Supported Hardware Vendors
  1. SDI
    1. About SDI Formats and Standards
    2. SDI Feature Comparison Table
    3. ST 2110
  2. Capture and Playback
    1. Deltacast
      1. Supported Models as of Ventuz 6.08.00
      2. Unsupported Models
      3. Drivers
      4. Model Selection
      5. Configuration
    2. AJA
      1. Supported Models
      3. Drivers
      4. Kona 5 Firmware
      5. Kona 4 / Kona 3 / IO4K Firmware
    3. Black Magic Design
      1. Supported Models
      2. Drivers
      3. Limitations of Decklink 8K Pro
      4. Extreme Series
      5. Configuration
    4. Datapath
      1. Supported Models
      3. Drivers
    5. DVS
      1. Supported Models
      2. Drivers
    6. NewTek
      1. iVGA / AirSend
    7. NDI
    8. Windows Media Foundation
    9. AWS Cloud Digital Interface
  3. GPUs
    1. AMD
    2. Nvidia
    3. Intel
    4. Other
  4. Camera Tracking Systems
    1. Trackmen - Egripment
    2. NCam
    3. Stype
    4. Mo-Sys
  5. Head Mounted Displays
    1. HTC Vive
    2. Oculus Rift
  6. Other
    1. GPI Boards
  • GPUs
  • Capture and Playback for SDI, VGA, HDMI, DVI, Display Port, Network protocols and consumer devices like Webcams.
  • Camera Tracking Systems
  • General Purpose IO
SDI
Data Rate SMPTE Links Resolution, Maximal Framerate, Description
270 Mb/s 525i60, 625i50
ST 259 SD full raster
1.5 Gb/s 1080i60, 1080p30, 720p60
ST 292-1 HD full raster
3.0 Gb/s 1080p60
ST 425-1 3GA LevelA : full raster
ST 372 2xHD interleaved lines
ST 425-1 3GB LevelB : 3G link carries a HD Dual Link stream muxed
6.0 Gb/s 2160p30
none 4xHD image quadrants
ST 425-3 2x3GB 2x 3G Level B-DS links carry 4 HD streams as two samples interleaved
ST 2081-10 6G full raster
12.0 Gb/s 2160p60
none 4x3GA image quadrants
ST 425-5 4x3GA 4 3G links as two samples interleaved
ST 2081-11 2x6G interleaved pixels across 2 streams
ST 2082-10 12G full raster
24.0 Gb/s 4320p30
none 4x6G image quadrants
ST 2081-12 4x6G interleaved pixels across 4 streams
48.0 Gb/s 4320p60
none 4x12G image quadrants
ST 2082-12 4x12G interleaved pixels across 4 streams
  • In this table and the following table, a framerate of 60 includes 59.94, 50, 48 and 47.96. A framerate of 30 includes 29.98, 25, 24 and 23.98.
  • 3G comes in two variants that are incompatible to each other: Level A and Level B. This can lead to compatibility problems, especially with old boards, please check the board compatibility carefully.
  • quad link 2160p60 comes in two versions: as image quadrants and as SMPTE ST 425-5 two sample interleaved, and please, you have to check board compatibility carefully.
  • quad link 2160p60, in both versions, can be based on 3G Level A or 3G Level B. Ventuz supports only Level A.
