Web Browser
  1. Usage and Interaction
  2. Input
    1. Multitouch ´
    2. Mouse
  3. Browser Functionality
    1. Browser Cache
    2. Disable Security
  4. Progress and Status
    1. Content
    2. Cursor
  5. JavaScript
    1. Methods/Events
    2. Execute On Load
    3. Transparent Background
  6. Limitations
The Web Browser node renders web pages into a texture so their content can be used inside a Ventuz scene. Since Ventuz 5.3 this is done based on the ​Chromium Embedded Framework CEF.
Input
Multitouch ´
​Chromium Embedded Framework CEF can handle maximum 16 inputs per browser.
Mouse
Code Description
13 Return
9 Tab
8 Backspace
127 Delete
27 Escape
The unicode values for the most commonly used characters can be found ​here and ​here. Additional information on other character sets can be found ​here.
  • Load: Load the URL/HTML specified in the NavigationURL or NavigationHTML respectively.
  • Reload: Reloads the current content (same as pressing F5/Refresh in a dedicated browser application).
  • Stop: Stops/interrupt the current loading process.
  • Forward: Go one page forward in the navigation history.
  • Backward: Go page backward in the navigation history.
Browser Cache
%TMP%\Ventuz
Disable Security
With the start of version 6.9 the Disable Security property is deprecated and will be removed in the future. When activating it you will get a pop up notification saying that this is moved to the machine configuration. The reason for this is that with the new ​Chromium Embedded Framework CEF update this has to be set globally and can not be managed per node anmyore. So we had to move it inside the Machine Configuration. There in the *Multi Touch* and Remoting 4 category under the extended tab you will find the Web Browser Settings.
Here you can now disable the Web Security.
Only Disable the Web Security when you know what you are doing. This can open the door for malicious software to enter your PC as well as many other problems. So use with caution!
Progress and Status
Content
  • CurrentURL: The URL of the currently displayed HTML page.
  • TargetURL: If the cursor hovers over a link, this provides the URL the link leads to.
  • Title: The title of the currently displayed HTML page.
  • Tooltip: If the content contains a tooltip for the current position of the cursor, it will be provided in this property.
Cursor
0 Pointer (default)
1 Cross 2 Hand 3 Ibeam 4 Wait
41 Custom
JavaScript
The Web Browser node supports the ​JavaScript scripting language both as part of the content as well as a means of interaction between Ventuz and the site content. This is done by defining input/output properties, methods and events in the Custom Model editor at the bottom of the Property Editor.
Methods/Events
<html>
<head>
<title>Method Test</title>
</head>
<body>
function CalculateSquare() {
  var result = ventuz.value * ventuz.value;
  document.write("The square of " + ventuz.value + " is " + result + "<br>");
  ventuz.Result(result);
</script>
</body>
</html>
Execute On Load
The property WebBrowserJavaScript can optionally contain a ​JavaScript snippet that is injected and executed on every loaded page. This opens many possibilities to operate on external pages.
Example 1:
Example 2:
Creates two methods called UP and DW in the Custom Model to invoke the defined JS functions. The displayed window will scroll up/down when Ventuz invokes these methods. (See also function ​scrollBy())
Disable PluginPlugins (like Adobe Flash) are disabled.
Disable SecurityDisables all security checks inside the Web Browser. Use with Caution!
Allow ClearTypeDisables/enables ​Clear Type. Monochrome scaled text with Clear Type enabled result in colorful edges.
Allow ventuz:// from external sitesAllows you to reference assets inside a Ventuz Project
Ignore SSL certification errorsExecution of Java Script code is disabled.
AudioAllows you to configure the In and Out Ventuz Ordinals and global browser Volume. Also check the crosspoint section in the Audio Video Config for further information.
Limitations
  • The maximum resolution of the web browser is 4096 x 4096 pixel.
  • A touch is immediately claimed by the Web Browser, so a combination of Touch Translation node with the Web Browser node is not possible.
  • User login prompts and other popup windows are not supported.
  • Multi Touch
  • Ventuz Input Subsystem
  • ​JavaScript
