Previs Canvas
Previs Canvas A node used purely for previsualization, typically not used in a production environment.
The Previs Canvas Node is used to map the content from a Composition Layer or a Composition Projector Node to Previs Screens to apply content to elements in a previs Scene.
More than one Canvas can be mapped onto a Previs Canvas using different Blending Modes.
CanvasNameAssigns a name to each Previs Canvas making it easy to identify
DesignWidth/HeightAdjusts the Canvas in pixels. The aspect ratio is not respected with these settings
[+] Adds a Composition Source to the Node
Composition from LayerTaking the content from a Composition Layer and using it as a source for this Previs Canvas
Composition from Virtual ProjectorTaking the content from a Composition Projector
TransformUse four different options to transform the canvas layer/projector including the option to bind a Matrix
DesignSize
DefaultUses the whole Canvas
RectangleAllows the Composition or Projector to be placed inside of the Previs Canvas. The values are in Pixels. By default, the whole Composition fills the whole Canvas
BlendMode These blend modes follow the usual blend mode conventions found elsewhere in Ventuz and other Graphic editing platforms
SolidThe final color is the top color, regardless of what the bottom color is. The effect is like two opaque pieces of paper overlapping
AlphaUses the alpha channel or luma values to isolate regions of the background
AddBrightens the base color to reflect the blend color by increasing the brightness
Mul (Multiply)The final color is the result of multiplying the top and bottom colors. A black layer leads to a black final layer, and a white layer leads to no change.
AddSmooth
BlendAmountAdjusts the intensity of the blend
AllowScalingIs to enable the scaling of a Canvas to a Screen of a different resolution. If enabled and a screen is set to FHD a 4K Canvas will be rendered in 4K and downscaled to FHD. If the AllowScaling is disabled, the Canvas will be rendered twice, once in 4K and once in FHD
  • Render Setup
  • Composition List
