Ventuz Stream Out API
  1. Connecting to Ventuz
  2. Chunks and the Pipe Header
    1. Chunk header
    2. Pipe header chunk ('VVSP', 0x56565350)
  3. Retrieving video and audio
    1. Frame header chunk ('fhdr', 0x66686472)
    2. Audio and video chunks
      1. Video chunk ('fvid', 0x66766964)
      2. Audio chunk ('faud', 0x66617564)
  4. Sending commands
    1. Request IDR frame command
    2. Touch commands
    3. Key commands
    4. Mouse commands
      1. Mouse position
      2. Mouse buttons
      3. Mouse wheel
    5. Set encode parameters command
  5. C# example code
The Encoded Stream Out outputs provide a simple pipe based streaming protocol to other processes running on the same machine. This way 3rd party applications can process or distribute the video coming out of Ventuz in real time.
There is a comprehensive example, client library and test application, written in C#, on GitHub here: ​https://github.com/VentuzTechnology/StreamOutExample
Ventuz makes the encoded streams available to other processes via a ​named pipe. These processes will need the proper permissions to access the pipe (usually this means running as the same user or at a higher privilege level than the Ventuz runtime).
The pipe's name is VentuzOutA for the first output and B etc. for any additional outputs. Ventuz accepts an arbitrary number of connections to the named pipes, so for example a stream server can choose whether to handle multiple incoming connections itself or to connect to the pipe once per client served.
Chunk header
offset type description
+00 FourCC Chunk type
+04 uint32 Chunk size in bytes
  • Unknown chunk types should be ignored, i.e. skipped
  • If the size in the chunk header is bigger than expected, clients should consume as many bytes as expected and skip the rest. This way structures can be appended to without losing backwards compatiblity.
  • If the size in the chunk header is smaller than expected, clients should treat it as error and disconnect from the pipe
+00 uint32 Protocol version
+04 FourCC Video format
+08 uint32 Video width (pixels)
+12 uint32 Video height (pixels)
+16 uint32 Video frame rate numerator
+20 uint32 Video frame rate denominator
+24 FourCC Audio format
+28 uint32 Audio sample rate (Hz)
+32 uint32 Audio channel count
Notes:
  • The current protocol version is 2, please disconnect from the pipe if the version field is anything else than that.
  • Currently h.264 and HEVC video are supported, video formats are 'h264' (0x68323634) and 'hevc' (0x68657663) respectively
  • Audio is currently always signed 16 bit little endian stereo interleaved PCM at 48KHz, the audio format is 'pc16' (0x70633136)
  • The video and audio format is guaranteed to not change during a session. If the format should change, eg. because of a configuration change, the pipe will be closed and clients will have to reconnect.
+00 uint32 Frame index
+04 uint32 Frame flags
value description
0x00000001 This video frame is an IDR frame
This chunk contains exactly one frame worth of encoded video. If the IDR frame flag is set in the frame header it's guaranteed that this frame contains everything that's needed to start or restart a video stream, i.e. Sequence and Picture information, and no reference to past frames.
Sending commands
byte followed by description
0x00 - No operation
0x01 - Request IDR frame
0x10 Touch parameters Begin Touch
0x11 Touch parameters Move Touch
0x12 Touch parameters End Touch
0x13 Touch parameters Cancel Touch
0x20 Unicode character (uint32) Key Pressed
0x21 VirtualKey code (uint32) Key Down
0x22 VirtualKey code (uint32) Key Up
0x28 Mouse XY parameters Mouse position
0x29 Mouse Button parameters Mouse buttons
0x2a Mouse XY parameters Mouse wheel
0x30 Encode parameters Set encode parameters
This command instructs the encoder inside Ventuz to emit an IDR frame. Due to the asynchronous nature of the encoding process this may take a frame or two; don't assume the frame received right after sending this command will already be an IDR one.
Touch commands
+00 uint32 Touch ID
+04 int32 X coordinate (pixels from left side of viewport)
+08 int32 Y coordinate (pixels from upper side of viewport)
Key commands
Clients can inject text characters with the Key Pressed command followed by this structure:
+00 uint32 UTF32 codepoint
Control keys that correspond to control characters such as Backspace or Enter will also work. This command only works with nodes that accept text input, i.e. Text Fields and Web Browsers.
Alternatively, clients can use the Key Up and Key Down events that supply a Windows VirtualKey as described in ​https://learn.microsoft.com/en-us/windows/win32/inputdev/virtual-key-codes
+00 uint32 VirtualKey code
Note that this command doesn't work in conjunction with the DirectInput Key node.
