Render Setup Editor
  1. Render Setup Editor
    2. User Interface
      1. Import and Export Render Setup
        1. Export
        2. Import
      2. Layout Mode
        1. Render Setup Elements
          1. Compositions
          2. Screens
          3. TUIO Touch Areas
        2. Measurement Tool
          1. Measurement Info Box
        3. Changing the Render Order
        4. Blending
        5. Composition Instancing
        6. Default Composition
      3. Mapping Mode
      4. Import Device Configuration
    3. Coordinate Space
      1. Selecting and Moving Elements
      2. Bezel and Overlap
      3. Output Types
        1. Single
        2. Grid
        3. Manual
      4. Cuts
        1. Properties
        2. Separation
        3. Split and Combine
      5. Machine ID
    6. TUIO Touch Area
      1. Examples and Scenarios
    7. Keyboard Shortcuts
  2. Warping and Soft-Edging
    2. The Ventuz Shaping Engine
      1. Performance Considerations
    3. The User Interface
      1. Navigation
      2. Global Toolbar
        1. Test Patterns
    4. Editing the Grid
      1. Selection
        1. Mirror Modes
      2. Editing
        1. Smart Mode
        2. UV Editor
      3. Summary
        1. Keyboard
        2. The Side-Toolbar
        3. Cursor Shape
      4. Zooming and Panning
      5. Handle Modes
      6. Insert Rows and Columns
    5. Manipulating Layers and Groups
      1. Subdivision
      2. Multiple Warp Groups
    6. Soft-Edges
      1. The gamma values
      2. Automatic Mode
      3. Manual Mode
    7. Per Output Settings
      1. Color Correction
      2. Quality Settings
    8. Per Group Settings
      2. UV Boundaries
      3. 3D projection
    9. Limitations
Configuring graphics cards to use AMD Eyefinity or Nvidia Mosaic is no longer needed to support multiple outputs from one graphics card. You can now assign all outputs individually or combine them using the Render Setup editor.
To open the Render Setup editor, open the Configuration Editor and open the Project Management tab, now select the Project this setup should be for. Create a new Render Setup by  clicking the button on the right side of the window.
It is possible to Import and Export existing Render Setups to and from Projects and to import from previous versions of Ventuz when using the Migration assist tool.
Export
To export a Render Setup, hover over the "Download" button and  click. Save the file in a desired folder on your hard drive.
Import
To Import an existing Render Setup file,  Click on "New...", in the pop-up select "Import Render Setup" and navigate to the location the desired Render Setup file is stored.
Layout Mode
Once the new Render Setup is created, the Render Setup window will automatically open in the Layout Mode. To edit an existing Render Setup  click on the Pencil Icon inside of the existing Render Setup.
Generally speaking this is the mode where you set the stage for you presentation, add screens and use compositions to set the frame for your rendering. To learn more about the handling of our new output system read this page.
1. Mode Change:
  • Change between the Layout and Mapping mode
2. Previs:
  • Select Previsualization Scenes currently available inside your .vzp Ventuz Project via the Pencil icon and import them, make sure you saved them recently after a upgrade to a higher version or you wont be able to see your scenes.
3. Close and Save:
  • Close: Closes the Render Setup Editor
  • Save: Saves the recent changes and applies them. This will also apply it to a running runtime which can interrupt the rendering!
  • Undo: Undo your changes, CTRL+Z also works.
  • Live: Click this Checkbox to see your changes in real time when the associated project is running in Ventuz Runtime.
4. Machine Selection:
  • Currently selected machine. Select the appropriate machine before going into the Editor.
5. Compositions:
  • Select and add Compositions inside the Tree View. Via its possible to add either Instances or new Compositions. A Double click lets you change the name, this is also possible inside the Properties Window (11) The Default Composition name cannot be changed. Deleting is done by and using the drop down menu. Here you can also change the Rendering Order of the compositions. If multiple Compositions are placed on the same output the render order may need to be changed to achieve your desired results. To accomplish this, simply  drag+drop to change it.
  • Add or delete TUIO Touch areas to define which parts of your setup should be interactive. Windows touch is not assignable through this area. Use the Multi capabilities and touch groups for Windows Touch that can be found inside of the Machine Configuration Window.
8. Contextual Controls:
  • Depending on the mode you are in these buttons offers the functions to add objects. Like you can by using the tree view or inside the view window.
