Mirror
MirrorRenders a mirrored version of the 3D Layer content.
Effect Mirror Renders a mirrored version of the 3D Layer content and can apply effects to it.
Mirror
Effect Mirror
  • Mirror Filter Node
  • Anti Aliasing
