Data Rate | SMPTE | Links | Resolution, Maximal Framerate, Description | ||||
270 Mb/s | 525i60, 625i50 | ||||||
ST 259 | SD | full raster | |||||
1.5 Gb/s | 1080i60, 1080p30, 720p60 | ||||||
ST 292-1 | HD | full raster | |||||
3.0 Gb/s | 1080p60 | ||||||
ST 425-1 | 3GA | LevelA : full raster | |||||
ST 372 | 2xHD | interleaved lines | |||||
ST 425-1 | 3GB | LevelB : 3G link carries a HD Dual Link stream muxed | |||||
6.0 Gb/s | 2160p30 | ||||||
none | 4xHD | image quadrants | |||||
ST 425-3 | 2x3GB | 2x 3G Level B-DS links carry 4 HD streams as two samples interleaved | |||||
ST 2081-10 | 6G | full raster | |||||
12.0 Gb/s | 2160p60 | ||||||
none | 4x3GA | image quadrants | |||||
ST 425-5 | 4x3GA | 4 3G links as two samples interleaved | |||||
ST 2081-11 | 2x6G | interleaved pixels across 2 streams | |||||
ST 2082-10 | 12G | full raster | |||||
24.0 Gb/s | 4320p30 | ||||||
none | 4x6G | image quadrants | |||||
ST 2081-12 | 4x6G | interleaved pixels across 4 streams | |||||
48.0 Gb/s | 4320p60 | ||||||
none | 4x12G | image quadrants | |||||
ST 2082-12 | 4x12G | interleaved pixels across 4 streams |
Format | SD | 1080i60 | 1080p60 | 2160p30 | 2160p60 | 4320p30 | 4320p60 | |||||||||
Links | SD | HD | 2xHD | 3G A | 3G B | 4xHD | 2x3G B | 6G | 4x3G A | 4x3G A | 2x6G | 12G | 4x6G | 4x12G | ||
SMPTE ST | 259 | 292-1 | 372 | 425-1 | 425-1 | none1 | 425-3 | 2081-10 | none1 | 425-52 | 2081-11 | 2082-10 | none1 | 2081-12 | none1 | 2081-22 |
Deltacast | ||||||||||||||||
DELTA-12G1c-hmi10-elp | X | X | - | X | X | no key3 | no key3 | no key3 | no key3 | no key3 | - | no key3 | - | - | - | - |
DELTA-12G-ELP-H-4C | X | X | - | X | X | no key3 | no key3 | no key3 | no key3 | no key3 | - | no key3 | X | - | X | - |
DELTA-12G-ELP-H-2C | X | X | - | X | X | no key3 | no key3 | no key3 | no key3 | no key3 | - | no key3 | - | - | - | - |
DELTA-3G-elp-key-d 4k | X | X | X | X | X | X | X | - | X | X | - | - | - | - | - | - |
DELTA-3G-elp-key-d 2k | X | X | x | X | X | X | X | - | - | - | - | - | - | - | - | - |
DELTA-3G-elp-d 4c/8c | X | X | X | X | X | no key3 | no key3 | - | no key3 | no key3 | - | - | - | - | - | - |
DELTA-3G-elp-2key-d 22/44 | X | X | X | X | X | X | X | - | - | - | - | - | - | - | - | - |
DELTA-3G-* | X | X | - | X | X | - | X | - | - | - | - | - | - | - | - | - |
DELTA-HD-e-key 22/11 | X | X | - | - | - | - | - | - | - | - | - | - | - | - | - | - |
DELTA-HD-ELP-D-44/80 | X | X | X | - | - | X | - | - | - | - | - | - | - | - | - | - |
DELTA-HD-* | X | X | - | - | - | - | - | - | - | - | - | - | - | - | - | - |
FLEX-12G 10 01 | X | X | - | X | X | no key3 | no key3 | no key3 | no key3 | no key3 | - | no key3 | - | - | - | - |
FLEX-3G 40 04 | X | X | X | X | X | - | - | - | no key3 | no key3 | - | - | - | - | - | - |
Black Magic Design | ||||||||||||||||
Decklink 8K Pro | X | X | no key3 | X | X | - | no key3 | X | - | - | - | X | - | X | - | X |
Decklink 4K Extreme 12G | X | X | no key3 | X | X | - | no key3 | X | - | - | no key3 | X | - | - | - | - |