Format SD 1080i60 1080p60 2160p30 2160p60 4320p30 4320p60
Links SD HD 2xHD 3G A 3G B 4xHD 2x3G B 6G 4x3G A 4x3G A 2x6G 12G 4x6G 4x12G
SMPTE ST 259 292-1 372 425-1 425-1 none1 425-3 2081-10 none1 425-52 2081-11 2082-10 none1 2081-12 none1 2081-22
Deltacast
DELTA-12G1c-hmi10-elp X X - X X5 X X no key3 X X - no key3 - - - -
DELTA-12G-ELP-H-4C X X - X X5 X X X X X - X X X X X
DELTA-12G-ELP-H-2C X X - X X5 X X X X X - X - - - -
DELTA-3G-elp-key-d 4k X X X X X5 X X - X X - - - - - -
DELTA-3G-elp-key-d 2k X X x X X5 X X - - - - - - - - -
DELTA-3G-elp-d 4c/8c X X X X X5 no key3 no key3 - no key3 no key3 - - - - - -
DELTA-3G-elp-2key-d 22/44 X X X X X5 X X - - - - - - - - -
DELTA-3G-* X X - X X5 - X - - - - - - - - -
DELTA-HD-e-key 22/11 X X - - - - - - - - - - - - - -
DELTA-HD-ELP-D-44/80 X X X - - X - - - - - - - - - -
DELTA-HD-* X X - - - - - - - - - - - - - -
FLEX-12G 10 01 X X - X X5 no key3 no key3 no key3 no key3 no key3 - no key3 - - - -
FLEX-3G 40 04 X X X X X5 - - - no key3 no key3 - - - - - -
Black Magic Design
Decklink 8K Pro X X no key3 X X - no key3 X - - - X - X - X
Decklink 4K Extreme 12G X X no key3 X X - no key3 X - - no key3 X - - - -
Decklink 4K Extreme X X no key3 X X - no key3 X - - out only - - - - -
Decklink HD Extreme 3 X X - X X - - - - - - - - - - -
Decklink Duo/Quadro 2 X X - X X - - - - - - - - - - -
Decklink Mini Monitor 4K X X - X X - - X - - - - - - - -
Decklink Mini Recorder 4K X X - X X - - X - - - - - - - -
UltraStudio HD Mini X X - X X - - - - - - - - - - -
Aja
Kona 5 4 X X - X X no key3 no key3 X no key3 no key3 - X X X X X
Kona 4 X X - X X no key3 no key3 - no key3 no key3 - - - - - -
Kona 3 X X - X - - - - - - - - - - - -
Kona LHi X X - X - - - - - - - - - - - -
Kona LHe+ X X - - - - - - - - - - - - - -
Corvid 44 12G 4 X X - X X - - X - - - X X X X X
Corvid 88 X X - X X X X - X X - - - - - -
Io 4k Plus X X - X X no key3 no key3 - no key3 no key3 - - - - - -
Io X3 X X - X X - - - - - - - - - - -
Io 4K X X - X X no key3 no key3 - no key3 no key3 - - - - - -
Io XT X X - X - - - - - - - - - - - -
Datapath
Vision LC SDI X X - X X - - - - - - - - - - -
Vision AV SDI X X - X X - - - - - - - - - - -
  • 1 4 links as image quadrants
  • 2 4 links in a two sample interleaved pattern
  • 3 no key: no key + fill / external keying / internal keying modes
  • 4 Kona5 : limitiation apply based on chosen firmware / personality (see below for details)
  • 5 Some Deltacast boards have problems with 3G B audio and keying
Boards are also limited by the number of connectors and capabilies from the table below. For instance, a Delta-3G 11 with one input and one output can not do key+fill because that would require two outputs, and it can not do internal hardware keying because in the table below it says that "DELTA-3G-*" boards can not do internal hardware keying.
Feature summary and exlenation of sortcuts:
  • k+f : output key + fill as separate SDI streams to connect to an external keyer.
  • keyer : internal hardware keying modes available.
  • duplex : independent input and output streams, multiple input and output streams
  • multiformat : when independent streams are supported, can we mix multiple formats? Timebase means multiple formats are supported, but they must be all dropframe or none dropframe.
  • bypass : hardware watchdog can bypass SDI signal on catastrophic failure.
  • Timecode : timecode reception
  • AFD : reception of active format description
  • tracking : synchronize tracking network packets with SDI house clock, requirement for all camera tracking system.
  • ECK : external chroma keying: output foreground as key+fill, background as fill only and garbage matte as key only on 4 output jacks.
  • HDR : high dynamic range
  • Specials :
    • key-input : while doing internal keying, one can use the input signal for 3d rendering
    • key-delay : internal hardware keying with delayed input, used for transitions from normal keying to 3d rendering (DVE).
    • softkey : keying using an ordinary input and output stream, using the GPU as a keyer.
