Configuring graphics cards to use AMD Eyefinity or Nvidia Mosaic is no longer needed to support multiple outputs from one graphics card. You can now assign all outputs individually or combine them using the Render Setup editor.
To open the Render Setup editor, open the Configuration Editor and open the Project Management tab, now select the Project this setup should be for. Create a new Render Setup by clicking the button on the right side of the window.
Once the new Render Setup is created, the Render Setup window will automatically open in the Layout Mode. Generally speaking this is the mode where you set the stage for you presentation, add screens and use compositions to set the frame for your rendering. To learn more about the handling of our new output system read this page.
1. Mode Change:
2. Previs:
3. Close and Save:
4. Machine Selection:
5. Compositions:
8. Contextual Controls:
9. Mode Selection:
10. View Options:
11. Property Editor:
12. Workspace:
13. Measurement Tool:
1. Color
2. Name
3:Fit to Screen
4. Dimension
5. Render Order
6. Rotation
7. Pixel Density
8. Physical Size
9. Diagonal
10. Blend Mode
11. Blend Amount
12. Allow Scaling
1. Color
2. Name
3. Resolution
4. Pixel Density
5. Physical Size
6. Diagonal
7. Bezel
8. Allow Scaling
9. Render Filter
10. Rotation
1. Color
2. Name
5. Physical Size
By using the measurement button in the lower right corner the user is able to measure distances between different elements in centimeter or inches. Clicking on the measurement button again will hide all measurements.
Set a measurement:
on a edge or corner of a element and drag it over to a second point to create a measurement. Holding CTRL and using the to adjust set points.
Deleting Measurements:
By on a existing measurement and hitting DEL will delete the measurement line. Alternatively you can also hold CTRL and drag a point into empty space to delete it.
When stacking Compositions on to each other it may be necessary to change their render order. To do that, simply drag and drop the Composition to the desired place in the Tree view. As always in Ventuz, the Render order starts from the top going downwards.
Solid: No blending is used
Alpha: Enables Alpha Blending
Add: Additive RGB blending
Instancing Compositions can be used to show the same content multiple times, in different positions or different resolutions. When "Allow Scaling" is enabled, Ventuz will render the scene elements one time and scale them to fit the corresponding Compositions. Scaling saves system resources. Ensure the aspect ratio is correct for these instanced Compositions otherwise, your content might end up stretched or squished.
The Default Composition inside the Render Setup Editor is behaving a little different then other ones. This Composition will automatically scale with screens that are on it. The Name of the Composition also cant be changed.
In order to free screens of the automatic scaling inside the Default Composition uncheck the "Fit to Screen" property on the Default Composition or use the scaling handles of the composition and remove the Screen from it. Deleting the Default Composition inside the Render Setup Editor wont brake anything inside the Designer. Still the Default Composition Layer will be present when another Composition layer is inserted but can be safely ignored.
With the Mapping mode it is possible to assign Screens to Outputs, add new machines, or shape and warp the Outputs.
1. Mode Change:
2. Previs:
3. Close and Save:
4. Mode Selection:
5. View Options:
6. Add machines:
7. Shaping & Warping:
8. Property Editor:
9. Machine Options:
10. Add Outputs:
11. Workspace:
13. Output Workspace:
14. TUIO Touch inputs:
The maximum visual resolution for a Ventuz machine is 16384 x 16384 pixels!
Elements can be selected by simply click. Multi selection is possible by dragging a selection frame drag around elements inside the All mode.
Moving is done by dragging and dropping, scaling can be done by the indicator on the Compositions. Selecting items in the tree view also changes the modes accordingly | ![]() | Rotations can be snapped to 10° or 5° using CTRL(10) or ALT(5) | ![]() |
Use the All mode to quickly move a bunch of elements | ![]() | Scaling only works for Compositions and TUIO Touch Areas, to resize screens use the Property Editor | ![]() |
To create an equal bezel or overlap between multiple elements, use the grid function when creating new screens.
Uses a single screen on the output. Assign a screen by drag + drop from the left pane onto the desired output on the right.
It is possible to use the same screen multiple times by applying them to multiple outputs.
In general as soon as one uses either the Grid or Manual mode the output will be cut into multiple pieces. Indicated by the small label on the lower left.
M0 = Machine + ID
1:
2:
3:
4:
5:
6:
7:
8:
9:
Without separation groups:
With separation groups:
Open the Mapping mode by clicking on "Mapping" in the top left corner to assign those Screens to the outputs we want to use. The Composition in this case is defining the area which we want to render content, therefore we need to have screens to assign to the outputs.
As you can see on the left, Ventuz doesnt know about the second screen yet, which is indicated by the white dotted line (the machine boarder). To assign it, we need to add another output to the machine, we can also directly assign the screen to it by using the drop down menu inside the pop up window. Or drag + drop screens from the left on to empty output slots on the right. If placing a screen on an output that has a screen already assigned to it, the existing screen will be replaced by the new one.
View | ||
Middle mouse button+drag | Pan | |
Middle mouse wheel | Zoom | |
CTRL+R | Reset view | |
Selection | ||
click | Select | |
click+drag | Rectangle Selection | |
click | Context Menu | |
CTRL click | Multi Selection | Add/Remove to/from selection |
CTRL+A | Select all elements depending on the selected mode | |
SHIFT+ click+drag | Disable snapping |
Editing | ||
move | Move selection | |
SHIFT move | Move selection without snapping | |
CTRL + Z | Undo | |
CTRL + Y | Redo | |
←, →, ↑, ↓ | Move selection by 10 pixel | |
CTRL + ←, →, ↑, ↓ | Move selection by 1 pixel | |
SHIFT + ←, →, ↑, ↓ | Multi Selection | Change distance by 10 pixel |
CTRL + SHIFT + ←, →, ↑, ↓ | Multi Selection | Change distance by 1 pixel |
+ drag + CTRL | Rotation | 10° snapping |
+ drag + ALT | Rotation | 5° snapping |
CTRL+S | Save changes |