Mouse commands
Injecting mouse updates works with these three messages:
Mouse position
A mouse position update has the following parameters:
+00 int32 X coordinate (pixels from left side of viewport)
+04 int32 Y coordinate (pixels from upper side of viewport)
Any X or Y values outside the viewport (such as negative values) will also be treated as the mouse leaving the window or output.
Mouse buttons
A mouse button update updates all buttons at once. The message payload looks like this:
+00 uint32 Buttons bitfield
The buttons bitfield is the logical addition of all currently pressed buttons.
bit value description
0 0x01 Left
1 0x02 Right
2 0x04 Middle
3 0x08 X1
4 0x10 X2
Mouse wheel
Mouse wheel messages have the following payload:
+00 int32 Reserved (set to zero)
+04 int32 Wheel delta
The wheel delta follows Windows conventions, i.E. usually positive and negative 120 units per click.
Note that the mouse commands doen't work in conjunction with the DirectInput Mouse node.
+00 uint32 Rate control mode
+04 uint32 Bitrate or QP
value description
0x00000000 Encode with constant QP (Second field specifies QP (0..51))
0x00000001 Encode with constant bitrate (Second field specifies bitrate in kbits/s)
C# example code
using System;
using System.IO;
using System.IO.Pipes;
using System.Runtime.InteropServices;
/// <summary>
/// Copyright (C) Ventuz 2020-2024. All rights reserved.
/// Example for reading from the Ventuz StreamOut pipe.
/// Opens the pipe and dumps the audio and video streams into files.
/// Changelog
/// 2024-07-23 [TH] Added mouse messages
/// 2019-08-29 [TH] Initial public version
/// </summary>
namespace StreamOutPipeExample
    // The data coming from the pipe is organized in chunks. every chunk starts with this, followed by the chunk data
    [StructLayout(LayoutKind.Sequential)]
    public struct ChunkHeader
        public uint fourCC;            // chunk type (four character code)
        public int size;               // size of chunk data
    // Pipe header with general information (VVSP chunk)
    public struct PipeHeader
        public static readonly int VERSION = 2;
        public uint hdrVersion;         // should be VERSION
        public uint videoCodecFourCC;   // used video codec, currently 'h264' aka h.264
        public uint videoWidth;         // width of image
        public uint videoHeight;        // height of image
        public uint videoFrameRateNum;  // frame rate numerator
        public uint videoFrameRateDen;  // frame rate denominator
        public uint audioCodecFourCC;   // used audio codec, currently 'pc16' aka 16 bit signed little endian PCM
        public uint audioRate;          // audio sample rate, currently fixed at 48000
        public uint audioChannels;      // audio channel count, currently 2
    // Frame header, gets sent every frame, followed by video and then audio data (fhdr chunk)
    public struct FrameHeader
        [Flags]
        public enum FrameFlags : uint
            IDR_FRAME = 0x01,           // frame is IDR frame (aka key frame / stream restart/sync point)
        public uint frameIndex;         // frame index. If this isn't perfectly contiguous there was a frame drop in Ventuz
        public FrameFlags flags;        // flags, see above
    // Commands to send back to the encoder.
    enum PipeCommand : byte
        Nop = 0x00,             // Do nothing
        RequestIDRFrame = 0x01, // Request an IDR frame. it may take a couple of frames until the IDR frame arrives due to latency reasons.
