3D Layer Reference
  1. Properties
  2. Limitations
  3. Common Layer Properties
    1. Blending
      1. Mode
      2. Opacity
      3. Blocked
      4. BlockedOnFullTransparency
      5. Layer Mask
        1. Mask
        2. Texture Loader
        3. Loader
        4. IPP
        5. Lighting and Shaders
          1. Lighting
          2. Shaders
        6. Texture Property
        7. 1D Gradient
        8. SVG Loader and SVG Text
        9. Other
        10. Texture Array Loaders
          1. Flipbook Loader
          2. Strip Loader
        11. Flipbook
        12. QR Code Generator
          1. Mask Properties
        13. Mask Vignette
        14. Mask Border
    2. Layout
    3. Mapping
    4. Effects
      1. Blending
      2. Mask
    5. Mask Self
      1. Effect
      2. Effect Group
      3. Color Correction
      4. Filters
      5. Distortion
    6. Layer
3D ReferenceThis Layer Renders another 3D Layer a second time, but with the possibility to use another Layout, Camera, IPP Effects, Mask etc.
Properties
Limitations
Blending
Blending
Mode
Opacity
Blocked
Layer Mask
Mask
Texture Source
Texture Loader
Texture Loader Presets
Loader
Image/Texture
Description
Internal resource name
Image/Texture
Description
Shape Circle
Shape Triangle
Shape Pentagon
Shape Cross
Spike Star
Checker
internal://images/checker.png
Checker Blue
Checker Dots
internal://images/dots.png
Lines
internal://images/lines.png
Noise
internal://images/noise.png
Alpha Glow Full
Alpha Glow Half-Full
Alpha Glow
Alpha Glow Half-Sharp
Alpha Glow Sharp
Dimple
internal://images/dimple.png
Pimple
internal://images/pimple.png
Liquid
internal://images/liquid.png
Woodchip
IPP
Image/Texture
Description
Image/Texture
Description
Lensflare Ghost Colors
Lensflare Star
Lensflare Dirt
Lighting
Image/Texture
Description
Image/Texture
Description
Incidence 1D Lambert
Incidence 1D Rainbow
Incidence 1D Specular
Incidence 2D Smooth
Incidence 2D Steps
Incidence Diffuse
Incidence Diffuse Anisotropy
Incidence Specular
Incidence Blue Back
Celshading Steps
Shaders
Image/Texture
Description
Image/Texture
Description
Hatch Lines
Hatch Curves
Hatch Letters
Texture Property
1D Gradient
Gradient Presets
SVG Loader Presets
Other
Image/Texture
Description
Ventuz Logo SVG
internal://images/ventuz.svg
Flipbook Loader
Strip Loader
Gradient Presets
Flipbook
Image/Texture
Description
Flipbook Clock
QR Code Generator
ECC Level
  • Level L ~7%
  • Level M ~15%
  • Level Q ~25%
  • Level H ~30%
Mask Properties
Mask Vignette
Mask Border
Layout
Mapping
Effects
Blending
Mask
Mask Self
Effect
Effect Group
Color Correction
Filters
Distortion
Layer
  • 3D Layer Reference Filter Node
