The Encoded Stream Out outputs provide a simple pipe based streaming protocol to other processes running on the same machine. This way 3rd party applications can process or distribute the video coming out of Ventuz in real time.
There is a comprehensive example, client library and test application, written in C#, on GitHub here: https://github.com/VentuzTechnology/StreamOutExample
Ventuz makes the encoded streams available to other processes via a named pipe. These processes will need the proper permissions to access the pipe (usually this means running as the same user or at a higher privilege level than the Ventuz runtime).
The pipe's name is VentuzOutA for the first output and B etc. for any additional outputs. Ventuz accepts an arbitrary number of connections to the named pipes, so for example a stream server can choose whether to handle multiple incoming connections itself or to connect to the pipe once per client served.
| offset | type | description |
| +00 | FourCC | Chunk type |
| +04 | uint32 | Chunk size in bytes |
| +00 | uint32 | Protocol version |
| +04 | FourCC | Video format |
| +08 | uint32 | Video width (pixels) |
| +12 | uint32 | Video height (pixels) |
| +16 | uint32 | Video frame rate numerator |
| +20 | uint32 | Video frame rate denominator |
| +24 | FourCC | Audio format |
| +28 | uint32 | Audio sample rate (Hz) |
| +32 | uint32 | Audio channel count |
Notes:
| +00 | uint32 | Frame index |
| +04 | uint32 | Frame flags |
| value | description |
| 0x00000001 | This video frame is an IDR frame |
This chunk contains exactly one frame worth of encoded video. If the IDR frame flag is set in the frame header it's guaranteed that this frame contains everything that's needed to start or restart a video stream, i.e. Sequence and Picture information, and no reference to past frames.
| byte | followed by | description |
| 0x00 | - | No operation |
| 0x01 | - | Request IDR frame |
| 0x10 | Touch parameters | Begin Touch |
| 0x11 | Touch parameters | Move Touch |
| 0x12 | Touch parameters | End Touch |
| 0x13 | Touch parameters | Cancel Touch |
| 0x20 | Unicode character (uint32) | Key Pressed |
| 0x21 | VirtualKey code (uint32) | Key Down |
| 0x22 | VirtualKey code (uint32) | Key Up |
| 0x28 | Mouse XY parameters | Mouse position |
| 0x29 | Mouse Button parameters | Mouse buttons |
| 0x2a | Mouse XY parameters | Mouse wheel |
| 0x30 | Encode parameters | Set encode parameters |
This command instructs the encoder inside Ventuz to emit an IDR frame. Due to the asynchronous nature of the encoding process this may take a frame or two; don't assume the frame received right after sending this command will already be an IDR one.
| +00 | uint32 | Touch ID |
| +04 | int32 | X coordinate (pixels from left side of viewport) |
| +08 | int32 | Y coordinate (pixels from upper side of viewport) |
Clients can inject text characters with the Key Pressed command followed by this structure:
| +00 | uint32 | UTF32 codepoint |
Control keys that correspond to control characters such as Backspace or Enter will also work.
Alternatively, clients can use the Key Up and Key Down events that supply a Windows VirtualKey as described in https://learn.microsoft.com/en-us/windows/win32/inputdev/virtual-key-codes
| +00 | uint32 | VirtualKey code |
Injecting mouse updates works with these three messages:
A mouse position update has the following parameters:
| +00 | int32 | X coordinate (pixels from left side of viewport) |
| +04 | int32 | Y coordinate (pixels from upper side of viewport) |
Any X or Y values outside the viewport (such as negative values) will also be treated as the mouse leaving the window or output.
A mouse button update updates all buttons at once. The message payload looks like this:
| +00 | uint32 | Buttons bitfield |
The buttons bitfield is the logical addition of all currently pressed buttons.
| bit | value | description |
| 0 | 0x01 | Left |
| 1 | 0x02 | Right |
| 2 | 0x04 | Middle |
| 3 | 0x08 | X1 |
| 4 | 0x10 | X2 |
Mouse wheel messages have the following payload:
| +00 | int32 | Reserved (set to zero) |
| +04 | int32 | Wheel delta |
The wheel delta follows Windows conventions, i.E. usually positive and negative 120 units per click.
This command only works with nodes that accept text input, i.e. Text fields and Web browsers. The single key based nodes won't work.
| +00 | uint32 | Rate control mode |
| +04 | uint32 | Bitrate or QP |
| 0x00000000 | Encode with constant QP (Second field specifies QP (0..51)) |
| 0x00000001 | Encode with constant bitrate (Second field specifies bitrate in kbits/s) |
using System;
using System.IO;
using System.IO.Pipes;
using System.Runtime.InteropServices;
/// <summary>
/// Copyright (C) Ventuz 2020-2024. All rights reserved.
/// Example for reading from the Ventuz StreamOut pipe.
/// Opens the pipe and dumps the audio and video streams into files.