    • RGB444 : support RGB 4:4:4 in addition to YUV 4:2:2 for SDI streams
Deltacast
Series / Model audio autodetect k+f keyer duplex multiformat bypass Timecode AFD Tracking ECK HDR Specials
DELTA-12G-* yes yes yes - yes timebase - yes yes yes yes yes softkey
DELTA-3G-elp-key-d 4k yes yes yes yes yes timebase (yes)6 yes yes yes yes yes softkey, key-input, key-delay
DELTA-3G-elp-key-d 2k yes yes yes yes yes timebase (yes)6 yes yes yes - ? softkey, key-input, key-delay
DELTA-3G-elp-d 4c/8c yes yes yes - yes timebase - yes yes yes yes yes softkey
DELTA-3G-elp-2key-d 22/445 yes yes yes yes yes timebase yes yes yes yes - yes softkey, key-input, key-delay
DELTA-3G-* yes yes yes - yes timebase - yes yes yes yes ? softkey
DELTA-hd-e-key 22 yes yes yes yes yes timebase yes yes yes yes - - softkey, key-input, key-delay
DELTA-hd-e-key 11 yes yes - yes yes timebase yes yes yes yes - - softkey, key-input
DELTA-HD-* yes yes yes - yes timebase - yes yes yes yes - softkey
FLEX-12G 10 01 yes yes - - - timebase - yes - - - yes
FLEX-3G 40 04 yes yes - - - timebase - yes - - - ?
Blackmagicdesign
Decklink 8k Pro yes yes yes yes2 yes yes - yes - yes yes yes RGB444
Decklink 4k Extreme 12G yes yes yes yes2 yes - - yes - yes - yes RGB444
Decklink 4k Extreme yes yes yes yes2 yes - - yes - yes - ? RGB444
Decklink Extreme 3D3 yes yes yes yes2 - - - yes - - - ?
Decklink Duo/Quad 2 yes yes yes yes2 yes yes - yes - yes yes no RGB444
Decklink Duo/Quad yes yes - - - - - yes - yes - yes will appear as multiple devices
Decklink Mini Monitor 4k yes yes - - yes - - yes - - - ? RGB444
Decklink Mini Recorder 4k yes yes - - yes - - yes - - - ? RGB444
UltraStudio HD Mini yes yes yes yes yes - - yes - - - ?
Datapath
VisionLC-SDI - - - - - - - - - - - -
VisionSC-SDI4 - - - - - - - - - - - -
VisionSC-HD4+ - - - - - - - - - - - -
VisionAV-SDI2 - - - - - - - - - - - yes
AJA
Kona 57 yes yes yes yes yes - - - - yes yes yes
Kona 4 yes yes yes yes yes - - - - yes yes yes
Kona 3G yes yes yes yes yes - - - - yes - ?
Kona LHi yes yes - yes yes - - - - yes - ?
Kona LHe+ yes yes yes yes yes - - - - yes - ?
Corvid 44 12G (BNC or not) yes yes yes yes yes - - - - yes yes yes
Corvid 88 yes yes yes yes yes - - - - yes yes yes
Io 4K Plus8 yes yes yes yes yes - - - - yes yes yes
Io X38 yes yes yes yes yes - - - - yes yes yes
Io 4K8 4 yes yes yes yes yes - - - - yes yes ?
Io XT8 yes yes yes yes yes - - - - yes - ?
Limitations:
Some lines in the table describe a whole category of products. If a certain option requires more jacks than the board offers, the mode is obviously not supported. For instance, a Blackmagic Decklink board with only one output can not support key+fill, while it's larger brother with two outputs will.
  1. Some features for Atomix / Centaurus boards need special licenses from DVS.
  2. On Blackmagic and DVS products, the internal keyer can only operate in multiplicative mode. External keying can be multiplicative or additive depending on the hardware used as external keyer.
  3. Older Blackmagic Boards like HD Extreme 3 and older, are not capable of Input and Output simultaneously.
  4. On the Aja Io 4k, support for 4k 60Hz depends on the quality of the Thunderbolt interface and the mainboard.
  5. The 2key boards feature a second genlock, but this is not supported by Ventuz.
  6. Old versions of the 2k / 4k boards do not support bypass relays. New versions, which only work with Ventuz 6.02.00 or later, feature bypass relays.
  7. On the Aja Kona 5, the available features depend on the installed firmware, so not all features are available at the same time without reprogramming the device outside Ventuz.
