![]() | Float Expression | Provides the possibility to write logical C# expressions with a Float as resulting output value. |
![]() | Double Expression | Provides the possibility to write logical C# expressions with a Double as resulting output value. |
![]() | Int Expression | Provides the possibility to write logical C# expressions with an Int as resulting output value. |
![]() | String Expression | Provides the possibility to write logical C# expressions with a String as resulting output value. |
![]() | Boolean Expression | Provides the possibility to write logical C# expressions with a Boolean as resulting output value. Additional it provides True and False Event outputs. |
![]() | Date Time Expression | Provides the possibility to write logical C# expressions with Date Time as resulting output value. |
![]() | Float Array Expression | Provides the possibility to write logical C# expressions with a Float array as resulting output value. |
![]() | Double Array Expression | Provides the possibility to write logical C# expressions with a Double array as resulting output value. |
![]() | Int Array Expression | Provides the possibility to write logical C# expressions with an Int array as resulting output value. |
![]() | String Array Expression | Provides the possibility to write logical C# expressions with a String array as resulting output value. |
![]() | Boolean Array Expression | Provides the possibility to write logical C# expressions with a Boolean array as resulting output value. Additional it provides True and False Event outputs. |
![]() | Dynamic Expression | Provides the possibility to write logical C# expressions with the ability to manual define in and output values. |
return EXPRESSION;
STATEMENTS
return RESULT;
| A + B | Sum of A and B for numeric expressions or the concatenation for string expressions. |
| (A + 1.0) * B | Product of B and the sum of A and 1. |
| Math.Sin(A / 180.0 * Math.PI) | Sine of the input degrees given in angle. |
| Math.Asin(A) * 180.0 / Math.PI) | Inverse sine of the given value A, converted to degrees. |
| (A == 6) ? 1:0 | Return 1 if A is equal to 1.6, otherwise return 0. |
| (A != B) ? 1:0 | Return 1 if A is not equal to B, otherwise return 0. |
| (A < 0) ? 0 : A | Return 0 if A is smaller than 0, otherwise return A. |
| (A >= 0) ? 0 : A | Return 0 if A is greater than or equal to 0, otherwise return A. |
| (A < 10) ? 10: ( (A > 20) ? 20 : A) | Returns A clamped into the the interval 10 to 20. |
| (double)(int)A | Converts A into an integral value (all fractions are removed) and converts it back to double. |
| Convert.ToString( Convert.ToInt32(A) * Convert.ToInt32(B)) | Convert the two input strings to integers, multiply them and convert the result back to a string |
int b = 0;
for(int i = 1; i <= A; i++)
b = b + i;
return b;
int b = 1;
if(A<=1) return 1;
b = b * i;
return b;
int result = 0;
result += A[i];
return result;
System.DateTime.UtcNow.AddHours(2) |
Array.Sort(A);
return A;
using System; using System.Linq; using System.Xml.Linq;
Since the System namespace has been made available, all functions in the Math Namespace, theConvert Class and all String operations are supported.
