SVG Loader
SVG Loader Rasterizes Scalable Vector Graphics coming in as File or XML Text.
The SVG Loader Node is able to create a Texture in the respective dimension based on an SVG File or XML Text. The source can be changed with the SVG File or SVG Text Property Group options.
Usage
Example:
      <g id="g14">
        <g id="g16">
        </g>
      </g>
    </g>
  </g>
</svg>
Output:
Limitations
  • Material Node
  • SVG Layer
  • ​https://en.wikipedia.org/wiki/Scalable_Vector_Graphics