        TouchBegin = 0x10,      // Start a touch. Must be followed by a TouchPara structure
        TouchMove = 0x11,       // Move a touch. Must be followed by a TouchPara structure
        TouchEnd = 0x12,        // Release a touch. Must be followed by a TouchPara structure
        TouchCancel = 0x13,     // Cancal a touch if possible. Must be followed by a TouchPara structure
        Char = 0x20,            // Send a keystroke. Must be followed by a KeyPara structure
        KeyDown = 0x21,         // Send a key down event. Must be followed by a KeyPara structure
        KeyUp = 0x22,           // Send a key up event. Must be followed by a KeyPara structure
        MouseMove = 0x28,       // Mouse positon update. Must be followed by a MouseXYPara structure
        MouseButtons = 0x29,    // Mouse buttons update. Must be followed by a MouseButtonsPara structure
        MouseWheel = 0x2a,      // Mouse wheel update. Must be followed by a MouseXYPara structure
                                // NOTE: Currently only the Y value of the wheel is supported
        SetEncodePara = 0x30,   // Send encoder parameters. Must be followed by an EncodePara structure
    // Parameters for Touch* PipeCommands
    public struct TouchPara
        public uint id;   // numerical id. Must be unique per touch (eg. finger # or something incremental)
        public int x;     // x coordinate in pixels from the left side of the viewport
        public int y;     // y coordinate in pixels from the upper side of the viewport
    // Parameters for the Key PipeCommand
    public struct KeyPara
        public uint Code;   // UTF32 codepoint for Char command; Windows VK_* for KeyUp/KeyDown
    // Parameters for the MouseMove and MouseWheel PipeCommands
    public struct MouseXYPara
        public int x;     // x coordinate in pixels from the left side of the viewport, or horizontal wheel delta
        public int y;     // y coordinate in pixels from the upper side of the viewport, or vertical wheel delta
    // Mouse buttons bitfield
    [Flags]
    public enum MouseButtons : uint
        Left   = 0x01,
        Right  = 0x02,
        Middle = 0x04,
        X1     = 0x08,
        X2     = 0x10,
    // Parameters for the MouseButtons PipeCommand
    public struct MouseButtonsPara
        public MouseButtons Buttons; // bit field of all buttons pressed at the time
    // Parameters for the SetEncodePara PipeCommand
    public struct EncodePara
        public enum RateControlMode : uint
            ConstQP = 0,  // BitrateOrQP is QP (0..51)
            ConstRate = 1, // BitrateOrQP is rate in kBits/s
        public RateControlMode Mode;
        public uint BitrateOrQP;
    class Program
        // The following helper functions are only meant as a reference.
        // In a full implementation these should be asynchronous or
        // at least have some kind of timeout/error handling.
        /// <summary>
        /// Read a number of bytes from a stream and return as array
        /// </summary>
        public static byte[] ReadBytes(Stream stream, int length)
            var bytes = new byte[length];
            int done = 0;
            while (done < length)
                int read = stream.Read(bytes, done, length-done);
                if (read == 0) throw new IOException("stream ended");
                done += read;
            return bytes;
        /// <summary>
        /// Read a struct from a stream by just blitting the data
        /// </summary>
        public static T ReadStruct<T>(Stream stream, int size = 0)
            var tsize = Marshal.SizeOf(typeof(T));
            if (size <= 0) size = tsize;
            if (size < tsize) throw new ArgumentException("size is too small");
            var bytes = ReadBytes(stream, size);
            GCHandle handle = GCHandle.Alloc(bytes, GCHandleType.Pinned);
            T theStructure = (T)Marshal.PtrToStructure(handle.AddrOfPinnedObject(), typeof(T));
            handle.Free();
            return theStructure;
        /// <summary>
        /// Send a command to the pipe
        /// </summary>
        /// <param name="cmd"></param>
        /// <returns></returns>
        public static void SendCommand(Stream stream, PipeCommand cmd)
            var bytes = new byte[] { (byte)cmd };
            stream.Write(bytes, 0, 1);
        /// <summary>
        /// Send a command to the pipe, with data struct
        /// </summary>
        public static void SendCommand<T>(Stream stream, PipeCommand cmd, T para)
            int size = Marshal.SizeOf(para);
            byte[] arr = new byte[size+1];
            arr[0] = (byte)cmd;
            var h = GCHandle.Alloc(arr, GCHandleType.Pinned);
            Marshal.StructureToPtr(para, h.AddrOfPinnedObject()+1, false);
            h.Free();
            stream.Write(arr, 0, arr.Length);
        /// <summary>
        /// Make uint FourCC from four characters
        /// </summary>
        public static uint FourCC(char a, char b, char c, char d) => ((uint)a << 24) | ((uint)b << 16) | ((uint)c << 8) | ((uint)d);
        /// <summary>
        /// Entry point here
        /// </summary>
        static void Main(string[] args)
            Console.WriteLine("Ventuz video stream pipe receiver example\n");
            // The pipe name is "VentuzOutA" (or B etc for additional outputs), local only.
            // You can connect to the pipe as many times as you wish (eg. once per client you serve),
            // or you can connect once and handle distribution yourself.
            using (var stream = new NamedPipeClientStream("VentuzOutA"))
                Console.WriteLine("Connecting...\n");
                // connect to the pipe
                stream.Connect();
                // try to get first chunk
                var chunk = ReadStruct<ChunkHeader>(stream);
                if (chunk.fourCC != FourCC('V', 'V', 'S', 'P'))
                    throw new Exception("invalid header from pipe");
                // get header
                var header = ReadStruct<PipeHeader>(stream, chunk.size);
                if (header.hdrVersion != PipeHeader.VERSION)
                    throw new Exception("wrong protocol version");
                // check codecs
                // let's only accept h.264 here, but it works the same with HEVC
                if (header.videoCodecFourCC != FourCC('h', '2', '6', '4') || header.audioCodecFourCC != FourCC('p', 'c', '1', '6'))
                    throw new Exception("unsupported video or audio codec");
                Console.WriteLine($"video: {header.videoWidth}x{header.videoHeight} @ {(float)header.videoFrameRateNum / header.videoFrameRateDen}fps");
                Console.WriteLine($"audio: {header.audioChannels}ch @ {header.audioRate}Hz");
                Console.WriteLine("Press ESC to quit.\n");
                // video should always start with a full IDR frame (key frame with decoder reset,
                // contains metadata such as picture and sequence information). Let's check if this is true.
