Severe Limitations:
Limited Use:
  2. Building a Display Wall
  3. Creating a Render Setup
    1. Layout
    2. Mapping
  4. Working with Render Setups in Ventuz Designer
    1. Render Setup Modes
      1. Layer Effects
      2. Multitouch and Interaction
      3. Math Effects
  5. Setting up the Hardware
    1. Cluster Clock and Cluster ID
    2. Remoting
    3. Network multicast cluster setup
      1. Multicast messaging with multiple network interface cards
  6. Synchronization Hardware
    1. Setup
      1. Enable Swap Sync
      2. Our experiences with AMD Boards
      3. Our experiences with Nvidia Boards
  7. Check List
  8. Limitations
    1. Multi Touch and Interaction
    2. Layer Effects
This can be achieved easily by Uploading a Ventuz Presentation using the dialogue in the Project Management tab.  Click Upload in the top right corner and upload the appropriate VPR file.
While it is possible to configure the graphics driver to treat multiple outputs as one logical output, it is not necessary in Ventuz Version 7.
NVIDIA calls this ​Mosaic technology, AMD calls it ​Eyefinity. If this kind of setup is desired, configure the graphics card settings directly on the machines that need it using the appropriate graphics card software. These settings cannot be changed by Ventuz.
After the physical outputs have been configured, inside of the graphic card's software.  Click on the Presentation File (VPR) that was uploaded in the first step of this section. In the panel on the right,  click + New.... Choose a name and click OK. In this example, "ClusterSetup" is used. Clicking OK will automatically open the Render Setup Editor.
Layout
In the left menu, select Default Screen and then  click Delete Selected Screen(s). This screen is not needed for this setup.
Mapping
Delete the first Machine.  Click on the Red Garbage Can. This will help in utilizing the built in Wizard to create and assign Screens to Outputs.
In the bottom drop-down menu, select the first screen in the setup: Rhombus_1_1  Click Add.
Render Setup Modes
  • Canvas Preview: This is a simulation of the whole Cluster with any number of machines and displays. Areas which will not be visible on the physical wall can be masked with a customizable color and alpha value. These values can be set in the Global Video Configuration or in the Live Options if Ventuz is already running.
  • Output Preview: This mode allows the preview of each physical output of each machine that is in, or will be in the setup. Each machine can be selected by  clicking on the numbers at the top of the Stage Editor. Each number selects displays the machine with that ID.
  • Screen Preview: This mode displays what each screen is assigned.
  • Design Preview: This preview mode is a shows the Ventuz Designer preview. Areas that aren't visible on a physical screen will be masked.
To get an aspect-correct rendering make sure that Format settings in the Project Properties match the aspect of the whole Cluster. The Stage Editor provides a shortcut to adapt the Format to the active Cluster configuration: click on the cross in the toolbar on top.
Layer EffectsMGPU: , Cluster:
Multitouch and InteractionMGPU: , Cluster:
  • The BehaviorApply property on all Touch Transformation nodes has to be disabled. If this option is enabled, a physical simulation (like Inertia) is calculated within the nodes and applied to the transformed geometry; This simulation is not synchronized over all machines within a Cluster and will result in different values per machine and can produce different undesired render results.
  • In the Project Settings in the Interaction category Smoothing Weight and Interpolation Delay must be set to 0.0! Because touch data packets may not arrive simultaneously from the packet's source, smoothing and interpolation will create issues because the processing is based on time difference of received packets.
  • The Cluster must be symmetrical. This means that every machine in the Cluster must have the same resolution. E.g. 4x3 displays should be fed by 3 machines with a 4x1 screen setup. A screen setup like 2x2 + 2x2 + 4x1 is not recommended as the touch calculations are dependent on the resolution of the renderer. Different resolutions can lead to (slightly) different touch transformation results.
  • A Master-Client setup should be preferred over an All-Single setup for the Cluster touch network settings (see Cluster Interaction Settings). In the Master-Client setup the interaction inputs are only received by the Master machine and distributed to the Clients through a Ventuz-internal protocol.
  • Every Web Browser node renders the whole web page even if most parts of the page are not visible on a machine.
  • Browser page size is currently limited to 4096 x 4096 pixel. Thus a Cluster with a higher resolution will display a scaled up web page.
