  1. Single Statement
  2. Multiple Statements
  3. Examples
  4. Available Name Spaces
Expressions
Double Expression Provides the possibility to write logical C# expressions with a Double as resulting output value.
Boolean Expression Provides the possibility to write logical C# expressions with a Boolean as resulting output value. Additional it provides True and False Event outputs.
Date Time Expression Provides the possibility to write logical C# expressions with Date Time as resulting output value.
Float Array Expression Provides the possibility to write logical C# expressions with a Float array as resulting output value.
Double Array Expression Provides the possibility to write logical C# expressions with a Double array as resulting output value.
Int Array Expression Provides the possibility to write logical C# expressions with an Int array as resulting output value.
String Array Expression Provides the possibility to write logical C# expressions with a String array as resulting output value.
Boolean Array Expression Provides the possibility to write logical C# expressions with a Boolean array as resulting output value. Additional it provides True and False Event outputs.
Dynamic Expression Provides the possibility to write logical C# expressions with the ability to manual define in and output values.
Single Statement
   return EXPRESSION;
Multiple Statements
   STATEMENTS
   return RESULT;
Examples
(A == 6) ? 1:0 Return 1 if A is equal to 1.6, otherwise return 0.
(A != B) ? 1:0 Return 1 if A is not equal to B, otherwise return 0.
(A >= 0) ? 0 : A Return 0 if A is greater than or equal to 0, otherwise return A.
   int b = 0;
   for(int i = 1; i <= A; i++)
	b = b + i;
   return b;
Results in the sum of all numbers from 0 to A.
   int b = 1;
   if(A<=1) return 1;
	b = b * i;
   return b;
Results in A! (the faculty of A). Note that there are two return statements - one of which will only be reached if A is 1 or less.
	int result = 0;
        result += A[i];
   return result;
Returns the sum of all elements in the numeric array A. Only succeeds if the input is an array type.
  System.DateTime.UtcNow.AddHours(2)
This expression takes the current UTC Date Time and adds 2 hours. If you use a Date Time Expression Node, the result is a DateTime object that can be further processed with the Convert to Text Node for example.
	Array.Sort(A);
	return A;
By using array expressions, this expression will sort an incoming array with the help of the System.Array.Sort(Array) .Net Method. Check ​the microsoft documentation for further details.
using System;
using System.Linq;
using System.Xml.Linq;
Since the System namespace has been made available, all functions in the ​Math Namespace, the​Convert Class and all ​String operations are supported.
  • Script nodes