9. Mode Selection:
  • The Render setup editor has different "editing" modes. To only edit Compositions use the button on the left. Right beside that is the Screens edit button and besides that you can find the Touch area edit mode. Or use the ALL button to be able to select everything either in a multi selection or one by one.
10. View Options:
  • Reset View
    • Reset the workspace view to 0.0.
  • Show Canvas
    • Shows the Canvas(es)
11. Property Editor:
  • Holds the properties of selected elements. Measurements can be in metric or imperial units.
12. Workspace:
  • Use  Drag to move elements around
  • Hold down the middle mouse button to pan the view
  • to open the context menu
  • Using the scroll wheel will zoom the view in and out
  • multiple times on the same spot will click through items so selecting the ones beneath is easier
13. Measurement Tool:
  • Enables the Measurement Tool, use this to measure distances between elements. Displayed in centimeters. on a edge or corner of a element and drag it over to a second point.
14. Import Compositions:
  • Import Composition layer from a scene. This way you dont have to replicate what you already did inside the Designer.
Compositions
1. Color
  • Changes the color of the Composition
2. Name
  • Changes the Name of the Composition. This is locked for Default Compositions
3.Fit to Screen
  • This is a unique feature for the Default Composition, when turned off the composition wont scale with screens moved inside it anymore
4. Dimension
  • Sets the Virtual Dimension for the Composition
5. Render Order
  • Changes the Rendering Order
6. Rotation
  • Displays the current rotation value of the selected element. This can be changed by dragging the property, directly typing in it or by using the dot in the upper right corner of the view port
7. Pixel Density
  • Sets the Pixel Density per cm/inch for the Composition
8. Physical Size
  • Sets the Physical size of the Composition
9. Diagonal
  • The Diagonal width of the Composition
10. Blend Mode
  • Sets the Blending mode for the Compositions. This only applies for stacked compositions
11. Blend Amount
  • The Amount of blending, lower values means less blending of the elements
12. Allow Scaling
  • Enables the Scaling function, only usable for instanced content
Screens
1. Color
  • Changes the color of the Screen
2. Name
  • Changes the Name of the Screen.
3. Resolution
  • Sets the Virtual Resolution of the Screen
4. Pixel Density
  • Sets the Pixel Density per cm/inch for the Screen
5. Physical Size
  • Sets the Physical size of the Screen
6. Diagonal
  • The Diagonal width of the Screen
7. Bezel
  • Activates the Bezel function for the selected screen/s
8. Allow Scaling
9. Render Filter
  • Use this to filter out specific content by choosing different Render Filter groups, only functioning in conjunction with the Render Filter node
10. Rotation
TUIO Touch Areas
1. Color
  • Changes the color of the Touch Area
2. Name
  • Changes the Name of the Touch Area
5. Physical Size
  • Sets the Physical size of the Touch Area
Measurement Tool
By using the measurement button in the lower right corner the user is able to measure distances between different elements in centimeters or inches. Clicking on the measurement button will toggle all measurements on and off.
Set a measurement:
on an edge or corner of an element and drag it over to a second point to create a measurement.
To adjust existing points, hold CTRL and  click&drag on a point to adjust.
Holding SHIFT while dragging a point, they will snap lines at 45° increments while drawing them.
All of the markers are sticky; they will stay attached to the same point on an object if you change the size, rotation or pixel density.
Deleting Measurements:
By on a existing measurement and hitting DEL will delete the measurement line. Alternatively you can also hold CTRL and  drag a point into empty space to delete it.
With the measurement info box it is possible to measure different objects with different DPI or Px/cm and the different pixel distances.
1: Info Box Button
  • Enables or disables the Info Box
2: Names
  • Names of the two objects connected by the selected measurement
3: Current Dots per inch / pixel per cm
  • Shows the pixel per centimeter of the corresponding object
4: Show button
  • Activate the show button and changes the label on the currently selected measurement.
5: Delete all measurements
  • Button to delete all measurements
When stacking Compositions on to each other it may be necessary to change their render order. To do that, simply  drag and drop the Composition to the desired place in the Tree view. As always in Ventuz, the Render order starts from the top down.
Blending
Solid: No blending is used
Alpha: Enables Alpha Blending
Add: Additive RGB blending
Instancing Compositions can be used to show the same content multiple times, in different positions or different resolutions. When "Allow Scaling" is enabled, Ventuz will render the scene elements one time and scale them to fit the corresponding Compositions. Scaling saves system resources. Ensure the aspect ratio is correct for these instanced Compositions; otherwise, your content might end up stretched or squished.
