HLSL Shader
  1. HLSL Shader
  2. Ventuz HLSL Shader
    1. Variables
    2. Textures
    3. Vertex Textures
    4. Passes
  3. Reference Information
    1. Supported Semantics
    2. Supported Annotations
    3. State Changes
    4. Light Source Information
    5. Texture Information
  4. Adapting External Shaders
HLSL Shader A customizable HLSL shader implementation.
HLSL Shader
float4x4 Ms2Ss : WORLDVIEWPROJECTION;		// matrix from Model Space to Clip Space
void VS( float3 MsPos : POSITION, out float4 SsPos : SV_Position )
	SsPos = mul(float4(MsPos,1), Ms2Ss);	// transform from model space (Ms9 to clip space (Ss)
void PS( out float4 color : SV_Target0 )
	color = float4(1,0,0,1);
technique11 Tech1
	pass pass0
		vertexshader = compile vs_5_0 VS();
		pixelshader  = compile ps_5_0 PS();
A shader consists of two programs, the vertex and the pixel shader. The vertex shader is executed for each vertex that is rendered and must at least generate a transformed output position. The graphics card uses this output position to transform the primitive that is rendered into a number of fragments. For each fragment, the pixel shader is executed to calculate the final color of the fragment as it is turned into a pixel. In the example above, the vertex position is transformed using the world-view-projection matrix and each fragment is transformed into a solid red pixel regardless of any light or material nodes in the scene.
Ventuz HLSL Shader
Variables
A shader usually requires a number of values from the hosting application - in this case Ventuz - to operate properly. Even the simple shader in the example above requires the world-view-projection matrix to properly transform a vertex. There are three ways to assign a variable with proper values coming from Ventuz:
  • Semantics: A semantic describes the meaning of a variable and is added by a colon followed by a string right after the variable declaration. If Ventuz understands the semantic, it will automatically fill the variable with the correct values before the shader is executed.
  • Annotations: Annotations are a more standarized way of describing the meaning of a variable. They can be used to either describe how a proper user interface element for this variable should look like (for example a color picker) or bind them to a specific data source (for example the position of a light source).
  • Neither: If neither a semantic or annotation is used, the variable will be translated into one or more properties that will be visible in the Property Editor when selecting the shader node.
Textures
A shader addresses a texture via a sampler object. A lot of shader source codes do not contain an explicit texture variable definition but rather rely on the host application to associate the appropriate texture with a specific sampler. In contrast, Ventuz requires a texture variable declaration to create a bindable texture property. The assignment of a texture to a sampler has to be done from within the shader source code during the sampling:
Texture2D tex : register(t0);				// define texture
SamplerState sam : register(s0);			// define sampler
	// inside the pixel shader:
	color = tex.Sample(sam, UV);			//sample tex with sam
Which texture variable is assigned to which stage depends on what the DirectX shader compiler thinks is best. Usually the first texture used in a render pass (e.g. the respective vertex shader and pixel shader) is assigned to stage 1, the second to stage two and so on. To ensure proper interoperability with the standard Texture nodes, a dedicated stage should be assigned to each sampler, especially when multiple textures are used in multiple passes. This is done by adding :register(sx) after the sample definition where x is a 0 for stage1 up to 7 for stage8.
Vertex Textures
A vertex texture must be sampled with the SampleLevel function. This is because mipmapping information cannot be computed automatically and must be specified manually. Usually you will want a mipmap LoD of 0.
    float2 uv = input.uv;
    float lod = 0;
    float4 tex = tex.SampleLevel(Vertex1,uv,lod);
Filtering works the same as with pixel shader textures.
Passes
If multiple passes are required to render the same geometry, the respective nodes should be linked to both outputs (using CTRL + SHIFT while dragging, see Hierarchy Editor). This avoids creating two copies of all the nodes in the subtree, but there is still a memory overhead compared to using the content only on one output.
