Severe Limitations:
Limited Use:
Warping and Soft-EdgingMGPU: , Cluster:
  2. The Ventuz Shaping Engine
    1. Performance Considerations
  3. The User Interface
    1. Navigation
    2. Global Toolbar
      1. Test Patterns
  4. Editing the Grid
    1. Selection
      1. Mirror Modes
    2. Editing
      1. Smart Mode
      2. UV Editor
    3. Summary
      1. Keyboard
      2. The Side-Toolbar
      3. Cursor Shape
    4. Zooming and Panning
    5. Handle Modes
    6. Insert Rows and Columns
  5. Manipulating Layers and Groups
    1. Subdivision
    2. Multiple Warp Groups
  6. Soft-Edges
    1. The gamma values
    2. Automatic Mode
    3. Manual Mode
  7. Per Output Settings
    1. Color Correction
    2. Quality Settings
  8. Per Group Settings
    2. UV Boundaries
    3. 3D projection
  9. Limitations
  • Warping: If the screen is not 100% parallel to the projector, the screen is curved, or the projector has a notable lens distortion, the outputs must be warped to compensate for that.
  • Soft-edging: If two projectors are put next to each other to project on a larger screen, the projectors need to be set up with overlap to get rid of cracks between the projections. In such cases, both images must be "crossfaded" correctly so that the overlap is unnoticeable.
To get into the Shaping and Warping Editor open up the Render Setup Editor, open a new or existing Render Setup and go into the Mapping Mode. There you will find the Shaping & Warping button in the top right.
You can shape/warp only for the local machine when using the Web-based Configuration Editor! Not for the whole cluster.
So to summarize:
Totally disabling shaping is, of course, the fastest.
Soft-edging will impact the speed of Ventuz only a little, and that impact is independent of the number of edges. Only while changing the edges with the editor, recreating the edge-texture might be notable of course.
Shaping with the Ventuz Designer
The User Interface
  1. Toolbar for global tools
  2. Toolbar with control-point related tools (side-bar)
  3. Output navigation show the currently used #screens used in the Render Setup
  4. Switch between output settings, warping and soft-edging
  5. Group and layer navigation
  6. Group and layer related properties
  7. Toolbar with group and layer related tools
  8. Grid Editor
The output navigation (3) displays a schematic view of the outputs. It will not try to faithfully represent the actual size and position of the displays but indicates the general layout, like a subway map will not represent the actual distance between stations. For instance, overlap is not shown here.
The area marked with (4) can be used to switch between warping and soft-edging. The output section contains color correction and other per-output settings.
Global Toolbar
These settings will affect the presenter / cluster even after the render setup has been left:
Nr Name Description
1 Enable warping If this is disabled, the whole warping engine is disabled
2 Enable soft-edging Disable only soft-edging. Usually one would switch off the edging until warping is done.
3 Enable color correction Disable only color correction. Quickly disabling and re-enabling color correction can be used to check the effect of color correction
Nr Name Description
4 White background Fill the unused pixels of an output with white instead of black. This shows how many pixels are wasted because of the warping.
5 Highlight overlap areas Sometimes it is useful to highlight the areas where the outputs overlap because precise warping here is especially important.
6 Cut soft-edges This will cut the soft-edges in a way that the output of the two sides directly touch but not overlap. This is useful to check how well the outputs match colors. This requires that the warping has been done already.
7 Darken rendering / test image Sometimes the user interface overlay is hard to see over a bright rendering or test pattern. This button will darken the background to remedy this.
8 Solo Mode Like in an audio mixer, this disables all other outputs. Useful when there is confusion which output contributes to what. Also, the test pattern will center to the solo output.
9 3D-Projection in Editor Enable / Disable the effect of the 3d projection in the shaping editor. It is a matter of taste what to prefer. 3D-Projection is always enabled on the outputs.
14 Show keyboard shortcuts Most users prefer to do as much as possible with the keyboard alone. This option aids in memorizing the keys.
15 Screen GUI options Control extent and size of the user interface HUD provided on the outputs.
Nr Name Description
10 Enable test pattern Enable test pattern. In the editor, the test pattern is always shown. The presenter can show either test pattern or the Ventuz scene.
