Taking Action
In the chapter Introduction, we can see that getting a template on air is a three step process:
  • A template is selected and cued.
  • The template's values are modified.
  • The template is taken on air.
We will now take a closer look at the last step while discussing modification of values in the next chapter.
Take
The primary action after cueing a template is to Take it. This confirms that the operator has finished doing all required modifications and/or that the time has come to bring the cued content on air. To take a cued content, press F1. The Ventuz Template Engine will calculate the best animation from the old to the new content and performs it. Depending on how the templates have been designed, this can either mean the old template moves out before the new template comes in or some specialized transition. Regardless of the animation, the cue becomes empty, ready for the next template.
Some templates have multiple points along their animation that can be interesting to the audience. Such templates are called multi-takes and the number of takes required is shown in the Show Control (see below). When it's time for the next step in the in-animation, just press Take again.
Take Out / Clear
A similar operation is the Take Out, done by pressing F3. This moves out the current on-air template but does not move in the cued one. If the cue is empty, doing a Take will automatically result in a Take Out.
In the case of an emergency, the Clear can be used to get a template off air without performing any animations. This is done by pressing Ctrl +  F3.
Update
Wherever the operator needs to fix some error in the on-air content, he can perform an immediate update without animations: First, press Ctrl +  F2 to go into on-air mode. The Property Editor will switch to the current on-air content and show a bright red box in the top right corner that says "On Air".
The operator can now perform changes and once complete press F2 to update the on-air content. To leave the on-air editing mode, press Ctrl +  F2.
While in on-air mode, sub-templates cannot be added/removed as this would require performing animations.
Recueing
It is surprisingly often that one needs a copy of what is already cued or on-air. For example, an operator might take a template on air and then decide to add a sub-template a few seconds later. The hard way would be to cue the exact same template as before, change the values again and then add the sub-template. However, there is also an easy way: Recueing.
  • Shift +  F1 takes the currently cued template on air and automatically cues an exact copy.
  • Shift +  F2 cues a copy of what is already on air.
  • Shift +  F3 takes out the template currently on air and cues a copy.
Show Control
Since take, update, take out and clear are so important, they also have dedicated buttons in the user interface. Regardless of the window layout, the Show Control is always present underneath the render windows. It contains the four buttons for take, update, take out and clear as well as some status information about the cued template. In the right corner of the Show Control is the Log Message Icon that flashes red/yellow if an error/warning has occurred. Press it to open the Messages Window. Next to it is the Topology Icon which uses similar color codes when a warning/error in the topology occurs. Press it to open the Topology Editor.
Actions performed on the Showcontrol are applied to all Channels except those where the User interaction is explicitly disabled. See working with multiple channels for more information.
Reset all Playlists
F4 resets all playlists with User interaction that are allowed and enabled to the first item.
Playlist Control
The toolbar at the bottom of the playlist window contains various operations that can be performed. Which buttons are shown can be customized via the docking window configuration options to fit workflow needs.
Take, Update & Clear
These buttons function exactly the same as those in the Show Control. However, they only affect the channel this playlist window is bound to.
Editing & Operation
These buttons affect the actual usage of the playlist:
  • User-Interaction: When this button is not highlighted, the channel will not listen to user-interaction such as pressing F1 to do a take or the take button in the Show Control. Deactivate it if for example the channel is automated via a plug-in or the Automation feature described above.
  • Edit: Edit the description and other properties of a playlist entry.
  • Remaining Duration: If a playlist entry has a fixed duration specified, this will count down to the point when it will go off air again.
  • Ignore Duration: When a playlist entry has a fixed duration, it will be taken off air once its duration has been reached. However, with this button the automation can be deactivated while still preserving the values on the individual entries.
  • Loop Mode: When the last entry goes off air, restart at the first entry of the playlist.
  • Reverse Mode: Changes the auto-cueing to use the previous item instead of the next one.
  • Move Up: Move all selected items one row up. Ctrl + Shift + Up
  • Move Down: Move all selected items one row down. Ctrl + Shift + Down
  • Move Top: Move all selected items to the top of the playlist. Alt + Ctrl + Shift + Up
  • Move Bottom: Move all selected items to the bottom of the playlist. Alt + Ctrl + Shift + Down
  • Select All: Select all playlist items. Ctrl + A
  • Invert Selection: Invert the current selection Ctrl + I
  • Delete: Delete selected items. Delete
  • All-Out: Add an "All Out" item which performs a Take Out of all items on the current channel.
