Screen Render Options
Screen Render Options Forces the engine to render a Canvas multiple times with different resolutions and/or cameras
The Screen Render Options Node can be used on a Screen or Composition Projector Node to force the Ventuz Engine to render a Canvas multiple times with different resolutions and/or cameras. The Engine can render the content at the highest resolution and filter the result for lower resolution outputs resulting in saving system resources.
The CameraOverride can make use of
Setting Description
TrackedCameraFor Head Mounted Displays or Camera Tracking Systems
MatrixCameraAllows the use of a custom view matrix. The presets zero and identity matrix can be used or modified manually or the Matrix Property can be connected to a matrix coming from for example a Matrix Node or a Script
SetExtensionEnables a POV (Point of View) or Eyepoint to be visualized. This can be used to give the impression of an extended, view as if looking through a window, when the POV, or camera moves from one place to another
ZNearSets where the Z depth view starts. This will clip objects close to the camera
ZFarSets where the Z depth view stops. This will clip objects far from the camera
X/Y/ZSets the viewpoint of the camera in 3D space
RenderFilterCan be set to exclude parts of the hierarchy to be rendered - the filter enumeration can be selected on the output property in the Render Setup Editor
OverrideWidth/HeightChanges the output resolution
PrevisWidth/HeightChanges the previsualization resolution for the Previs rendering inside the Ventuz Designer as well as for the Previs Screen output in the Render Setup Editor
Keep this setting as low as possible to prevent performance issues when working with high resolution outputs
  • Composition List