  8. HDMI input and output is not supported for Aja IO series
ST 2110
Ventuz supports the following ST 2110 boards
Vendor Model Speed SPS 1 Channels Notes
Deltacast DELTA-ip-ST2110 10 10 GBit/s yes 4 In
Deltacast DELTA-ip-ST2110 01 10 GBit/s yes 4 Out
Aja Kona IP only output 4 In / Out end of production
  1. Seamless Protocoll Switching via ST 2022-7 for ST 2110.
Deltacast
​Deltacast HD / 3G / 12G Series
KEY Series
DVI / H4k Series
FLEX Series
Recommended boards
  • DELTA-12G-elp-h 4c (general purpose 12G SDI configurable input/output, 12g key+fill)
  • DELTA-IP-ST2110 10/01 (ST2110 10GB/s board, can be "flashed" to either all input or all output)
  • DELTA-3G-elp-d 4c (general purpose SDI configurable input/output, 3g key+fill)
  • DELTA-3G-elp-key-d 2K (general purpose SDI keyer board)
  • DELTA-3G-elp-key-d 4K (4k "2si" key+fill output)
  • DELTA-h4k2-elp 20 (4k HDMI/DVI capture)
  • DELTA-12G1c-hmi10-elp (12G SDI IO + HDMI capture)
  • DELTA-12G-elp-h 2c 20 (12G boards)
  • DELTA-12G-elp-h 40 04 22 (12G boards, these can be converted into a DELTA-12G-elp-h 4c board via firmware update as the hardware is identical, and we strongly recommend to do this)
  • DELTA-3G-elp-d 8c, (if you need more outputs / inputs than the 4c board offers)
  • DELTA-h4k-elp 20 (1080p HDMI/DVI capture)
  • DELTA-3G-elp-2key-d 22, DELTA-3G-elp-2key-d 44 (the 2k/4k boards are recommended over these boards)
Supported FLEX modules
  • DELTA-gwy 316-8 (gateway board to which the flex modules are connected)
  • DELTA-gwy 316-4
  • FLEX-DP 10
  • FLEX-HDM 10
  • FLEX-3G 40 04
  • FLEX-12G 10 01
  • DELTA-3G-elp 01,10,11,20,02,40
  • DELTA-3G-elp-d 01,10,11,20,02,21,12,22,40,04
  • DELTA-hd-elp-d 44,80,62 (since V8.0)
  • DELTA-hd-e-key 22,11
  • DELTA-hd-e 22,21,12,20,02,11,10,01
  • DELTA-hd-elp 40,20,10
  • DELTA-dvi-e 20,10
Unsupported Models
  • DELTA IP boards (not yet implemented)
  • DELTA ASI boards (Streaming support not implemented)
  • DELTA-3G40-hd40-elp-d (We need to do specialized testing for this card)
  • DELTA-12G-elp-h 1c (We need to do specialized testing for this card)
  • FLEX-DP 01 (We need to do specialized testing for this card)
  • DELTA-h4k2-elp 20 V2.0 (driver 6.20 not supported)(Caution: This board can be identified only by the label with the addition of V2 to the Type Label)
  • DELTA-3G-elp 2c (Deltacast stops supporting them since SDK 6.06)
  • DELTA-3G-e 22, DELTA-3G-e-key 22 (Deltacast stops supporting them since SDK 5.20)
  • DELTA-hd-e 04,40 (Deltacast stops supporting them since SDK 5.15)
  • DELTA-SD boards (Deltacast stops supporting them since SDK 5.15)
Drivers
Current Versions
Ventuz Mainstream Driver Legacy Driver Experimental Driver Note
8.01.00 6.22.1 rc 1 6.13.1 6.30.0 patched driver, "v6.22_rc1.zip"
8.00.00 6.22.1 rc 1 6.13.1 patched driver, "v6.22_rc1.zip"
7.00.00 6.15.1 6.13.1 6.20.0 introduced experimetal drivers
6.08.00 6.15.1 6.13.1 introduced legacy drivers
6.06.00 6.13.1
6.04.01 6.8.1 patch 3 patched driver, "v6.08.01_h4k2_EDID_Build3"
6.02.00 6.8.1 patch 2 patched driver, "v6.08.01_h4k2_EDID_Build_2"
You can download the driver from the Ventuz support website at ​http://www.ventuz.com/drivers.
Some versions use a patched version of the driver which is not available from the Deltacast website. Please always use the drivers in the driver folder of the Ventuz installation directory and not the drivers from the deltacast website.