  • Loading and presenting the web content is not synchronized over the machines as the content is rendered discreetly in each browser (client).
Math Effects
  • All machines have identical hardware.
  • The same scene on all machines is bing used (use the SystemID node to apply machine specific settings)
  • The scene is running properly with the maximum frame-rate.
  • Identical project and graphics card settings are used (a different anti-aliasing setting will bring the clock out of sync).
  • Disable Bezel or Overlap settings in the graphics card as this feature is achieved by the Render Setup rendering in Ventuz.
  • All machines are connected to the same network.
Cluster ID 01.02 means that this machine has the Group-ID 01 and the Machine-ID 02, the following number shows the current value of the cluster clock, and the clock from 01.01 indicates that the current clock master has Machine-ID 01. On a client system, the type of the cluster clock is colored green, on a master system it is white.
route  change 224.0.0.0 mask 240.0.0.0 <IP of network card here> metric 25
Setup
Enable Swap Sync
  • AMD suggests to boot the timing master first, then the clients in the order they are connected to the master. This way the timing signal is present when the client comes to live. Shut down vice versa.
  • AMD boards loose their configuration almost every time they loose the timing signal. AMD's recomendation is to ensure the have boards configured correctly using presets in the Catalyst Control Center and load these after every startup. This can be found in in the Catalyst Control Center help.
  • For stable results, Nvidia suggests to boot the clients first, then the master.
  • Nvidia boards remember their configuration, even if they loose the timing signal, which makes reconnecting easy.
  • For Swap Sync to work properly, only one logical display can be connected to the Nvidia GPU.
    • Mosaic mode provides only one logical display, so this works fine.
    • All monitors connected to additional Nvidia GPU's must be part of the mosaic.
    • It is OK to have an additional Nvidia GPU with no monitors connected
    • It is OK to have an additional Amd / Intel GPU with monitors connected (which is very helpful for debugging)
  • If one machine stalls for a longer period of time (>~5s), the other machines in the cluster will have an issue. The graphics driver will stall and causes a Windows timeout restarting the graphics driver and crashing Ventuz. ​Timeout Detection & Recovery. This may be avoided by the following Registry Key entry.
        // disable Timeout Detection & Recovery
        KeyPath   : HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\GraphicsDrivers
        KeyValue  : TdrLevel
        ValueType : REG_DWORD
        ValueData : 0
Check List
  • All machines have exactly the same display driver version.
  • An appropriate group ID (>0) and machine ID has been assigned to each machine.
  • If the way displays are connected has changed, reboot all systems.
  • If a firewall is used, make sure it does not block the cluster clock address/port (225.225.225.1:19300)
  • Do not use consumer grade graphics cards. They cause problems are difficult to diagnose.
  • Run the presentation in Ventuz Presenter, not in Ventuz Designer.
  • The presentation must run in a fullscreen output mode See: Video Device Configuration.
  • The cluster clock values in the Performance Statistics are rendered in green and do not flicker to gray (without Genlock/Framelock it is, in general, not possible to avoid this).
  • Ensure the framelock settings in the graphics card driver are correct before starting Ventuz.
  • If Swap Sync should be used this must be enabled in the Device Config of ALL machines!
  • When running in Ventuz Designer is unavoidable (which is advised against), make sure the FPS in the Device Configuration is set consistently. Otherwise animations will run at different speeds.
  • As a primary test for a correct setup run the 'Default.vpr' (build-in presentation) on the Cluster. If this very simple scene does not run synchronously, the cluster setup is incorrect. Ensure that the conditions above are fulfilled!
  • the final scene should run smoothly with full framerate on each machine (without cluster synchronization). Many (long) frame-drops disrupt the Cluster synchronization!
Limitations
Layer Effects
Effect Cluster Compatibility
Grayscale
Color Grading
Color Correction
Gain
Posterize RGB
Posterize HSV
Color Difference
RGB Noise
Delay
all Masks
works in cluster without problems
Mosaic
Blur
Glare
Dropshadow
Edge Detection
Lens Distortion
Distortion
RGB Distortion
2D Displacement
Noise Distortion
works with Effect Bleed only
Feedback often fails in cluster with an Effect Bleed - depending on parameters
Crashzoom
Polar Distortion
Kaleidoscope Distortion
does not work with an Effect Bleed
  • Shaping Editor