Decklink 4K Extreme | X | X | no key3 | X | X | - | no key3 | X | - | - | out only | - | - | - | - | - |
Decklink HD Extreme 3 | X | X | - | X | X | - | - | - | - | - | - | - | - | - | - | - |
Decklink Duo/Quadro 2 | X | X | - | X | X | - | - | - | - | - | - | - | - | - | - | - |
Decklink Mini Monitor 4K | X | X | - | X | X | - | - | X | - | - | - | - | - | - | - | - |
Decklink Mini Recorder 4K | X | X | - | X | X | - | - | X | - | - | - | - | - | - | - | - |
UltraStudio HD Mini | X | X | - | X | X | - | - | - | - | - | - | - | - | - | - | - |
Aja | ||||||||||||||||
Kona 5 | support on request | |||||||||||||||
Kona 4 | X | X | - | X | X | no key3 | no key3 | - | no key3 | no key3 | - | - | - | - | - | - |
Kona 3 | X | X | - | X | - | - | - | - | - | - | - | - | - | - | - | - |
Kona LHi | X | X | - | X | - | - | - | - | - | - | - | - | - | - | - | - |
Kona LHe+ | X | X | - | - | - | - | - | - | - | - | - | - | - | - | - | - |
Corvid 88 | X | X | - | X | X | X | X | - | X | X | - | - | - | - | - | - |
Io 4K | X | X | - | X | X | no key3 | no key3 | - | no key3 | no key3 | - | - | - | - | - | - |
Io XT | X | X | - | X | - | - | - | - | - | - | - | - | - | - | - | - |
Datapath | ||||||||||||||||
Vision LC SDI | X | X | - | X | X | - | - | - | - | - | - | - | - | - | - | - |
Vision AV SDI | X | X | - | X | X | - | - | - | - | - | - | - | - | - | - | - |
Boards are also limited by the number of connectors and capabilies from the table below. For instance, a Delta-3G 11 with one input and one output can not do key+fill because that would require two outputs, and it can not do internal hardware keying because in the table below it says that "DELTA-3G-*" boards can not do internal hardware keying.
Feature summary and exlenation of sortcuts:
Deltacast | |||||||||||||||||
Series / Model | audio | autodetect | k+f | keyer | duplex | multiformat | bypass | Timecode | AFD | Tracking | FG/BG/GM | Specials | |||||
DELTA-12G-* | yes | yes | yes | - | yes | timebase | - | yes | yes | yes | yes | softkey | |||||
DELTA-3G-elp-key-d 4k | yes | yes | yes | yes | yes | timebase | (yes)6 | yes | yes | yes | yes | softkey, key-input, key-delay | |||||
DELTA-3G-elp-key-d 2k | yes | yes | yes | yes | yes | timebase | (yes)6 | yes | yes | yes | - | softkey, key-input, key-delay | |||||
DELTA-3G-elp-d 4c/8c | yes | yes | yes | - | yes | timebase | - | yes | yes | yes | yes | softkey | |||||
DELTA-3G-elp-2key-d 22/445 | yes | yes | yes | yes | yes | timebase | yes | yes | yes | yes | - | softkey, key-input, key-delay | |||||
DELTA-3G-* | yes | yes | yes | - | yes | timebase | - | yes | yes | yes | yes | softkey | |||||
DELTA-hd-e-key 22 | yes | yes | yes | yes | yes | timebase | yes | yes | yes | yes | - | softkey, key-input, key-delay | |||||
DELTA-hd-e-key 11 | yes | yes | - | yes | yes | timebase | yes | yes | yes | yes | - | softkey, key-input | |||||
DELTA-HD-* | yes | yes | yes | - | yes | timebase | - | yes | yes | yes | yes | softkey | |||||
FLEX-12G 10 01 | yes | yes | - | - | - | timebase | - | yes | - | - | - | ||||||
