With Ventuz 7 the Web-Based Configuration Editor has the same functionality as the Configuration Editor standalone application. Please refer to the Configuration Editor page for all informations regarding the configuration and control properties.
With Ventuz 7 the Web Browser based Configuration Editor has the same functionality as the standalone application. It is not necessary to have Ventuz locally installed and it is also possible to use a tablet or a phone as device.
The address is as following:
| IP - Address | Via the Web Browser you can access the Configuration Editor directly with entering the IP of the Ventuz machine and |
| 21404 | the Port to access V7 Configuration Editor |
| localhost:21404 | Open the Configuration Editor via your local VMS on your machine |
| 192.168.4.25:21404 | sample address for the Web Configuration Editor on another machine |
Due to the vast number of web browser and versions of those, we can not provide guaranteed support for all versions and all features. You might test your web browser device for full support.
We do not recommend to use Microsoft Edge Browser while Runtime is rendering due to performance issues on the GPU
| OK | Ventuz is connected and running |
| INIT | Ventuz is connected and running, though no project is loaded yet |
| OFFLINE | Ventuz is not connected |
| TIMEOUT | No VMS discovery message received |
| Ready | waiting for input signal, ready to go |
| Presync, Syncing | stabilizing stream, synchronizing multiple streams together |
| Running | stream is running normally |
| Disabled | disabled either by the Live Video Node or by the software watchdog. |
| Bypass | bypass relays activated |
| Error | some error condition, see log for details. |
| Name | Bits Per Pixel | Comment |
| YUV422 10 bit | 21.3 | best quality |
| YUV422 8 bit | 16 | best speed |
| YUVK4224 10 bit | 32 | best quality with alpha |
| YUVK4224 8 bit | 24 | best speed with alpha |
| RGBA 8 bit | 32 | used as quality option when YUVK4224 10 bit is not available |
| RGB 8 bit | 24 | used for some webcams (windows media foundation devices) |
| YUV422 8 bit with separate alpha | 24 | used for iVGA, same quality and speed as YUVK4224 8 bit |
| Input -> Ventuz | The delay from input to the Ventuz renderer |
| Ventuz -> Output | The delay from the Ventuz renderer to output |
| Input -> Output | The delay from the input and the output |