Legacy Drivers
As of Ventuz 6.8, Ventuz will detect the installed drivers for deltacast boards and then choose the correct Deltacast SDK libraries.
If you have one of the old boards that are not supported by the latest deltacast SDK, install 6.13.1 drivers for all boards. Otherwise install the drivers that come with the ventuz installation for all boards, as that will have significantly better performance. Ventuz will then load the correct SDK libraries.
If you have multiple deltacast boards and mix drivers, Ventuz will load the "mainstream" libraries and the boards using 6.13.1 are not usable. Boards with any other driver will also be not usable.
So be aware mixing boards that require old drivers (like the DELTA-HD-e-key 22) and new boards that only work with mainstream drivers (like DELTA-12G1c-hmi10-elp).
Model Selection
Internal Keying
The only 3G board that can do 4k 60Hz SMPTE ST 425-5 (aka 2si) external keying is the DELTA-3G-elp-key 4K.
12G key+fill can be confusing to configure, as the 12G-elp-h 4c and 12G-elp-h 2c boards output 6G/12G key+fill on TX0 / TX4, and the second pair on TX2 / TX6, while 3G will be output on TX0 / TX1 and TX2 / TX3 as you would expect. In the device config you need to first choose "external keying" and then the right combination of output ports to have the desired video format available on your output.
Configuration
Tracking Source
The tracking source feature allows to align the timing of camera tracking data with an SDI signal. Since Ventuz V8.0, outputs can be used for this in addition to inputs. For this to work, the output must be locked to a genlock input and the genlock frequency must be manually selected, not set to "autodetect.". Inputs always work.
Genlock Offset
It is possible to use a different video format for the genlock signal then for the output that is to be synchronized, as long as the refresh rate is the same. For instance, using PAL as genlock and 720p50 as output is ok. But notice that for deltacast boards, the video format of the output defines the units for the genlock offset: changing the genlock by one line will change the genlock by one line in 720p, not one line in PAL. This also works with genlock format set to auto, since the video format of the output stream is always known. If multiple outputs with different video format are defined, the effect of the genlock offset is unspecified.
  • Before a Deltacast DVI input can be used, the board must be configured for the kind of signal it should expect with the Video Norm Input # board option. This is analog DVI, digital DVI, digital dual link DVI, HDMI or composite. This can be configured for each input separately.
  • On the DELTA-dvi-e 20, when receiving a dual link signal it must be connected to the first input, and the second input can not be used any more.
  • The DELTA-h4k-elp 20 will use YUV420 color sampling in the 4k @ 60 Hz modes.
Memory Pre-Allocation
Starting video stream failed. Sometimes this can be fixed by setting
Deltacast specific registry keys for 'memory pre-allocation'
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\DELTA-hd]
"PreallocPool0Size"=dword:03000000
"PreallocPool1Size"=dword:03000000
"PreallocPool2Size"=dword:03000000
"PreallocPool3Size"=dword:03000000
"PreallocPool4Size"=dword:00000000
"PreallocPool5Size"=dword:00000000
"PreallocPool6Size"=dword:00000000
"PreallocPool7Size"=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\DELTA-dvi]
[​​http://ventuz.com/sites/default/files/downloads/files/drivers/deltacast_mem_pre_alloc.zip download] this registry file from www.ventuz.com
AJA
​AJA Kona / Corvid
  • Although multiple inputs and outputs can be used, they must all have the exact same video format.
    • Because of this, auto-detecting inputs only works for a single input stream.
  • AFD and Timecodes are not yet supported
  • The HDMI features are not supported.
Supported Models
  • Kona 5 (see below)
  • Covvid 44 12G
  • Corvid 88
  • Kona 4 Quad
  • Kona 3G Quad
  • Kona LHe +
  • Kona LHi
External devices:
  • IO 4K
  • IO XT
Corvid boards are intended for situations where a developer bundles their software with a Aja hardware. Driver and tool support by Aja is limited and hidden behind a login that is only allowed for registered developers. Expect inconveniences when using a Corvid board!
This means that the board generally works with standard Venutz, but there are complicated limiations, please check with us.