FLEX-3G 40 04 | yes | yes | - | - | - | timebase | - | yes | - | - | - | ||||||
DVS | |||||||||||||||||
Centaurus II1 | yes | yes | yes | yes2 | yes | full | yes | yes | yes | - | - | softkey | |||||
Centaurus II LT1 | yes | yes | - | - | yes | full | yes | yes | yes | - | - | softkey | |||||
Atomix1 | yes | yes | yes | - | yes | full | yes | yes | yes | - | - | softkey | |||||
Blackmagicdesign | |||||||||||||||||
Decklink 8k Pro | yes | yes | yes | yes2 | yes | yes | - | yes | - | yes | yes | RGB444 | |||||
Decklink 4k Extreme 12G | yes | yes | yes | yes2 | yes | - | - | yes | - | yes | - | RGB444 | |||||
Decklink 4k Extreme | yes | yes | yes | yes2 | yes | - | - | yes | - | yes | - | RGB444 | |||||
Decklink Extreme 3D3 | yes | yes | yes | yes2 | - | - | - | yes | - | - | - | ||||||
Decklink Duo/Quad 2 | yes | yes | yes | yes2 | yes | yes | - | yes | - | yes | yes | RGB444 | |||||
Decklink Duo/Quad | yes | yes | - | - | - | - | - | yes | - | yes | - | will appear as multiple devices | |||||
Decklink Mini Monitor 4k | yes | yes | - | - | yes | - | - | yes | - | - | - | RGB444 | |||||
Decklink Mini Recorder 4k | yes | yes | - | - | yes | - | - | yes | - | - | - | RGB444 | |||||
UltraStudio HD Mini | yes | yes | yes | yes | yes | - | - | yes | - | - | - | ||||||
Datapath | |||||||||||||||||
VisionLC-SDI | - | - | - | - | - | - | - | - | - | - | - | ||||||
VisionSC-SDI4 | - | - | - | - | - | - | - | - | - | - | - | ||||||
VisionSC-HD4+ | - | - | - | - | - | - | - | - | - | - | - | ||||||
VisionAV-SDI2 | - | - | - | - | - | - | - | - | - | - | - | ||||||
AJA | |||||||||||||||||
Kona 5 4K | yes | yes | yes | yes | yes | - | - | - | - | yes | yes | ||||||
Kona 5 8K | yes | yes | yes | - | yes | - | - | - | - | yes | yes | ||||||
Kona 4 | yes | yes | yes | yes | yes | - | - | - | - | yes | yes | ||||||
Kona 3G | yes | yes | yes | yes | yes | - | - | - | - | yes | - | ||||||
Kona LHi | yes | yes | - | yes | yes | - | - | - | - | yes | - | ||||||
Kona LHe+ | yes | yes | yes | yes | yes | - | - | - | - | yes | - | ||||||
Corvid 88 | yes | yes | yes | yes | yes | - | - | - | - | yes | yes | ||||||
Io 4K4 | yes | yes | yes | yes | yes | - | - | - | - | yes | yes | ||||||
Io XT | yes | yes | yes | yes | yes | - | - | - | - | yes | - |
Limitations:
Some lines in the table describe a whole category of products. If a certain option requires more jacks than the board offers, the mode is obviously not supported. For instance, a blackmagic decklink board with only one output can not support key+fill, while it's larger brother with two outputs will.
![]() | Deltacast | HD / 3G / 12G Series KEY Series DVI / H4k Series FLEX Series |
Recommended boards
Supported FLEX modules
Current Versions
Ventuz 6 | Deltacast Driver Packet | Note |
6.08.00 | 6.15.1 or 6.13.1 | introduced dual drivers |
6.06.00 | 6.13.1 | |
6.04.01 | 6.8.1 patch 3 | patched driver, "v6.08.01_h4k2_EDID_Build3" |
6.02.00 | 6.8.1 patch 2 | patched driver, "v6.08.01_h4k2_EDID_Build_2" |
You can download the driver from the Ventuz support website at http://www.ventuz.com/drivers.
