Ventuz Configuration
  1. Ventuz Configuration
    1. Machine Selection
    2. Live Options
      1. Ventuz Options
    3. Rendering Options
    4. AV Options
    5. Ventuz Config
    6. Project Management
  2. Machine Configuration
    1. Interaction
      1. General
      2. Windows Touch
      3. TUIO
      4. Cluster Networking
      5. Output Scaling
    2. Remoting
      1. Remoting 2 (.Net)
      2. Remoting 4
      3. Miranda
      4. CLI Remoting
      5. OSC Remoting
    3. DMX
      1. General DMX settings
      2. Art-Net
      3. sACN
    4. Extended
      1. Presenter Settings
      2. Culture Settings
      3. WebBrowser Settings(Ad Blocker, Audio etc.)
      4. Process Settings
      5. Tracking System
      6. Timecode Settings
      7. Progress Visualization Settings
      8. Logging Settings
      9. System Monitoring Settings
    1. Render Pipes
      1. Stream Modes
      2. Preview
    2. Video Inputs
    4. Software Watchdog
    5. Software Keying
      1. SDI 3G
      2. 4k
    7. Chroma Keying
    8. Comprehensive Audio Mixing
  4. AV Configuration
    1. Video Outputs
    2. Video Inputs
    3. Video Options
      1. Standard Options
      2. Advanced Options
    5. Global Options
    6. Live Status
    7. Audio Devices
    8. Cross Points
    9. Device Mapping
  5. Render Setup Editor
    1. User Interface
    3. Coordinate Space
      1. Selection
      2. Move Elements
      3. Bezel and Overlap
      4. Split and Combine
      5. Machine ID
    7. Touch Area
      1. Examples and Scenarios
    8. Keyboard Shortcuts
  6. Warping and Soft-Edging
    1. The Ventuz Shaping Engine
      1. Performance Considerations
    2. The User Interface
      1. Navigation
      2. Global Toolbar
        1. Test Patterns
    3. Editing the Grid
      1. Selection
        1. Mirror Modes
      2. Editing
        1. Smart Mode
        2. UV Editor
      3. Summary
        1. Keyboard
        2. The Side-Toolbar
        3. Cursor Shape
      4. Zooming and Panning
      5. Handle Modes
      6. Insert Rows and Columns
      1. Subdivision
      2. Multiple Warp Groups
    5. Soft-Edges
      1. The gamma values
      2. Automatic Mode
      3. Manual Mode
    6. Per Output Settings
      1. Color Correction
      2. Quality Settings
    7. Per Group Settings
      2. UV Boundaries
      3. 3D projection
The Ventuz Configuration Editor enables the configuration of a Ventuz system for production. The editor also allows for the administration of multiple configurations and easy switching between them. The Ventuz Configuration Editor can be found in the Windows Start menu, or in the Tools menu of Ventuz Designer.
The editor is capable of configuring and controlling remote systems utilizing the Ventuz Machine Service. In fact, the local system is actually also technically configured by remote access (via localhost)! An installed, started and accessible VMS is mandatory for all systems being configured.
The Ventuz Configuration is project independent and handles and configures all settings related to the Ventuz system. Most of the settings are hardware related but it also contains rendering, network and identification settings. This configuration affects settings of the Ventuz installation and likely needs to be changed whenever the system is used for another project.
Changing the Ventuz Configuration requires a restart of Ventuz is most cases! (except for changing Live Options. See below).
The Ventuz Configuration Editor consists of several sections which are described here:
  1. Selection of a single Ventuz machine or selection of a group of Ventuz machines (Cluster)
  2. Editing of Live-Options (only in single machine mode)
  3. Configuration of the Ventuz Config (Name, ID, GroupID and selection of sub-configurations)
    1. Edit and administrate Machine Configuration (only in single machine mode)
    2. Edit and administrate AV Configuration (only in single machine mode)
    3. Edit and administrate Render Setup (in single and group machine mode)
  4. Live Project Management (Upload Ventuz project, Start and Stop Ventuz Runtime)
  5. Log Messages: When  clicked, shows the message log window.
  6. Determines which Layout scene should be loaded. For more information on Layout scenes see here Scene Tree.
All Ventuz configuration files are stored in the system's public documents folder in the Ventuz6\Configuration directory. On most systems this path is:
C:\Users\Public\Documents\Ventuz6\Configuration\
In the Ventuz config folder multiple files and folders are stored. All Ventuz configuration files use the XML format and therefore are human readable and easy to handle.
VentuzConfig.vcfg Ventuz Configuration
MachineConfig\*.vmc Machine Configuration Files
AVConfig\*.avc AV Configuration Files
RendersSetup\*.vmc Render Setup Files
Director\*.* Director Configuration Files (not part of the Ventuz Config Editor)
Machine Selection
The Machine Selector shows all machines discovered within the network. The Ventuz Machine Service broadcasts its VMS signature periodically. The Machine Selector receives these messages and add the entries to the selector. Machines without VMS running can't be discovered and configured!
The entry with the green bar on the left marks the local machine. The local machine is the default selection when the Ventuz Configuration Editor is started.
The selector automatically groups all machines with the same GroupID. To select a group click on the group label (here Group 2). Only Render Setups and Project Management are available when a group is selected.