Unsupported Models
Drivers
Ventuz 4 Ventuz 5 Ventuz 6 Ventuz 7 Driver
8.00.00 16.2.5
6.08.00 7.00.00 15.5.3.1
6.06.00 15.5.1.2
4.05.00 5.00.00 6.00.00 12.0.0.123
Problems Installing Drivers
Kona 5 Firmware
The Kona 5 and Corvid 44 12G come with different firmwares, each firmware has a different feature set. As there are different tools to flash a Corvid firmware, the names for equivalent firmwares are different.
Kona5 Firmware 4k n/a 8K 12 Bit
Corvid44 12G Firmware n/a 8KMK 8K 2x4K
input / output SD/HD/3G SD/HD/3G HD/3G/6G/12G no
quad link input / output HD/3G HD/3G 6G/12G no
internal keying SD/HD/3G (2x) SD/HD/3G (1x) no 6G/12G
external keying SD/HD/3G (2x) SD/HD/3g (1x) no 6G/12G
We recommend:
  • if you need 6G/12G keying, you need the 12 bit / 2x4K firmware
  • if you need 6G/12G input / output, you need the 8k firmware
  • if you need quad link 6G/12G input / output, you need the 8k firmware
  • if you need SD/HD/3G keying, you need the 4k / 8KMK firmware
  • if you need SD input / output, you need the 4k / 8KMK firmware
  • if you need quad link HD/3G input / output, you need the 4k / 8KMK firmware
  • otherwise, the 4k / 8KMK or 8k firmware will both do, prefer the 8K firmware.
The Aja control panel supports switching the firmware of Kona-5 boards without reboot, this is called the "fast" option. This may be useful when you need to experiment with the different modes.
These "fast" firmwares behave identical to the normal ones, only that the board will revert to the original state on next shutdown / reboot, as the firmware is not actually "flashed".
The Corvid44 12G must be configured with a commandline tool. The Aja Control Panel detects the board but does not provide the required firmwares.
Many older boards have two firmwares : UFC and Quad. Ventuz is tested with the Quad firmware only.
Black Magic Design
​Black Magic Designs Decklink series
Intensity series
UltraStudio series
  • Decklink boards provide SDI, DVI and sometimes anaolog inputs and outputs. The more advanced boards provide keyer functionality and can output key+fill.
  • UltraStudio products are similar to Decklink, but are connected via Thunderbolt or USB3 instead of PCIe.
  • Intensity is the label Blackmagic puts to products that only support DVI / HDMI / DisplayPort and analog connection. There is no SDI. They can come internally as PCIe or externally via USB / Thunderbolt.
Supported Models
  • Decklink 8K Pro
  • Deckink 4k Extreme 12G
  • Decklink Duo II
  • Decklink Quad II
  • Decklink Mini Monitor 4k
  • Decklink Mini Recorder 4k
  • Decklink Quad HDMI
Legacy models that we tested:
  • Decklink Extreme 3
  • Decklink Duo
Other models should work as long as they are supported by the 12.x drivers.
Drivers
Ventuz Desktop Video Driver Comment
8.00.00 12.7.1
6.12.00 12.4.0 Major version bump, 12.x driver required
6.08.00 11.4.1
6.06.00 11.4.1 Major version bump, 11.x driver required
6.00.00 10.8.4 fixes for Windows 10 anniversary update
5.00.00 10.3.1 Major version bump, 10.x driver required
4.00.00 9.7.7
You can download the drivers directly from Black Magic Design at ​https://www.blackmagicdesign.com/support/family/capture-and-playback
The 8K Pro is currently the most powerful SDI board by BMD with 4 individually configurable 12G SDI jacks.
Please mind the following when trying to configure it:
  • Configure Keying and dual link streams first.
  • Dual link output is only supported on ports 3/4, input on ports 1/2
  • Keying only works for single link streams, including 12G single link streams. You will have two single link jacks used.
  • The supported keying streams are external hardware keying, internal hardware keying and external chroma keying simple.
Extreme Series
Very old boards, like the Extreme 3d, can only have input or output, not both at the same time. All models currently on sale support simultanous input and output.
This does not apply to the duo / quad boards and the 8K Pro.
Configuration
When getting video from HDMI / DVI inputs, you must specify if the input is in RGB 4:4:4: or YUV 4:2:2. This is done with the board options. When using autodetect, this will be done automatically.