Supported Semantics
One of the biggest drawback of shader semantics is the fact that they are not standardized. It is up to the application to define a string that is used to describe a certain semantic and many applications use incompatible definitions. At the time of writing, Ventuz only supports the following semantics:
Semantic Type Description
WORLD float4x4 The object-to-world matrix at the geometry currently rendered. Usually the result of a number of Axis nodes.
WORLDINVERSE float4x4 Inverse of the object-to-world matrix.
VIEW float4x4 The world-to-view matrix at the geometry currently rendered. Usually the result of a Camera node.
VIEWINVERSE float4x4 Inverse of the world-to-view matrix.
PROJECTION float4x4 The view-to-clip space matrix at the geometry currently rendered. Usually the result of a Camera node.
PROJECTIONINVERSE float4x4 Inverse of the view-to-clip space matrix.
WORLDVIEWPROJECTION float4x4 Combined matrix that contains the complete transformation from object to clip space. This is usually used to compute the output position of a vertex.
WORLDVIEWPROJECTIONINVERSE float4x4 Inverse of the world-view-projection matrix.
WORLDVIEW float4x4 Combined matrix that contains the object-view transformation.
WORLDVIEWINVERSE float4x4 Inverse of the world-view matrix.
VIEWPROJECTION float4x4 Combined matrix that contains the transformation from world to clip space.
VIEWPROJECTIONINVERSE float4x4 Inverse of the view-projection matrix.
Example:
​Annotations are an effort by Microsoft to address the disadvantages of using semantics. There are two different categories of annotations: User interface and data binding annotations. All annotations are specified by variable declarations inside less and greater than characters right after the original variable.
float4x4 View
    string SasBindAddress = "Sas.Camera.WorldToView";
Sas.Skeleton.MeshToJointToWorld[0] float4x4 Object-to-world matrix.
Sas.Camera.WorldToView float4x4 World-to-view matrix.
Sas.Camera.Projection float4x4 View-to-clip space matrix.
Sas.Light[0].Direction float3 Direction vector of the first light source. Indices 0-7 are supported.
Ventuz.Lights.Ambient float4 Ambient color of the most recently set light source with respect to the rendering order of the scene hierarchy.
Ventuz.Lights.Diffuse float4 Diffuse color of the most recently set light source with respect to the rendering order of the scene hierarchy.
Ventuz.Lights.Direction float3 Direction vector of the most recently set light source with respect to the rendering order of the scene hierarchy.
Ventuz.Lights.Position float3 Position of the most recently set light source with respect to the rendering order of the scene hierarchy.
Ventuz.Lights.Specular float4 Specular color of the most recently set light source with respect to the rendering order of the scene hierarchy.
Ventuz.Material.Alpha float Alpha value at the geometry currently rendered. Multiple Alpha nodes or Material nodes may have contributed to this value based on their AlphaRelation properties.
Ventuz.Material.Ambient float4 Ambient material color active at the time the geometry is rendered, usually the result of a parent Material node.
Ventuz.Material.Color float4 Color active at the time the geometry is rendered. In case the geometry is influenced by a Material node, this will be the diffuse color of that node. In case the geometry is influenced by a Color node, this will be the color of that node. Note that the alpha value may be the accumulated alpha of multiple nodes based on the AlphaRelation property of the material node.
Ventuz.Material.Base float4 Base Color.
Ventuz.Material.Diffuse float4 Diffuse material color active at the time the geometry is rendered, usually the result of a parent Material node. Note that the alpha value may be the accumulated alpha of multiple nodes based on the AlphaRelation property of the material node.
Ventuz.Material.Emissive float4 Emissive material color active at the time the geometry is rendered, usually the result of a parent Material node.
Ventuz.Material.Sharpness float Specular material exponent active at the time the geometry is rendered, usually the result of a parent Material node.
Ventuz.Material.Specular float4 Specular material color active at the time the geometry is rendered, usually the result of a parent Material node.
Ventuz.RenderTarget.Size float2 Dimension in pixel of the Offscreen Layer active during rendering of the geometry.
Ventuz.Texture.Active bool True if at least one texture is set to any of the texture stages, usually the result of a parent Texture node.