Live Options
Some settings from all configuration areas as well as many settings for the renderer can be adjusted on-the-fly by entering the Live Options on a machine with a running and connected Ventuz Runtime process (green or yellow state). Currently there are three areas that have live options available:
  • Ventuz Designer
Please note that Live Options can only be saved if the corresponding configuration is not set to (None). The actual values of the settings are injected into the currently loaded file and it will be saved to disk. If there is no configuration file Ventuz can't save it...
Displays
The performance statistics contain a lot of information. In many cases displaying it all can be a bit overwhelming and requires a lot of screen real-estate. So individual sections can be enabled and disabled and with the Frame Count the amount of visible frames can be adjusted:
With all sections enabled, it can look like this:
Performance
In general:
History Mode and Pause
Interpreting GPU Measurement
Accumulated Bars Versus Detailed Timeline
Performance Impact of Measurement
System Information
Node Limit
GPU Information
Creation Calls are an exceptionally expensive part of the DirectX API and should only happen during scene loading.
Persistent Resources are resources that accumulate and are never deleted until Ventuz is quit. VertexFormats and VertexConverters are cheap internal resources that should stay below 25. Shaders is the number of different shaders that have been used since Ventuz started.
GPU Memory: this shows how GPU memory is divided into geometry (vertex and index buffers), textures and Color/Depth Target (textures used as rendertarget or depth buffer).
AV Inputs / Outputs
The states mean:
  • Running: stream is running
Movies
The states are:
  • error: the stream failed
  • busy: Internal operation
  • empty: No file was loaded
  • loadmeta: loading metadata
  • loadinfo: prepare playback
  • active: normal playback
  • pause: playback is paused
  • seek: seeking
The buffers show how many buffers Ventuz has allocated and how many frames in the future are available. If these buffers run dry, increase the number of buffers for that movie. At the end of each line you can see the exact Cluster Clock when each Movie Started. Like the lead this is mainly useful to check syncronization of movies in a cluster.
Tracking
User-manual To-Do:
  • add offset matrix that occurs with touch teleport node
Layer Processing
Each line represents:
  • rendering a scene
Watches
Ventuz Options
The ID and the currently used Render Setup can be changed live. Changing these values doesn't affect the saved Ventuz Configuration as long the Live Options have not been saved.
Rendering Options
These options change some renderer-specific settings. The same options are also available in the Renderer Windows in Ventuz Designer.
Please note that the Rendering Options cannot be saved! After a restart of Ventuz all options fall back to their default values.
AV Options
Some board and audio and video stream have settings that only can reasonably adjusted while Ventuz is running (Genlock delay, audio gains and delays, etc). The live AV options make all settings available that are changeable on-the-fly. Saving the AV part of the Live Options will overwrite the current AV Configuration File. If no configuration has been set (None) the live edited values cannot be saved!
Ventuz Config
The Ventuz Configuration contains general information about the Ventuz Machine. It defines the Name of the machine as well its numeric ID and GroupID. The ID is used to select the correct part to be rendered in the multi-machine Render Setup. The GroupID must be set to a value greater than zero if a machine is part of a Cluster (group). Only machines with a GroupID can interchange their timing (cluster clock) to synchronize Remoting, animation and movie playback. For proper synchronization a valid Cluster Option is required. The Name of a machine is technically not important. A proper name helps the user to identify a machine within a Ventuz network.
The Machine Tag is used by the Runtime to determine the Scene that is to be used.
The Ventuz Configuration also defines which sub-configuration should be used for the three sub-sections: Machine Configuration, AV Configuration and Render Setup. The corresponding selection boxes (3a, 3b and 3c) allows the user to switch between the existing configurations. Changing a value here requires the Ventuz Configuration to be saved. This can be done by pressing the Save button.
Each of the three sub-configuration has an Administration Area. This is shown if the expander left of the selection box is clicked.
The Administration Area shows a list of all available configurations where the checked entry marks the currently active file.
Several action can be performed on the selected entries:
Edit selected entry Create new entry
Duplicates selected entry Renames selected entry
Deletes selected entry
Imports a file Exports selected entry
The Edit and New buttons are also available in the compact view of each sub-configuration section though the shown entry is the check and selected one at the same time. (always the active configuration is edited)
Editing an entry switches to the corresponding sub-configuration editor. Each sub-editor has its own Save and Cancel buttons. These buttons affect only the current sub-configuration being edited. The Save button on the Ventuz Configuration page only affects the settings of the Ventuz Configuration which references the sub-configurations by name.
Importing and Exporting is just a simple way to copy the actual configuration files from/to the configuration folder. If a remote system or group of machines is configured this feature becomes very helpful!
Project Management
The Live Project Management allows a project found on the target system to be selected and Ventuz Runtime to be started with the selection. The simple view can also be expanded to show more options:
The displayed list shows all projects found by VMS on the target system. If the user hovers the mouse over one entry a tooltip popup shows more details about the project. The project files must be stored in the project folder configured in VMS. The default folder is
C:\Users\Public\Documents\Ventuz6\Projects
In expanded mode the Live Project Management can perform several actions:
Start the selected project. Any previously running Ventuz Runtime will be closed before!
Stop (kill) any currently running Ventuz Runtime.
Upload a Ventuz Project (VPA or VPR) to all selected machines and initiate a re-scan on VMS.
Initiate a project scan on all selected target machines.
  • Input Handling inside Ventuz
  • ​Open Sound Control
  • ​Deltacast
  • ​Miranda/GrassValley: Vertigo Suite and Miranda: X-3D / X-Ventuz]