11 Multiply output color Each output is assigned a color. This will multiply the test pattern foreground color with the output color. If good colors are assigned to the outputs, this helps to identify outputs and figure out which of two overlapping outputs needs warping and which is correct.
12 Select test pattern There are many useful test patterns programmed already. If they are insufficient, user images can be used as test patterns.
13 Test pattern options Most test patterns have a range of options to configure the width and distance of lines or the colors.
Test Patterns
Most test patterns offer a foreground and a background color. Also each output can be assigned a color. By pressing the Multiply output color icon in the global toolbar, the foreground color will be multiplied with the output color. For this to work, it is best to choose a bright color as the foreground color.
By default grid and checker test patterns will not perfectly fit, the last row and column will be cut off. By pressing Fit corners, this will be corrected, at the price that the aspect ratio is not guaranteed to be 1:1.
The image test pattern allows you to specify a directory that contains any pictures you prefer as test patterns. It is important that all presenters in a cluster and the computer that runs the shaping editor have the images on the exact same path. Using a network share is the simplest way to ensure this. If the image could not be loaded, a dummy image with color gradients is generated. The files in the directory are filtered for common image file types, like bmp, png, gif, tif, tga and jpg.
  • In the color and gray ramps, '-' toggles between gradient and bars.
  • In the color ramps, shift '-' toggles between rainbow and standard bars.
  • In grid and checkers, '-' toggles the fit corners option.
  • In image test pattern, '-' and shift '-' cycle through the images in a directory.
Editing the Grid
Selection
  • Gray: not selected
  • Orange: selected.
  • Red: current cursor position, also selected.
  • White: The mouse is hovering over the selected control point.
To select points, left-click on them. Pressing shift while doing so will add to the selection. When clicking beside the points, a rectangle is drawn as the mouse moves, and the points in the rectangle are selected. Again, pressing shift while doing so will add to the selection.
In addition to the primary control points at the cross-sections of the grid, there are control handles for finer control over the mesh. These are only visible, and can only be clicked on when the associated primary control point is selected.
Mirror Modes
Editing
The control points can be moved with the mouse just as they are selected, that is or + SHIFT. Holding CTRL while moving the mouse will limit the movement to either the x or y axis. This works by pressing CTRL before or after clicking . To move the points with the keyboard, use the Cursor keys + SHIFT.
For a warping layer, there is a way to move a control point without warping the image. This allows to move a point to a feature of the projection screen, and warp from there. With the mouse, use + CTRL. With the keyboard, use Cursor + SHIFT + CTRL. Before doing this, consider using the UV Editor, in most cases, it is more precise and intuitive.
Smart Mode
UV Editor
By default, the control points are mapped to evenly spaced locations of the content (or test image). So if you have a 5x5 grid and your test pattern is a 4x4 checkerboard, each control-point is directly bound to one of the intersections:
Summary
Keyboard
Mouse Keyboard Description
Cursor select point
SHIFT Cursor move selected points
 click on point select only this point, then move
SHIFT  click on point add point to selection, then move
CTRL  click move only horizontally or vertically
 click not on point B, then Cursor box selection
SHIFT ALT  click SHIFT ALT Cursor smart editing
CTRL  click CTRL Cursor move without warping
 click pan
 wheel zoom
The Side-Toolbar
Nr. Keyboard / Mouse Descriptions
1 Insert row (right of cursor)
2 Insert columns (below cursor)
3-7 A U K L S Handle Modes, see below
8 X Reset selected points to default position
9  wheel up Zoom in
10 R Reset zoom and pan
11  wheel down Zoom out
12 CTRL-Z Undo
13 CTRL-SHIFT-Z or CTRL-Y Redo
14 cycle with O, SHIFT O Mirror Mode off
15 cycle with O Mirror Mode Horizontal
16 cycle with O Mirror Mode Vertical
17 cycle with O Mirror Mode Horizontal + Vertical
18 cycle with O Mirror Mode Point-Symmetry
19 Normal Control Point Movement (Translation)
20 Toggle with SHIFT S Scale
21 Toggle with SHIFT R Rotation
22 Toggle with SHIFT U UV Edit Mode
- ESCAPE Reset mirror, scale, rotate and multiselect
Cursor Shape
Normal Box Selection UV Editor UV Box Selection
Translate (default)
Scale SHIFT S
Rotate SHIFT R
Zooming and Panning
Handle Modes
Name Color Shortcut Description
Linked Green A Both sides have same direction and stretching
Straight Yellow U Both sides have same direction, but can be stretched differently
Unlinked Red K Both sides are completely independent, allowing for kinks and different stretching
Linear Pink L Handles are automatically calculated for linear interpolation
Default Brown S Handles are automatically calculated for maximum smoothness
With most modes, the change of a handle is local and affects only the area of the surrounding 3x3 control points. In default mode, the change affects a 5x5 surrounding. This mode is useful for the 2x2 and 3x3 layers where this does not matter.