Default Composition
The Default Composition inside the Render Setup Editor behaves differently than other ones.
This Composition will automatically scale with screens that are inside this Composition. The Name of the Default Composition can't be changed.
In order to free screens of the automatic scaling inside the Default Composition uncheck the "Fit to Screen" property on the Default Composition or use the scaling handles of the composition and remove the Screen from it. Deleting the Default Composition inside the Render Setup Editor will not break anything inside the Designer. Still the Default Composition Layer will be present when another Composition layer is inserted but can be safely ignored.
Mapping Mode
With the Mapping mode it is possible to assign Screens to Outputs, add new machines, or shape and warp Outputs.
1. Mode Change:
  • Change between the Layout and Mapping Mode.
2. Previs:
  • Select Previsualization Scenes currently available inside your .vzp Ventuz Project and import them into the Render Setup.
3. Close and Save:
    • If the Render Setup that you're editing is active, clicking Save will apply it to a running Runtime. This can interrupt the rendering of each Runtime!
4. Mode Selection:
  • The Mapping mode has two different modes to show; All screens, or All Touch areas separately.
5. View Options:
  • Show Machines: Will highlight machine borders with a white dotted line.
  • Reset View: Resets the workspace view to 0.0
6. Add machines:
  • Adds another machine to the Output list. Here you can also setup things like the Machine ID how many outputs that machine has and so on.
7. Import Device Configuration:
  • This lets you import complete Device configurations currently available on the selected machine. Take a look into the Import Device Configuration section to learn more.
8. Shaping & Warping:
  • Select a screen to Warp and use this button to get into the Shaping&Warping editor.
9. Property Editor:
  • Holds the properties of selected elements. Measurements can be in Metric or Imperial.
10. Machine Options:
  • Use the Pencil to edit the currently used MachineID. Or use the bucket to delete the machine with its outputs. This will also use your current machine ID when creating the Render Setup.
11. Add Outputs:
  • Add outputs to the machine.
  • Single Screen: the output will only use one screen.
  • Grid: Allows to assign multiple screens to one output.
  • Manual: Adjust the output resolution and screen sizes manually.
  • Name: Here you can change the name of the current output. When imported from a device configuration this will have the name according to that configuration.
13. Output Workspace:
  • Shows the output in its chosen configuration. Selectable with the . Pan the view with the middle mouse button. And use the scroll wheel to zoom in and out. When set to manual and dropping a screen onto it you can hold SHIFT to tile the screen directly.
14. TUIO Touch inputs:
  • Add TUIO touch inputs to the output. It is possible to either use the Touch areas in the Layout mode or directly assign complete screens to a TUIO touch input.
15. Workspace:
  • Workspace shows the machine boarder as well as all configured Screens and Touch areas. These can be dragged and dropped on to outputs to configure them. Multi select is also possible.
16. Selected Machine/Group:
  • Shows the machine or cluster group that is currently selected.
17. Adding cuts:
  • When the output is put to Manual mode you can use this button to add cuts.
18. Reset of the view:
  • Resets the view to the center.
19. Maximize output:
  • Use this to maximizie one output to a bigger size, which makes working with a lot of smaller cuts alot easier. You can also double click the output to open and close it. Also navigating through the outputs is possible with the arrow buttons on the top when maximized.
20. Moving of outputs:
  • With this button you can move outputs to a different slot, but keep in mind that these outputs represent your physical GPU outputs! First output will also always be the top one in your Device configuration. And if these not match correctly the outputs will render incorrectly. We advice using the configuration import to minimize the risk of such issues.
After clicking on the Device Configuration Import button you will be greeted with this small helper pop up.
1: Device Configuration:
  • Choose a Configuration from the drop down menu. This will show all available Device Configurations.
2: Collapse all:
  • Collapse the whole tree,
3: Configuration Overview:
  • This shows an overview of the content inside the selected Device Configuration. The names of the outputs will be added to the outputs in the Mapping Mode.
4: Choosing a machine to import to:
  • Here you choose to which machine the outputs should be added. IDs are taken from the currently configured IDs inside the Machine Configuration.
5: Choose to overwrite or add:
  • Choose if you want to overwrite the current mapping or add (append) it to the existing ones.
For a Cluster Configuration Imports, only the currently active configurations from the machines inside that group can be used. Also note that you have to choose the correct group before opening a new Render Setup for that cluster!