Datapath
​Datapath VisionRGB
VisionAV
VisionSC
Supported Models
We explicitly tested the following bords
  • VisionLC-HD2
  • VisionLC-SDI
  • VisionSC-DP2
  • VisionSC-HD4+
  • VisionAV-SDI
  • VisionAV-HD
  • VisionRGB-E1
Other bords from the VisionRGB / VisionAV / VisionSC series should also work.
Unsupported Models
We only support datapath capture boards, no graphics boards.
Drivers
Ventuz 4 Ventuz 5 Ventuz 6 Ventuz 7 Ventuz 8 Driver SC / AV / RGB Driver LC
6.06.00 7.00.00 8.00.00 7.20.35001.1 1.2.4.35006
4.05.00 5.00.00 6.00.00 7.11.0.1028
DVS
​DVS Centaurus II (LT)
Atomix series
Supported Models
  • Both Centaurus II and Centaurus II LT are supported
  • Internal hardware keying is supported (not LT)
  • The internal keyer can only operate in multiplicative mode
  • RS422 and GPI is not supported
  • On some rare mainboards, the internal hardware keying of Centaurus II is faulty. This can be fixed by setting Board Format to RGBA 8 in the Advanced Options. This setting has the same speed but lower quality as Quality , so it should only be used to fix mainboard incompatibility issues.
  • The Firmware version for an Centaurus II should be 3.2.76.7_19_15
Atomix Series
  • Internal hardware keying is not supported.
  • When using any SDI-3G formats, only one input and one output is available.
  • When you put an input in auto-detect mode and want to receive 3G or dual link signals, you need to manually set the board option "Multi Channel" to off. This will be done automatically if you specify one of these modes directly, but it won't happen if you use auto-detect.
  • The Firmware version for an Atomix LT should be 5.4.0.19_5.2.7
Drivers
6.08.00 7.00.00 8.00.00 deprecated
4.00.00 5.00.00 6.00.00 4.3.5.10
NewTek
​NewTek iVGA/AirSend
NDI (Network Device Interface)
iVGA / AirSend
1. http://127.0.0.1:49480/AirSend.mpg
2. http://127.0.0.1:49481/AirSend.mpg
NDI
Formats
Ventuz supports NDI, NDI HX and NDI HX2. The Image format is totally Size/Aspect independent. For further and latest informations about NDI please visit the ​Wikipedia NDI page.
Key+Fill
Possible amount of Inputs
Possible amount of Outputs
This depends on the license you have. Only the Enterprise license supports four outputs. All others can only have one NDI output. The maximum output resolution is limited by the License only. Please see the ​Edition Comparisons for reference.
Usefull Information
Syncing / Frame Locking
  • Set the In and Output to "Low Latency"
  • Only Set the Input to synchronized
​Windows Media Foundation
​AWS CDI
CDI is not enabled in every Ventuz Edition. Check our website for further information or get in contact with our sales team (​sales@ventuz.com)
GPUs
AMD
​AMD Radeon Pro Series (recommended)
FirePro Series (recommended)
Radeon Series (with limitations)
Ventuz supports the ​ATI FirePro™ S400 Synchronization Module to synchronize multiple GPU's in a cluster of Ventuz installations.
Nvidia
​Nvidia Quadro Series (recommended)
Geforce Series (with limitations)
Ventuz supports the ​Quadro Sync and ​Quadro G-Sync boards to synchronize multiple GPU's in a cluster of Ventuz installations
The ​NVIDIA Quadro Digital Video Pipeline is not supported by Ventuz. The SDI output of these board family can be used as monitor output. External key, Audio and other features of this product line are not address by Ventuz.
Intel
​Intel Intel integrated graphics
Other
​Direct3D Windows compatible graphics board
Vendor Input Output
Aja X X
Black Magic X
Deltacast X
​Trackmen
​Egripment
​Trackmen Products
NCam
​NCam NCam
Stype
​Stype Kit Stype Kit
Mo-Sys
​Mo-Sys StarTracker StarTracker
​Video
We introduced built-in support for Head Mounted Displays (HMD) such as ​HTC-Vive and ​Oculus Rift. See the related How To for more detailed information.
HTC Vive
HTC Vive integrated through Open VR
Oculus Rift
Oculus Rift integrated through Open VR
Other
GPI Boards
At the time of writing Ventuz supports the ​DLP Design IO8 and the ​Numato 16 Channel USB GPIO boards.
  • Video Engine
