Nodes and Bindings
  1. Nodes
    1. Layer Nodes
    2. Hierarchy Nodes
    3. Content Nodes
    4. Primary Nodes
  2. Properties and Bindings
  3. Layer to Layer Bindings
  4. Validation and Rendering
Introduces you to the basics of the scene building workflow in Ventuz. You will get to know the different types of Ventuz Nodes and how to use results of one Node as Inputs of other Nodes. This way you will be able to adjust any Properties of your Visual Objects according to any kind of data. Be it animations, data bases, files, or otherwise generated data.
Nodes
Nodes are the fundamental elements from which a Ventuz Scene is constructed. Each node is either a Layer, Content or Hierarchy Node and thus belongs either in the Layer Editor, Content Editor or Hierarchy Editor.
This is visualized by the orientation of the brackets around the node icon.
A hierarchy node has vertical brackets, a content node horizontal brackets and a layer node corners around the node icon.
While Content Nodes are available everywhere in the scene, Hierarchy Nodes and the Hierarchy Editor can only be used inside a 3D Layer.
All nodes can be browsed via one of the Toolboxes. These can be accessed either through the toolbox window (accessible via View/Toolbox in the menu bar) or by clicking into the Layer Editor, Hierarchy Editor or Content Editor and then pressing the Space key to open the Fast Toolbox.
Some toolbox items can be placed in other editors than hinted by their brackets, see the Toolbox reference page for more details.
Layer Nodes
Layer Nodes are somewhat special in that they represent a 2D Compositing Layer - everything inside a Layer will be rendered onto a dedicated texture and then composited together with all other Layers using the Layer Effects and the Layer Blending and Masking.
Hierarchy Nodes
A hierarchy node is like an instruction to the Ventuz Rendering Engine, for example to activate a certain material or texture, to render a mesh and so forth.
Content Nodes
A content node describes an asset (i.e. a texture, an XML file, ...), a numeric constant, an event or any other item that does not directly influence the rendering process.
Primary Nodes
Primary Nodes are Hierarchy and Layer Nodes, except the following ones:
  • Container Output
  • Switch and Yes/No Switch
  • Layer Switch
  • Set World
  • Get World
  • Shear
  • Layer Group
  • ZSort
In terms of the limitation of the Community Edition Primary Nodes are counted through the whole currently active Scene Tree. Especially when working in the Ventuz Designer you need to keep in mind that not only the Nodes in the current Scene are counted. The node count of the currently open scene can be found in the scene tab, the node count of the whole scene tree is found in the System Information of the Performance Statistics.
Example
Below you can find a very common scene tree setup. One main scene loads and displays several sub-scenes. The limit exceedance depends on how many nodes each scene has. For the examples we assume a limit of 500 nodes:
  • Case 1 - The_Office and all seven sub-scenes each have 50 nodes: The limit is not exceeded as in sum they have 400 nodes.
  • Case 2 - The_Office and all seven sub-scenes each have 100 nodes: The limit is exceeded as in sum the scenes have 800 nodes, although each scene alone has less than the given limit.
Bindings are visualized as arrows which connect nodes in the Content Editor. To create a binding, select a node, go to the Properties Editor and drag the input property onto another node. When released, Ventuz will open up a list of compatible output properties of that second node. Upon choosing one of the properties, a connection is created and visualized by an arrow going from the output node to the input node. For more information, see Property Editor. When a node is selected its bindings will be highlighted as shown in the picture above.
It is possible to have bindings across Layers. Before you can use a property and bind it from one to another layer, or bind the property to the Layer Level content nodes you have to expose the values up to the Layer Level. The following screenshots show a Touch Button which has the TouchPressed exposed from the 3d Layer (User interface) and is bound to the 2D Movie Clip Layer to control the Play.
Inside the Layer3D - exposed the SingleTap
Layer Level - The exposed SingleTap is visible and can be bound
The Play event from the 2D Movie Clip Layer is bound to the SingleTap
  • PropertiesEditor
  • Node Descriptions
  • Containers and Interfaces
