The Ventuz Configuration Editor enables the configuration of a Ventuz system for production. The Configuration Editor allows for the administration of multiple configurations and easy switching between them. The Ventuz Configuration Editor can be found in the Windows Start menu, or in the Tools menu of Ventuz Designer.
The editor is capable of configuring and controlling remote systems utilizing the Ventuz Machine Service. An installed, started, and accessible VMS is mandatory to configure all systems. The Ventuz Configuration is Project independent and configures all settings related to the Ventuz system. Most of the settings are hardware related but it also contains rendering, network and identification settings.
The Ventuz Configuration Editor consists of several sections:
Section 1: Information: In this section all information regarding the Status of the machine or group of machines selected is displayed. Using the License Manager, details are displayed and licenses can be edited for each machine.
Section 2: Configuration: All configurations of the machine or group of machines are set here. With the General Configuration, Machine Configuration and the Device Configuration the machine, or the remote machine(s), can be configured. With Ventuz 7 the Render Setup has moved to the Project Management.
Section 3: Management: Start or stop any Ventuz Presentation or start a Project in the Project Management or select and edit a Render Setup. With the Show Management all Director shows can be overviewed and launched as well.
Section 4: Live Control With a running Ventuz Runtime this section will not be greyed out and live changes to the runtime can be made. Changes can be made ine the Scene in the Sceneport with the Scene Control or check the Live Options to enable the Performance Statistics or change setting on the fly.
With Ventuz 7 the Web Browser based Configuration Editor has the same functionality as the standalone application. It is not necessary to have Ventuz locally installed and it is also possible to use a tablet or a phone as device.
The address is as following:
| IP - Address | Via the Web Browser you can access the Configuration Editor directly with entering the IP of the Ventuz machine and |
| 21404 | the Port to access V7 Configuration Editor |
| localhost:21404 | Open the Configuration Editor via your local VMS on your machine |
| 192.168.4.25:21404 | sample address for the Web Configuration Editor on another machine |
Due to the vast number of web browser and versions of those, we can not provide guaranteed support for all versions and all features. You might test your web browser device for full support.
We do not recommend to use Microsoft Edge Browser while Runtime is rendering due to performance issues on the GPU
| OK | Ventuz is connected and running |
| INIT | Ventuz is connected and running, though no project is loaded yet |
| OFFLINE | Ventuz is not connected |
| TIMEOUT | No VMS discovery message received |
| Ready | waiting for input signal, ready to go |
| Presync, Syncing | stabilizing stream, synchronizing multiple streams together |
| Running | stream is running normally |
| Disabled | disabled either by the Live Video Node or by the software watchdog. |
| Bypass | bypass relays activated |
| Error | some error condition, see log for details. |
| Name | Bits Per Pixel | Comment |
| YUV422 10 bit | 21.3 | best quality |
| YUV422 8 bit | 16 | best speed |
| YUVK4224 10 bit | 32 | best quality with alpha |
| YUVK4224 8 bit | 24 | best speed with alpha |
| RGBA 8 bit | 32 | used as quality option when YUVK4224 10 bit is not available |
| RGB 8 bit | 24 | used for some webcams (windows media foundation devices) |
| YUV422 8 bit with separate alpha | 24 | used for iVGA, same quality and speed as YUVK4224 8 bit |
| Input -> Ventuz | The delay from input to the Ventuz renderer |
| Ventuz -> Output | The delay from the Ventuz renderer to output |
| Input -> Output | The delay from the input and the output |
The status page gives you detailed information about the current state of your selected machine(s).
This includes:
With the Snapshot button in the bottom right corner, a snapshot of the current Ventuz Runtime rendering will be displayed and is also downloadable.
If a Group is selected in the Machine Selection tab, this window will display the information overview of each machine in parallel.
The Logs Quick access provides all the different application Logs. By pressing the Log button you can download the log file. They are also saved in the Ventuz configurations folder next to the Configuration Files on your harddrive.
In the License section the system Ventuz license can be added, updated or unregistered.
This License Manager in the Configuration Editor has the some functionality as the standalone application installed with Ventuz.
With the Copy button all license information are copied to the clipboard.
Sometimes it might be necessary to press Update to reach out to the Ventuz License server to verificate your license after a change.
When you are running your license for the first time or if your dongle does not contain any license keys, you must click on Enter License, and a new screen will appear (see below). The same goes with system and TPM licenses. You should fill in this form with your Licensee User, Company and Contact E-Mail information, and with the License Key information provided on your License Certificate.
If you try to run Ventuz Designer, Director or Runtime and are presented with the Ventuz License Manager with red text in the license panel this is an indication that your Maintenance period has expired and the version of Ventuz that you have installed is too new. In such a case please contact your Ventuz reseller or sales@ventuz.com. Highest available version under Maintenance indicates which is the most recent version of Ventuz that will run with your current license. You can download older versions here: https://www.ventuz.com/archive
The General configuration tab contains information about the Ventuz Machine.
It defines the Machine Name of the machine as well its numeric ID and GroupID.
The ID determines which machine will be Master and which Client(s) in a Machine Cluster. The lowest ID will be set as Cluster Clock Master. The ID is also used to select the correct part to be rendered in the multi-machine Render Setup. With the Live Options, the ID can be changed while the runtime is active.
The GroupID must be set to a value greater than zero if a machine is part of a Cluster (group). Only machines with a GroupID can interchange their timing (cluster clock) to synchronize Remoting, animation and movie playback. For proper synchronization a valid Cluster Option is required.
The Tag is used by the Runtime to determine the Layout Scene that is to be used.
The Machine Configuration and Device Configuration files are selectable and editable in the Configuration Editor.
New creates a new configuration file. It is possible to upload a file from the hard-disk, also a duplication of an existing configuration file can be done in the creation dialog. With Activate the selected configuration is activated and will be applied, also while the runtime is running.
With pressing the Cogwheel Icon the selected configuration will be opened in the editor. If you want to edit the configuration directly without the interface, you can edit the JSON file via the UI, by pressing the Paper Icon. With the Pencil Icon an existing, not activated, configuration can be renamed. With the next button the configuration file is saved to hard-disk. The Red Bin Icon deletes the configuration.
All Ventuz configuration files are stored in the system's public documents folder in the Ventuz7\Configuration directory. On most systems this path is:
C:\Users\Public\Documents\Ventuz7\Configuration\
Except the Render Setup files are stored within the Content\Project\!RenderSetups folder structure within the Project.
If you upload your configuration file to a remote machine with creating a new configuration it will be saved at the remote machine locally in the same folder structure.
In the Ventuz configuration folder multiple files and folders are stored.
All Ventuz configuration files are human-readable and can be opened with a text editor.
| .vcfg | Ventuz Config | This file contains the Ventuz Config consisting of Machine Configuration, Device Configuration, Render Setups |
| .vdev | Device Configuration | The Device Configuration contains the configuration of IO devices. |
| .vmc | Machine Configuration | This file is project independent that handles and configures all settings related to the Ventuz system |
| .vren | Render Setups | This file contains the Render Setup created in the Render Setup Editor. |
| .vnetcfg | Network Configuration | This file contains the port numbers to be used for the Ventuz network protocols. |
If a Group / Cluster is selected the General Configuration section shows an overview of the machines configuration.
It is possible to see the activated configurations and Render Setups for each machine and the VMS status for each machine. The machines can be sorted by each category. With the arrow at the end of each machine line, the Configuration Editor will switch to this machine for editing configurations.
The red marked bar indicates that status or the configurations of both machines is not according to each other. In this case the runtime of the first machine is not running.