Please note that the handle modes are changed by this action: when inserting a single row into a 5x5 grid, the distances between the rows is different and the linked handle mode can not be used anymore, it is automatically changed to straight where that is required.
  1. Adds a new group.
  2. Adds a new layer. If the new layer is finer than the finest layer, it will become the new finest layer. Some editing done to the finest layer may be lost. It is best to subdivide the current finest layer once substantial editing has been done.
  3. Allows renaming the layer.
  4. Removes the selected group.
  5. Removes the selected layer. If the layer is not the finest layer, no editing is lost by this, as the finest layer holds all the information for creating the mesh.
  6. Move current group up (ALT Page Up)
  7. Move current group down (ALT Page Down)
  8. Reverts the whole group to default.
  9. Creates all soft edges, or reverts them to default when they already exist. Press this when the overlap has been changed in the render setup.
Subdivision
By pressing the '+' icon in the layer navigation, the finest layer can be subdivided in X, Y or both. This will insert a row and/or columns between every existing pair of rows/columns: a 5x5 point grid turns into a 9x9 point grid.
As 33x33 is the finest allowed layer, any layer with more than 17 points either horizontally or vertically can not be subdivided anymore.
One can have multiple warp groups per output. They are independent of each other, but share the same color correction and are drawn in the bottom to top order. If the warp groups overlap, use the toolbar or the ALT key and Page Up / Down to change the order. Pressing E will cycle through the groups.
Soft-Edges
The gamma values
  1. Apply the white spline
  2. Apply the separate red/green/blue splines
  3. Apply the gamma value
  4. Apply the separate red/green/blue gamma values
Automatic Mode
Manual Mode
In manual mode, only one edge can be edited at a time.
Per Output Settings
Color Correction
Name Description
Gain For color correction, a value that is used to multiply the rendering pixels
Lift For color correction, a value that is added to the rendering pixels, before contrast is applied
To change all 3 (red, green and blue) sliders at the same time, press the Alt key while dragging with the mouse. This will change the color values while trying to preserve the ratios between the colors, so brown will always stay brown and not become more and more pale-white as values increase.
Quality Settings
The Quality section mainly controls how fine the warping mesh is to be tessellated. The defaults are set for quite high quality, when using more precise values you should check for wasteful over-tesselation with the Show Wireframe option.
Name Description
Max Level Maximum subdivision when creating the mesh from the finest layer
Position Error Acceptable difference for the vertex positions between perfect Beziér interpolation and the actual mesh, in pixels
Mapping Error Acceptable difference for the UV mapping between perfect Beziér interpolation and the actual mesh, in pixels
Ramp Error Acceptable difference for ramp colors between perfect Beziér interpolation and the actual mesh, in color values ranging from 0 to 255
Dither Mode Enable dithering to improve ramp quality. Temporal dithering will change the dither pattern every frame, that usually gives better results but may result in undesirable artifacts.
Show Wireframe Shows the wireframe of the warping mesh. Useful for checking if the level of subdivision is reasonable or insane.
Enable / Disable Projector User Interface
The Projector Gui Enable button allows excluding some of the outputs from being affected by the shaping editor. Warping, Shaping and Masking are done as edited, but test patterns and the user interface is never drawn. The affected outputs are crossed out in the navigation.
Per Group Settings
Enable Warp Group / Alpha Blending
UV Boundaries
This allows making a warp group use only a portion of the content. Numerical input is possible for entering precise values.
3D projection
Shift will move the warp mesh
Limitations
Generally Warping and shaping works in a Cluster with or without multiples GPU's. But the use of the Warping and shaping editor is limited to the local PC only! Accessing any other PC in the same network and attempting to use the Editor will fail.
  • Cluster General
  • Cluster Setup HowTo
