Communication Protocols Overview
    This page is a summary of all available Communication protocols that can be used inside Ventuz. Use it to quickly navigate to the detailed guides inside the Manual for the chosen topic.
    Serial
    The Serial Text node is able to send and receive simple text messages across a serial (COM) connection.
    RemotingExternal data
    MIDI Nodes
    MIDI (Musical Instrument Digital Interface) is a protocol for communication between music devices.
    OSC Nodes
    OSC stands for Open Sound Control and is a network protocol designed for simple communication between computers and/or multimedia hardware.
    General Purpose Input
    The '''GPI''' Node can be used to get the state of a GPIO Board's input pin.
    Network
    The TCP Client node provides the ability to send simple text commands to a TCP server socket asynchronously.
    DMX Nodes
    Ventuz supports sending and receiving DMX data, using the two protocols Art-Net and sACN, that allow transporting DMX data over ethernet.
    Timecode Nodes
    Timecode nodes provide a wide range of usecases.
    TUIO
    TUIO is a network protocol designed for transmitting MultiTouch input data.
    introductiondesignerinteractionlogic
    Designer&Runtime
    Ventuz 4 - Remoting
    Designer&Runtime
    Remoting over HTTP
    Remoting4 via HTTP or HTTPS
    Remoting 4 via Websocket
    Remoting 4 via websocket
    Designer&Runtime
    Remoting over HTTP