Ventuz.Texture.Mapping float4x4 Texture mapping matrix active at the time the geometry is rendered, usually the result of a inside a Material node. A shader that wants to respect texture mapping should multiply the input texture coordinates by this matrix to apply the mapping transformation.
Ventuz.Viewport.Size float2 Dimension in pixel of the [NodeLayer3D 3D Layer] active at the time the geometry is rendered.
Ventuz.DirectionalLight[*] VentuzDirectionalLight[8] All directional lights, see Light Source Information
Ventuz.PointLight[*] VentuzPointLight[8] All point-lights, see Light Source Information
Ventuz.SpotLight[*] VentuzSpotLight[8] All spot-lights, see Light Source Information
Ventuz.Light[*] VentuzLight[8] All lights, see Light Source Information
Ventuz.NumDirectionalLights int Number of directional lights
Ventuz.NumPointLights int Number of point-lights
Ventuz.NumSpotLights int Number of spot-lights
Ventuz.NumLights int Number of lights, independent of type
Ventuz.Textures[*].Size float4[8] Size of the texture image in pixels, see Texture Information
Ventuz.Textures[*].Mapping float4x4[8] Mapping matrices for all textures, see Texture Information
Ventuz.Textures[*].Info uint4[8] Information about texture shading and UV mapping, see Texture Information
Ventuz.NumTextures int Number of textures. Exactly: Index of the last used texture stage plus one.
float4 DiffColor
	string SasUiControl = "ColorPicker";
	string SasUiLabel = "Diffuse";
> = { 1.0f, 0.022f, 0.0f, 1.0f };
Annotation Type Description
SasUiControl string Supported values are ColorPicker and Direction.
SasUiLabel string Name of the property as it will appear in the Property Editor, must be unique with respect to the other properties generated. If the same name is used for different properties, the automatic property generation algorithm will most likely fail or produce incorrect results.
SasUiMin int/float Minimum value for a float or int variable, not supported for vector types.
SasUiMax int/float Maximum value for a float or int variable, not supported for vector types.
SasUiSteps int/float Increments by which a property can be increased/decreased. Can for example be used to only allow odd numbers.
SasUiVisible bool If set to false, no property will be generated for this variable.
VentuzFavored bool By default, all parameters will produce a favored property. Use this annotation to specify whether a property should be favored or not.
State Changes
HLSL allows adding state change information to a pass (see ​MSDN: Effect states. While one could also use the respective Ventuz nodes, it is a convenient way to influence the rendering behavior.
DepthStencilState NoZTest {
	DepthEnable = FALSE;
technique11 Tech1
	pass pass0
		SetDepthStencilState( NoZTest, 0 );
The state changes are applied when rendering of the respective pass starts, so at the time of the shader node in the rendering order. Any relevant node (for example Z-Testing for DepthEnable) before the shader is overwritten and any node after the shader will overwrite the shader's state change.
Information about all light source can be retrieved in the shader by using the Ventuz.DirectionalLight[*], Ventuz.PointLight[*], Ventuz.SpotLight[*] and Ventuz.Light[*] annotations. First you have to declare the following structures:
struct VentuzDirectionalLight
    float3 DiffuseColor;
    float3 SpecularColor;
    float3 AmbientColor;
    float3 Direction;
struct VentuzPointLight
    float3 Position;
    float3 Attenuation;
    float Range;
struct VentuzSpotLight
    float3 Position;
    float3 Direction;
    float3 Attenuation;
    float4 RangeFallofInnerOuter;
struct VentuzLight
    int Type;
    float3 Position;
    float3 Direction;
    float3 Attenuation;
VentuzDirectionalLight DirLights[8]
   string SasBindAddress = "Ventuz.DirectionalLight[*]";
VentuzPointLight PointLights[8]
   string SasBindAddress = "Ventuz.PointLight[*]";
VentuzSpotLight SpotLights[8]
   string SasBindAddress = "Ventuz.SpotLight[*]";
VentuzLight SpotLights[8]
   string SasBindAddress = "Ventuz.Light[*]";
int DirectionalLightCount
   string SasBindAddress = "Ventuz.NumDirectionalLights";
int PointLightCount
   string SasBindAddress = "Ventuz.NumPointLights";
int SpotLightCount
   string SasBindAddress = "Ventuz.NumSpotLights";
int LightCount
   string SasBindAddress = "Ventuz.NumLights";
Note that the old DX9 Attenuation values are not used anymore and set to 0 since Ventuz 7.