Coordinate Space
Logical vs. Visual Resolution
The maximum visual resolution for a GPU currently is 16384 x 16384 pixels!
Manipulating a Render Setup
Elements can be selected by simply  click. Multi selection is possible by dragging a selection frame  drag around elements inside the All mode.
Moving is done by dragging and dropping, scaling can be done by the indicator on the Compositions. Selecting items in the tree view also changes the modes accordingly Rotations can be snapped to 10° or 5° using CTRL(10) or ALT(5)
Use the All mode to quickly move a bunch of elements Scaling only works for Compositions and TUIO Touch Areas, to resize screens use the Property Editor
Bezel and Overlap
To create an equal bezel or overlap between multiple elements, use the grid function when creating new screens. You can choose to add them using centimeter values or pixels.
It is also possible to do it like it was in Version 6 where all selected screens are properly aligned when the bezel was added. This only works when it matches the following requirements:
  • They're all selected
  • Have bezel on
  • Have the same rotation
  • Their bezels touch
Or you can pull them apart using the arrow's appearing when having selected more then one screen. This also comes with some limitations:
  • Pulling apart screens which already have different distances to each other will create odd behavior
  • Compositions wont scale with it unless you are using the Default Composition with fit to screen on.
Output Types
Single
Uses a single screen on the output. Assign a screen by  drag + drop from the left pane onto the desired output on the right.
Grid
Manual
It is possible to use the same screen multiple times by applying them to multiple times to the same output. Notice how the original size of the Screen set in the Layout cant be overwritten by this. You can also choose which portion should be rendered, change this by changing the screen position in the left view.
It is also possible to hold down the SHIFT key when dragging screens onto a output to tile it to the desired size automatically.
Cuts
In general as soon as one uses either the Grid or Manual mode the output will be cut into multiple pieces. Indicated by the label in the middle. For the Grid mode this will show 1.1 1.2 and so on depending on there position in the output. For Manual tiling it will simply count upwards.
M0 = Machine + ID
Properties
1:
  • Deletes the currently selected screen from inside the output
2:
  • Output label also shown on the screen itself inside the output mapping in the lower left corner
3:
  • Dropdown menu to change to different screens for the output
4:
  • Seperation groups
5:
  • Choose the rotation of the screen inside the output. This can be also done by using the handle in the upper right corner when clicking on a screen inside a output.
6:
  • Menu to enable different mirror modes for the output
7:
  • Enable or disable Warping&Shaping for the selected screen
8:
  • Screen Position: displays the current X and Y position of the screen cut outside of the output.
  • Screen Size: the current size of the selected screen. This can be independent from the actual output size which will be rendered.
  • Output Position: the current position of the screen inside of the output.
  • Output Size: actual used render size for the selected screen.
9:
  • Link Size: Links the output size directly to the screen size.
  • Link Aspect: Links the aspect of the cut to the screen.
  • Unlinked: Screen and outputs are handled individually. The output will be scaled accordingly.
Separation
Without separation groups:
With separation groups:
Split and Combine
With the split button you can easily tile a screen or split them to the desired count. Or split of a specific portion of the screen. This menu is available in the properties or by onto a screen.
Machine ID
TUIO Touch Area
Open the Mapping mode by  clicking on "Mapping" in the top left corner to assign those Screens to the outputs we want to use. The Composition in this case is defining the area which we want to render content, therefore we need to have screens to assign to the outputs.
As you can see on the left, Ventuz doesnt know about the second screen yet, which is indicated by the white dotted line (the machine boarder). To assign it, we need to add another output to the machine, we can also directly assign the screen to it by using the drop down menu inside the pop up window. Or  drag + drop screens from the left on to empty output slots on the right. If placing a screen on an output that has a screen already assigned to it, the existing screen will be replaced by the new one.
View
Middle mouse button+drag Pan
Middle mouse wheel Zoom
R Reset view
 double click Outputs Maximize / Restore view
Selection
 click Select
 click Context Menu
CTRL+A Select all elements depending on the selected mode
CTRL+ click+drag Disable snapping
SHIFT+ +drag Perpendicular measurements in 45° steps
Editing
 move Move selection
CTRL + C Copy selection
CTRL + V Paste
CTRL + Z Undo
CTRL + Y Redo
+ drag + CTRL Rotation 10° snapping
+ drag + ALT Rotation 5° snapping
CTRL+S Save changes
  • Shaping Editor
  • Cluster General
  • Cluster Setup HowTo
  • Screens
  • Multi Screen introduction
