Ventuz 6 Quick Guide
  • Ventuz 5 Migration Guide
Ventuz 6 Designer
Ventuz 6 Node Reference
Ventuz 6 Director
  1. Displays
    1. Performance
      1. History Mode and Pause
      2. Interpreting GPU Measurement
      3. Accumulated Bars Versus Detailed Timeline
      4. Performance Impact of Measurement
    2. System Information
    3. GPU Information
    4. AV Inputs / Outputs
    5. Movies
    6. Tracking
    7. Layer Processing
    8. Watches
  2. Logging
    1. Markup in Logging
    2. Logging Limits
  3. Performance Measurement via Script
    1. Logging
    2. Performance Timing
    3. Example
    4. Scale To Preview
  4. Interpreting the Performance Timing
    1. The Relation Between Main Thread and CPU Percentage
    2. Monitoring Movie Playback Performance
    3. Why is my Audio Delay so big?
  5. Explanation of the Various Bars
Performance Statistics
The performance statistics is a display rendered above the Ventuz output. It can be enabled from the designer or the live options to analyze performance problems in a scene. This has been enhanced as of Ventuz 4.04.00.
Displays
The performance statistics contain a lot of information. In many cases displaying it all can be a bit overwhelming and requires a lot of screen real-estate. So individual sections can be enabled and disabled and with the Frame Count the amount of visible frames can be adjusted:
With all sections enabled, it can looks like this:
Here is an explanation of these sections. This is done with the drop-down button.
Performance
In general:
System Information
Note that the GPU Cloclk field shows the frequency of the core not that of the memory. It can go beyond 100% when overclocking the GPU.
GPU Information
Dynamic Geometry: Ventuz will do some FastUploads for interal purposes. When a geometry is animated by binding it, this will issue a SlowUpload when a value changes. How slow such an update is depends on how complex the vertex format is: Most vertex formats will undergo no conversion or a QuickVertexConvert. Sometimes a SlowVertexConvert has to be done, this should be avoided on animated geometries.
Creation Calls are an exceptionally expensive part of the DirectX API and should only happen during scene loading.
Persistent Resources are resources that accumulate and are never deleted until Ventuz is quit. VertexFormats and VertexConverters are cheap internal resources that should stay below 25. Shaders is the number of different shaders that have been used since Ventuz started.
GPU Memory: this shows how GPU memory is divided into geometry (vertex and index buffers), textures and Color/Depth Target (textures used as rendertarget or depth buffer).
AV Inputs / Outputs
The states mean:
  • Running: stream is running
Movies
The states are:
  • error: the stream failed
  • busy: Internal operation
  • empty: No file was loaded
  • loadmeta: loading metadata
  • loadinfo: prepare playback
  • active: normal playback
  • pause: playback is paused
  • seek: seeking
The buffers show how many buffers Ventuz has allocated and how many frames in the future are available. If these buffers run dry, increase the number of buffers for that movie. At the end of each line you can see the exact Cluster Clock when each Movie Started. Like the lead this is mainly useful to check syncronization of movies in a cluster.
Tracking
Layer Processing
Each line represents:
  • rendering a scene
Watches
Logging
Markup in Logging
Logging Limits
Logging
Performance Timing
using(Script1.MeasureCpu)
Example
Here is a complete example:
using System;
using Ventuz.Kernel;
using Ventuz.Kernel.Tools;
    private bool changed;
    public Script()
    public virtual void Dispose()
        changed = true;
    public bool OnEnable(int arg)
	return false;
	return false;
        if (changed)
            changed = false;
            return true;
        return false;
Scale To Preview
  • The CPU percentage includes all video decoding.
  • The status of each movie player can be displayed. Check if there are more active movie players than expected, or if movie players are switched on and off unnecessarily.
  • Transfering the image from the CPU where it is decoded to the GPU and performing the color space conversion takes some time on the GPU, displayed as dark-green bar in the performance timing.
  • Most likely the input is set to "autodetect". So Ventuz must assume the longest possible frame to buffer.
  • If the framerates match perfectly, the buffer must hold exactly one frame. If they don't match, the buffer must hold the duration of both input plus output frame to handle worst case scenarios.
  • If the input has the same framerate as the output, is genlocked, and set to synchronous, the delay will be either 2 or 0 samples.
