![]() | Color Layer | Fills the Layer with a Solid Color |
![]() | Gradient Layer | Creates a Gradient filled Layer - The gradient can be edited and reoriented |
![]() | Image Layer | Creates a simple Layer with an Image - for more properties choose the Texture Loader Layer |
![]() | SVG File Layer | Creates a layer to load SVG drawings |
![]() | SVG Text Layer | Creates a layer that is completely filled with a SVG drawing coming in as XML text |
![]() | Movie Clip Layer | Creates a layer to load in a Movie Clip |
![]() | Movie Frame Layer | Creates a layer to load in a Movie Clip and specify a single Frame inside the Properties |
![]() | Movie Stream Layer | Creates a layer to load in a Streaming Video Clip like a RTSP |
![]() | Live Video Layer | Creates a layer to show Live Video Streams - these Video Inputs have to be configured in the Ventuz Config Editor |
![]() | Gradient Texture Layer | Creates a Gradient Layer with a Gradient Texture node attached inside the Content Editor Area |
![]() | Texture Loader Layer | Creates a Texture Layer with a Texture Loader node attached inside the Content Editor Area |
![]() | Texture Property Layer | Creates a Texture Property Layer only - you need to connect any source node inside the Content Editor Area |
| Spout Receiver Layer | Receives a RGBA texture via SPOUT |
The Image Layer loads standard images and layouts them in Full Size per default. You would preferably use the Image Layer to bring images on screen because it does not generate MipMaps nor does it apply any kind of multisampling. While using the Image Layer you can adjust the Gamma and how to handle the Alpha Channel by changing the Property called TextureHint.
Gamma
- Not a Color is used mostly for Roughness and Specularity Material Stages since the Texture is used without any gamma conversion and these Textures are usually Grayscale. Textures loaded with this option will not be touched or converted internally into any other colorspace which is important when using the HDR-Render Mode.
- sRGB defines to use the Texture in the sRGB colorspace, which is the standard for Images, Videos and most Textures.
- Gamma2_2 loads the Texture in Gamma 2.2 which is most times needed when using Cubemaps/Environment maps in HDR. Linear loads the Texture in Gamma 1.0.
- Normal Map uses a special internal routine to blend the colors between the different MipMap stages to result in normalised Normal Vectors. This makes it possible to have Crisp and correct MipMaps.
Alpha
- Premultiply by File which detects if a premultiplication is needed.
- Preserve will never premultiply and keep the alpha as-is.
- Always will force a premultiplication.
Example:
<g id="g14">
<g id="g16">
</g>
</g>
</g>
</g>
</svg>
Output:
The Live Video Layer offers a simple and effective way to add any configured live video to be feed into Ventuz. To use the Live Video Layer with your Webcam or SDI-Board, you would need to setup the Video Input Source in the Device Configuration. With the Live Video Layer you are able to create very quick side by side Video Feeds simply by adjusting the Layout of the layer itself. To select a specific Ordinal you can either click the Layer Icon or use the Ordinal drop down menu in the Video Property. You can Enable and Disable the Live Video by clicking the buttons in the Video Control section.
| Variable | Meaning |
| !{0}, !{4} | Position of the color keys |
| !{1}, !{5} | Red-Value of the color keys |
| !{2}, !{6} | Green-Value of the color keys |
| !{3}, !{7} | Blue-Value of the color keys |
| !{8}, !{10} | Position of the Alpha keys |
| !{9}, !{11} | Value of the Alpha keys |
The difference with the Image Layer is that the Texture Loader Layer also adds a Texture Loader Node to the Content Area. To load an image into the Layer you would need to specify it in the Texture File Property. The TextureHint is a multi-option drop-down menu used for setting how image Gamma and Alpha channel information are loaded.
Gamma
Alpha
The SPOUT Receiver Node receives an RGBA Texture that can be bound to e.g. a Material Node.Every SPOUT Sender available is added to a List, with the Sender Name Property you can select the sender you want to receive the Texture from. In the outputs you get a list of all currently available senders. This list is updated once during initialization of the node. If needed you can update the list again using the Update Sender List Method.
Not a Color Textures loaded with this option will not be touched or converted internally into any other colorspace sRGB defines to use the Texture in the sRGB colorspace, which is the standard for Images, Videos and most Textures. Linear loads the Texture in Gamma 1.0.
Protocol Version Pixel semantic 2.006 RGBA
The NDI Receiver provides the texture of a chosen NDI source together with several meta data. The Source property defines which NDI source to use - it can be provided either as a string or using the dropdown menu that is accessed by clicking the arrow on its right.
Low Bandwidth limits the input to 640x360 pixels which saves bandwitch between the source and Ventuz andis meant to be used e.g. for preview cases. Low Latency disables frame buffering that is used to stabilize the incoming framerate. If enabled it may cause stuttering on the input depending on the NDI source and the network environment, but the frames will be processed by Ventuz without any delay.
Each of these Ordinals can be mapped to the physical stereo pairs of your machine in the Device Configuration. You can define several mappings of a stream and channel to an output ordinal by adding any number of Property Groups with the
in the Property Group List inside the Property Editor. The Stream dropdown defines which stream of the File to use. For the Channels you can choose to use any single Mono Channel, two consecutive channels as Stereo Channels or to Downmix the whole stream into a single stereo signal. In the Flags property you can turn on several options: Flip L/R swaps the left and right channels if it plays back two channels as stereo. Invert left/right phase invert the polarity of either channel. And Mid/Side to Stereo converts a mid or side channel to a stereo channel. Ordinal selects the Logical Device Ordinal used for this mapping. Gain changes the sound level of this input and the Balance adjusts the playback volume between the left and right audio channel.
ECC Level