Some versions use a patched version of the driver which is not available from the Deltacast website. Please always use the drivers in the driver folder of the Ventuz installation directory and not the drivers from the deltacast website.
Dual Drivers
As of Ventuz 6.8, Ventuz will detect the installed drivers for deltacast boards and then choose the correct Deltacast SDK libraries.
If you have one of the old boards that are not supported by the latest deltacast SDK, install 6.13.1 drivers for all boards. Otherwise install 6.15.1 drivers for all boards, as that will have significantly better performance. Ventuz will then load the correct SDK libraries.
If you have multiple deltacast boards and mix 6.13.1 and 6.15.1, Ventuz will load 6.15.1 libraries and the boards using 6.13.1 are not usable. Boards with any other driver will also be not usable.
So be aware mixing boards that require old drivers (like the DELTA-HD-e-key 22) and new boards that only work with 6.15.1 drivers (like DELTA-12G1c-hmi10-elp).
Older Versions
For older deltacast vesions, the driver version displayed by the windows device manager has nothing to do with the Deltacast driver package version, also the driver version will be completely different depending on the kind of board. Here is a "decoder table":
Ventuz 4 | Ventuz 5 | Ventuz 6 | Deltacast Driver Packet | HD/Gen1 | 3G/Gen2 | DVI/HDMI | Note |
5.09.01 | 6.0 patch | 5.4.150.0 | 6.0.1.0 | 5.3.62.0 | patched driver, "v6.00_Fix4cKill_Build1" | ||
4.09.00 | 5.03.00 | 6.00.00 | 6.0 | 5.4.150.0 | 1.0.309.0 | 5.3.62.0 | |
4.08.00 | 5.00.00 | 5.19 patch | 5.4.133.0 | 1.0.231.0 | 5.3.47.0 | ||
4.06.00 | 5.17 | 5.4.125.0 | 1.0.151.0 | 5.3.42.0 | |||
4.05.02 | 5.16 patch | 5.4.124.0 | 1.0.138.0 | 5.3.41.0 | patched driver, "v5.16_Timeout_Ventuz_RC3.1" | ||
4.05.00 | 5.16 | 5.4.121.0 | 1.0.138.0 | 5.3.41.0 | |||
4.04.00 | 5.15 | 5.4.112.0 | 1.0.125.0 | 5.3.36.0 | |||
4.01.00 | 5.14 | 5.4.91.0 | 1.0.71.0 | 5.3.28.0 | |||
4.00.00 | 5.13 | 5.4.79.0 | 1.0.44.0 | 5.3.24.0 |
Internal Keying
The DELTA-3G-elp-key 2K board is a full replacement for the good old DELTA-hd-e-Key 22.
The only board that can do 4k 60Hz SMPTE ST 425-5 (aka 2si) external keying is the DELTA-3G-elp-key 4K.
Genlock Offset
It is possible to use a different video format for the genlock signal then for the output that is to be synchronized, as long as the refresh rate is the same. For instance, using PAL as genlock and 720p50 as output is ok. But notice that for deltacast boards, the video format of the output defines the units for the genlock offset: changing the genlock by one line will change the genlock by one line in 720p, not one line in PAL. This also works with genlock format set to auto, since the video format of the output stream is always known. If multiple outputs with different video format are defined, the effect of the genlock offset is unspecified.
DVI / HDMI / DisplayPort Capture Boards
Memory Pre-Allocation
[http://ventuz.com/sites/default/files/downloads/files/drivers/deltacast_mem_pre_alloc.zip download] this registry file from www.ventuz.com
![]() | AJA | Kona / Corvid |
The following board configurations are supported on request:
This means that the board generally works with standard Venutz, but there are complicated limiations, please check with us.