                bool expectIDRFrame = true;
                float bytespersec = 0;
                // let's open some files to dump the streams into. You can open the .264 file with
                // VLC or Media Player Classic, or mux video and audio using FFMpeg.
                FileStream videoFile = null;
                FileStream audioFile = null;
                try
                    var temppath = Path.GetTempPath();
                    videoFile = File.Create(temppath + "test.264");
                    audioFile = File.Create(temppath + "test.pcm");
                catch (Exception ex)
                    Console.WriteLine($"ERROR: Can't create output file(s): {ex.Message}\n");
                // now let's receive some stuff! Forever!
                bool quit = false;
                while (!quit)
                    while (Console.KeyAvailable)
                        var rk = Console.ReadKey();
                        var key = rk.Key;
                        // On second thought, quit if esc is pressed.
                        if ( key == ConsoleKey.Escape )
                            quit = true;
                            break;
                        else if (key == ConsoleKey.Spacebar)
                            // If the space bar is pressed, request an IDR frame
                            // (not setting expectIDRFrame here; it might take a frame or two until the IDR frame arrives)
                            SendCommand(stream, PipeCommand.RequestIDRFrame);
                        else if (key == ConsoleKey.F1)
                            // simulate a singular touch
                            var para = new TouchPara
                                id = 12345,
                                x = 100,
                                y = 100,
                            SendCommand(stream, PipeCommand.TouchBegin, para);
                            SendCommand(stream, PipeCommand.TouchEnd, para);
                        else if (rk.KeyChar >= '1' && rk.KeyChar <= '9')
                            // numeric keys: switch encoder bitrate to 1 mbit per key :)
                            SendCommand(stream, PipeCommand.SetEncodePara, new EncodePara
                                Mode = EncodePara.RateControlMode.ConstRate,
                                BitrateOrQP = ((uint)rk.KeyChar - '0') * 1000,
                        else
                            // forward all other keys to Ventuz
                            SendCommand(stream, PipeCommand.Char, new KeyPara
                                Code = rk.KeyChar
                    try
                        // frame header first
                        if (chunk.fourCC != FourCC('f', 'h', 'd', 'r'))
                            // skip unknown chunks
                            var _ = ReadBytes(stream, chunk.size);
                            continue;
                        var frameheader = ReadStruct<FrameHeader>(stream, chunk.size);
                        if (expectIDRFrame)
                            if (!frameheader.flags.HasFlag(FrameHeader.FrameFlags.IDR_FRAME))
                                throw new Exception("IDR frame expected");
                            expectIDRFrame = false;
                        // read video data
                        if (chunk.fourCC != FourCC('f', 'v', 'i', 'd'))
                            throw new Exception("video frame expected");
                        byte[] videoFrame = ReadBytes(stream, chunk.size);
                        // read audio data
                        if (chunk.fourCC != FourCC('f', 'a', 'u', 'd'))
                            throw new Exception("audio frame expected");
                        byte[] audioFrame = ReadBytes(stream, chunk.size);
                        // calc video bitrate (exponential moving average over packet size times frame rate)
                        bytespersec += 0.1f * ((float)videoFrame.Length * header.videoFrameRateNum / header.videoFrameRateDen - bytespersec);
                        // print stuff and dump streams into files
                        if (frameheader.flags.HasFlag(FrameHeader.FrameFlags.IDR_FRAME))
                            Console.WriteLine($"Received IDR frame {frameheader.frameIndex}                    ");
                        Console.Write($"got frame {frameheader.frameIndex}, {bytespersec * 8 / 1000.0f}kbits/s       \r");
                        videoFile?.Write(videoFrame, 0, videoFrame.Length);
                        audioFile?.Write(audioFrame, 0, audioFrame.Length);
                    catch (Exception e)
                        Console.WriteLine($"pipe read failed: {e.Message}");
                        break;
                Console.WriteLine("good bye.");
                videoFile?.Close();
                audioFile?.Close();
  • [MachineConfigurationMC Machine Configuration]
  • Supported Vendors
