote debugging of WebBrowser node.
Debugging
To investigate problems with web pages you can either use the Chromium DevTools or even the Remote Debugging functionality. To open the DevTools click the DevTools button at the bottom of the WebBrowser node's property page. To use Remote Debugging you have to enable it in the WebBrowser section of the Machine Configuration first. Then you can connect with a stand-alone Chrome browser to the Ventuz internal to work with the DevTools remotely.
  • Now open a Chrome Browser and visit chrome://inspect/#devices.
  • Configure Target Discovery Settings (Devices -> Discover network targets -> Configure) to include localhost:9222. 9222 is the default port used in the Machine Configuration.
  • Enable "Discover network Targets".
  • Some time / refreshes later all web pages of the WebBrowser nodes in the Ventuz Runtime are offered to be debugged with web tools.
  • Information about the Chrome Devtools Protocol (CDP) can be found here: ​Chrome DevTools Protocol
  • A simple way to check if the debug port is working: Visit http://localhost:9222/json which returns a list of all websocket targets (open pages and iframes).
Limitations
  • The Web Browser node is only working on the first (primary) GPU usually marked as 0:0 when enabling the Performance Statistics
  • The maximum resolution of the web browser is 16384 x 16384 pixels, going over 8K resolution isn't recommended though.
  • A touch is immediately claimed by the Web Browser, so a combination of Touch Translation node with the Web Browser node is not possible.
  • User login prompts and other popup windows are not supported.
  • Multi Touch
  • Ventuz Input Subsystem
  • ​JavaScript