Ventuz 4 | Ventuz 5 | Ventuz 6 | Driver |
6.08.00 | 15.5.3.1 | ||
6.06.00 | 15.5.1.2 | ||
4.05.00 | 5.00.00 | 6.00.00 | 12.0.0.123 |
AJA and Firmware Updates
Problems Installing Drivers
![]() | Black Magic Designs | Decklink series Intensity series UltraStudio series |
Legacy models that we tested:
Other models should work as long as they are supported by the 11.x drivers.
We recommend you use the driver we used during testing. Using a different driver usually works as long as the major version number is the same (11.x.x)
Ventuz 4 | Ventuz 5 | Ventuz 6 | Desktop Video Driver | Comment |
6.08.00 | 11.4.1 | |||
6.06.00 | 11.4.1 | Major version bump, 11.x driver required | ||
5.03.00 | 6.00.00 | 10.8.4 | fixes for Windows 10 anniversary update | |
4.04.00 | 5.00.00 | 10.3.1 | Major version bump, 10.x driver required | |
4.00.00 | 9.7.7 |
You can download the drivers directly from Black Magic Design at https://www.blackmagicdesign.com/support/family/capture-and-playback
Multi-Stream:
BlackMagic frequently updates their product lineup.
Most BMD boards only support one input and one output stream, and before the "4k" series not even at the same time. Even if a board has 2 or 4 jacks you can have only one input and one output stream at a time, the additional jacks are for key+fill output or for multi-link streams like HD-dual link or SMPTE 425-3 3G-LevelB dual link.
The exception are the Decklink Duo / Decklink Quad boards. The first generation of these boards support two or four independent channels. Still they can not be used to create key+fill because each channel is independent and can not be used in a dual link mode. Also, you can not have input and output of a channel operate at the same time.
The second generation Decklink Duo 2 / Decklink Quad 2 are versatile boards. The duo has four and the quad has eight jacks that can be individually used as input or output. Each pair of jacks can be used for internal and external keying. Still, you can not bundle 4 strams as quad link 4k.
Keying and video format:
Not all boards support internal and external keying for all video formats. See the big vendor table above for details.
When getting video from HDMI / DVI inputs, you must specify if the input is in RGB 4:4:4: or YUV 4:2:2. This is done with the board options. When using autodetect, this will be done automatically.
![]() | Datapath | VisionRGB VisionAV VisionSC |
We explicitly tested the following bords
Other bords from the VisionRGB / VisionAV / VisionSC series should also work.
We only support datapath capture boards, no graphics boards.
Ventuz 4 | Ventuz 5 | Ventuz 6 | Driver SC / AV / RGB | Driver LC |
6.06.00 | 7.20.35001.1 | 1.2.4.35006 | ||
4.05.00 | 5.00.00 | 6.00.00 | 7.11.0.1028 |
![]() | DVS | Centaurus II (LT) Atomix series |
Atomix Series
6.08.00 | deprecated | ||
4.00.00 | 5.00.00 | 6.00.00 | 4.3.5.10 |
![]() | NewTek | iVGA/AirSend NDI (Network Device Interface) |
![]() | Windows Media Foundation |
![]() | AMD | Radeon Pro Series (recommended) FirePro Series (recommended) Radeon Series (with limitations) |
![]() | Nvidia | Quadro Series (recommended) Geforce Series (with limitations) |
The NVIDIA Quadro Digital Video Pipeline is not supported by Ventuz. The SDI output of these board family can be used as monitor output. External key, Audio and other features of this product line are not address by Ventuz.
![]() | Intel | Intel integrated graphics |
![]() | Direct3D | Windows 7 compatible graphics board |
![]() | Trackmen Egripment | VioTrack TorqTrack ManuTrack |
![]() | NCam | NCam |
![]() | Stype Kit | Stype Kit |
![]() | Mo-Sys StarTracker | StarTracker |
![]() | HTC Vive integrated through Open VR |
![]() | Oculus Rift integrated through Open VR |