The field RangeFallofInnerOuter holds for information:
  • RangeFallofInnerOuter.x is the range
  • RangeFallofInnerOuter.y is the falloff
  • RangeFallofInnerOuter.z is the inner cone, in the form of cos(inner/2)
  • RangeFallofInnerOuter.w is the outer cone, in the form of cos(outer/2)
The light Type is:
  • 1: Point light
  • 2: Spot light
  • 3: Directional light
Texture Information
float4 TexSize[8]
    string SasBindAddress = "Ventuz.Textures[*].Size";
float4x4 TexMap[8]
    string SasBindAddress = "Ventuz.Textures[*].Mapping";
uint4 TexInfo[8]
    string SasBindAddress = "Ventuz.Textures[*].Info";
int TexCount
    string SasBindAddress = "Ventuz.NumTextures";
Ventuz.Textures[*].Info contains various information about selected texture options. Most of this information does only work with the old legacy texture node, which has been removed. The only thing that still works is:
The sampling options in info.w are
  • 0: texture is unused
  • 1: 2d texture
  • 3: cube texture
For a shader to work properly, a certain amount of functionality is required in the hosting application. Since the implementation of that functionality varies from application to application, it is in general not possible to simply copy-and-paste the shader source code from another application into Ventuz and having it produce the same results without modifications. The following is a list of points based on the experiences on porting shaders to Ventuz:
  • Ventuz uses DirectX 11 and thus supports pixel shader model and vertex shader model 5.0. Older shader models will not compile without some modifications.
  • Multiplication order: The proper multiplication order of a vector and matrix is vecresult = mul(vec, matrix) as the matrices are passed to the shader in a column-major layout. ATI Render Monkey for example uses a row-major layout and therefore uses an inverted multiplication order in its shader examples.
  • Left-handed vs right-handed coordinate system: Ventuz by default uses a left-handed coordinate system (x to the right, y to the top, z point towards the screen) where many modeling/CAD applications use a right-handed coordinate system (z points away from the screen). This may require that vector/matrix operations have to be adapted.
  • If something doesn't work, maybe the shader source is buggy. Even the official parallax occlusion shader from the DirectX SDK has a bug in it.
  • In one case, the binormal and tangent had to be switched in the shader source code to produce correct results in Ventuz.
  • Ventuz generates properties for all global variables that are not bound to a data source via semantic or annotation. For constants that are only required in the shader and are never supposed to change, use the const static keywords.
  • It is possible to pass float arrays to a shader, but the size of the array has to be set to a fixed size in the shader code. There is no way to handle arrays of dynamic size.
  • Calling normalize on a float4 divides all components by the length of the complete vector. For example, normalize( mul(Pos, world_view) ) will produce an incorrect direction vector as the homogenous component w is not ignored. Either set it to zero before normalizing or clamp the float4 to a float3.
  • The statement if ( booleanvariable == true ) for some reason always evaluates to true. Instead, use if ( booleanvariable ).
  • Variable may have incorrect names. In one example, a variable called worldtoview actually contained the view-to-world transformation. If possible, check the application source code with what values a shader parameters is filled.
  • Shaders often do some pre-computation in the hosting application, for example to compute the camera position once for a geometry. If no appropriate semantic/annotation exists to get that value, one has to compute it in the vertex/pixel shader manually.
  • Shader Editor Docking Window
  • ​wikipedia: HLSL
  • ​MSDN: Programming Guide for HLSL
  • ​MSDN: Standard Annotations and Semantics
  • The GPU Gems series of books as well as the Shader X series of books
