Web BrowserMGPU: , Cluster:
Severe Limitations:
Limited Use:
  1. Usage and Interaction
  2. Input
    1. Multitouch ´
    2. Mouse
  3. Browser Functionality
    1. Browser Cache
  4. Progress and Status
    1. Content
    2. Cursor
  5. JavaScript
    1. Methods/Events
    2. Execute On Load
    3. Transparent Background
  6. Limitations
The Web Browser node renders web pages into a texture so their content can be used inside a Ventuz scene. Since Ventuz 5.3 this is done based on the ​Chromium Embedded Framework CEF.
Input
Multitouch ´
​Chromium Embedded Framework CEF can handle maximum 16 inputs per browser.
Mouse
Code Description
13 Return
9 Tab
8 Backspace
127 Delete
27 Escape
The unicode values for the most commonly used characters can be found ​here and ​here. Additional information on other character sets can be found ​here.
  • Load: Load the URL/HTML specified in the NavigationURL or NavigationHTML respectively.
  • Reload: Reloads the current content (same as pressing F5/Refresh in a dedicated browser application).
  • Stop: Stops/interrupt the current loading process.
  • Forward: Go one page forward in the navigation history.
  • Backward: Go page backward in the navigation history.
Browser Cache
%TMP%\Ventuz
Progress and Status
Content
  • CurrentURL: The URL of the currently displayed HTML page.
  • TargetURL: If the cursor hovers over a link, this provides the URL the link leads to.
  • Title: The title of the currently displayed HTML page.
  • Tooltip: If the content contains a tooltip for the current position of the cursor, it will be provided in this property.
Cursor
0 Pointer (default)
1 Cross 2 Hand 3 Ibeam 4 Wait
41 Custom
JavaScript
The Web Browser node supports the ​JavaScript scripting language both as part of the content as well as a means of interaction between Ventuz and the site content. This is done by defining input/output properties, methods and events in the Custom Model editor at the bottom of the Property Editor.
Methods/Events
<html>
<head>
<title>Method Test</title>
</head>
<body>
function CalculateSquare() {
  var result = ventuz.value * ventuz.value;
  document.write("The square of " + ventuz.value + " is " + result + "<br>");
  ventuz.Result(result);
</script>
</body>
</html>
Execute On Load
The property WebBrowserJavaScript can optionally contain a ​JavaScript snippet that is injected and executed on every loaded page. This opens many possibilities to operate on external pages.
Example 1:
Example 2:
Creates two methods called UP and DW in the Custom Model to invoke the defined JS functions. The displayed window will scroll up/down when Ventuz invokes these methods. (See also function ​scrollBy())
Limitations
  • The Web Browser node is only working on the first (primary) GPU usually marked as 0:0 when enabling the Performance Statistics
  • The maximum resolution of the web browser is 16384 x 16384 pixels, going over 8K resolution isn't recommended though.
  • A touch is immediately claimed by the Web Browser, so a combination of Touch Translation node with the Web Browser node is not possible.
  • User login prompts and other popup windows are not supported.
  • Multi Touch
  • Ventuz Input Subsystem
  • ​JavaScript