  • If the framerate is a 1000/1001 timing like 59.94 Hz (drop frame timing), a 2 samples buffer must be inserted because input and output might in a different phase when it comes to audio-frame lengths.
  • When using Blackmagic boards, an extra video-frame of audio-delay is inserted. this is because unlike all other supported vendors, the Blackmagic SDK handles audio and video with separate timing.
So for shortest delays:
  • don't use autodetect, specify video format manually
  • have input and output at the same frame-rate (but may be different resolution)
  • genlock input and output and set input to "synchronized"
  • If you have the choice, use a timing without drop-frames.
Red(ish): Validation
  • Validation : update bindings and nodes
    • ContentValidation : content nodes
    • HierarchyValidation : hierarchy nodes
  • ResourceLoad : Sending resources (Texture, Geometry) from CPU to GPU.
Green(ish): Rendering
  • RenderSetupBegin : Overhead before rendering can start
  • RenderSetupEnd : Overhead after rendering has finished. This includes Warping.
  • Render : walk the hierarchy nodes and find out what needs to be rendered (recording)
    • Main : render the recording for the main rendering pass
    • Mirror : render the recording for simple mirrors (no rendertarget)
    • FxMirror : render the recording for effect mirrors (with rendertarget)
    • CubeReflection : render the recording 6 times to build a cubemap reflection
    • Shadowmap : render the recording for spot and directional shadows
    • PointShadowmap : render the recording 6 times to build a cube-shadow-map.
    • BoundBoxCalculation : bounding box calculation needed to determinate the size of directional shadowmaps.
  • Glow : Glow node
  • BlurTextureSimple : Blur Texture Simple node
  • HLSLShader: HLSL Shader node
  • TextRendering: Text nodes
  • MovieClip : CPU to GPU transfer and color space conversion during movie replay
Blue(ish): Idle
  • Present: wait for next frame.
  • PreventD3DQueuing: wait for GPU to prevent the GPU from queuing up multiple frames.
  • ResourceLock : wait for GPU to have access to some GPU resource (Texture, Geometry)
  • Blit : A CPU stall that can occur in RenderSetupEnd. This is just an artifact of the measurement method.
  • HardGpuStall : force synchronization of CPU & GPU when GPU Stall option is enabled.
  • BeginVideo : waiting for video at the start of a frame
  • EndVideo : waiting for video at the end of a frame
Yellow(ish): Postprocessing
  • PreparePostProcess: Analyze effects & layers and figure out how to combine various shaders
  • PostProcess: actually execute the postprocessing
  • Some postprocessing shaders take longer than others and are marked individually
    • Blur: Shaders in postprocessing that blur the image
    • Downsample: Shaders in postprocessing that downsample the image to trade of quality for speed for the blurring.
    • DoF: Shaders that implement depth of field.
  • ResourceGen : A resource gets update, and is none of the below:
  • TextureResourceGen : Texture resource update
  • TextResourceGen : Text resource update : this happens when text or layout changes
  • GeometryResourceGen : Geometry resource update
  • XMLResourceGen : XML/XPath/XSLT resource update
  • ShaderResourceGen : Shader resource update
Video Process:
  • InputHandling : Processing for Inputs, excluding DMA and colorspace conversion
  • InputDma : DMA transfer for input streams
  • InputColorSpace : Color space conversion for input streams
  • OutputHandling : Processing for Outputs, excluding DMA and colorspace conversion
  • OutputDma : DMA transfer for output streams
  • OutputColorSpace : Color space conversion for output streams
  • EndFieldGpuStall : Synchronization between CPU and GPU at the end of a frame
  • WaitForFrame : Processing during waiting for frame (for all streams)
  • Wait : Idle time during waiting for frame (this time is used by other threads)
  • FinishFrame : Processing at the end of a frame (for all streams)
Other
  • Runtime (gray) : The Ventuz Runtime. All major processing should have it's own color, this catches smaller tasks that seemed unimportant to measure individually
  • no bar (transparent) : When in Accumulated Bars mode, the times do not add up to 100%. These gaps are time spend with other processes or in the user interface. Especially in the designer, a lot of time may be spend in the user interface when there is mouse-movement.
  • InputProcessing (gray) : processing of touch events.
  • PerfMon (gray) : performance monitor rendering.
