Log Node
Log Prints user generated messages to the Performance Statistics.
The Log Node can be used to debug large scenes and projects. It can print custom messages to the Performance Statistics. To see the outcome the Statistics as well as its User Log section must be enabled in the Renderer Window.
Inputs
  • Enabled: Boolean, enables or disables the Log Node.
  • Message: User can define a custom log message message.
  • Write to log file: Boolean, En or Disables the ability to also write everything also into the log file.
  • Trigger: Event, Triggers the Node once. Needs the right type selected to be working.
  • Clear Console: Event, clears the console.
The Type property defines the way the message should be logged.
  • Frame updates the message every frame in the statistics
  • Console prints the message to the console of the statistics every frame
  • ConsoleOnChange only does so when the message is actually changed
  • OnTrigger prints the message to the Console every time the Trigger method is fired. This way also Events can be tracked. The event argument can be accessed by writing {0}  inside the Message string.
  • With Clock inserts the Cluster Clock in the printed string
Use the ClearConsole method to clear messages written in the Log.
Simple markup can be used to change colors and draw bars. See Markup in Logging.
  • Markup in Logging