/// Changelog
/// 2024-07-23 [TH] Added mouse messages
/// 2019-08-29 [TH] Initial public version
/// </summary>
namespace StreamOutPipeExample
// The data coming from the pipe is organized in chunks. every chunk starts with this, followed by the chunk data
[StructLayout(LayoutKind.Sequential)]
public struct ChunkHeader
public uint fourCC; // chunk type (four character code)
public int size; // size of chunk data
// Pipe header with general information (VVSP chunk)
public struct PipeHeader
public static readonly int VERSION = 2;
public uint hdrVersion; // should be VERSION
public uint videoCodecFourCC; // used video codec, currently 'h264' aka h.264
public uint videoWidth; // width of image
public uint videoHeight; // height of image
public uint videoFrameRateNum; // frame rate numerator
public uint videoFrameRateDen; // frame rate denominator
public uint audioCodecFourCC; // used audio codec, currently 'pc16' aka 16 bit signed little endian PCM
public uint audioRate; // audio sample rate, currently fixed at 48000
public uint audioChannels; // audio channel count, currently 2
// Frame header, gets sent every frame, followed by video and then audio data (fhdr chunk)
public struct FrameHeader
[Flags]
public enum FrameFlags : uint
IDR_FRAME = 0x01, // frame is IDR frame (aka key frame / stream restart/sync point)
public uint frameIndex; // frame index. If this isn't perfectly contiguous there was a frame drop in Ventuz
public FrameFlags flags; // flags, see above
// Commands to send back to the encoder.
enum PipeCommand : byte
Nop = 0x00, // Do nothing
RequestIDRFrame = 0x01, // Request an IDR frame. it may take a couple of frames until the IDR frame arrives due to latency reasons.
TouchBegin = 0x10, // Start a touch. Must be followed by a TouchPara structure
TouchMove = 0x11, // Move a touch. Must be followed by a TouchPara structure
TouchEnd = 0x12, // Release a touch. Must be followed by a TouchPara structure
TouchCancel = 0x13, // Cancal a touch if possible. Must be followed by a TouchPara structure
Char = 0x20, // Send a keystroke. Must be followed by a KeyPara structure
KeyDown = 0x21, // Send a key down event. Must be followed by a KeyPara structure
KeyUp = 0x22, // Send a key up event. Must be followed by a KeyPara structure
MouseMove = 0x28, // Mouse positon update. Must be followed by a MouseXYPara structure
MouseButtons = 0x29, // Mouse buttons update. Must be followed by a MouseButtonsPara structure
MouseWheel = 0x2a, // Mouse wheel update. Must be followed by a MouseXYPara structure
// NOTE: Currently only the Y value of the wheel is supported
SetEncodePara = 0x30, // Send encoder parameters. Must be followed by an EncodePara structure
// Parameters for Touch* PipeCommands
public struct TouchPara
public uint id; // numerical id. Must be unique per touch (eg. finger # or something incremental)
public int x; // x coordinate in pixels from the left side of the viewport
public int y; // y coordinate in pixels from the upper side of the viewport
// Parameters for the Key PipeCommand
public struct KeyPara
public uint Code; // UTF32 codepoint for Char command; Windows VK_* for KeyUp/KeyDown
// Parameters for the MouseMove and MouseWheel PipeCommands
public struct MouseXYPara
public int x; // x coordinate in pixels from the left side of the viewport, or horizontal wheel delta
public int y; // y coordinate in pixels from the upper side of the viewport, or vertical wheel delta
// Mouse buttons bitfield
[Flags]
public enum MouseButtons : uint
Left = 0x01,
Right = 0x02,
Middle = 0x04,
X1 = 0x08,
X2 = 0x10,
// Parameters for the MouseButtons PipeCommand
public struct MouseButtonsPara
public MouseButtons Buttons; // bit field of all buttons pressed at the time
// Parameters for the SetEncodePara PipeCommand
public struct EncodePara
public enum RateControlMode : uint
ConstQP = 0, // BitrateOrQP is QP (0..51)
ConstRate = 1, // BitrateOrQP is rate in kBits/s
public RateControlMode Mode;
public uint BitrateOrQP;
class Program
// The following helper functions are only meant as a reference.
// In a full implementation these should be asynchronous or
// at least have some kind of timeout/error handling.
/// <summary>
/// Read a number of bytes from a stream and return as array
/// </summary>
public static byte[] ReadBytes(Stream stream, int length)
var bytes = new byte[length];
int done = 0;
while (done < length)
int read = stream.Read(bytes, done, length-done);
if (read == 0) throw new IOException("stream ended");
done += read;
return bytes;
/// <summary>
/// Read a struct from a stream by just blitting the data
/// </summary>
public static T ReadStruct<T>(Stream stream, int size = 0)
var tsize = Marshal.SizeOf(typeof(T));
if (size <= 0) size = tsize;
if (size < tsize) throw new ArgumentException("size is too small");
var bytes = ReadBytes(stream, size);
GCHandle handle = GCHandle.Alloc(bytes, GCHandleType.Pinned);
T theStructure = (T)Marshal.PtrToStructure(handle.AddrOfPinnedObject(), typeof(T));
handle.Free();
return theStructure;
/// <summary>
/// Send a command to the pipe
/// </summary>
/// <param name="cmd"></param>
/// <returns></returns>
public static void SendCommand(Stream stream, PipeCommand cmd)
var bytes = new byte[] { (byte)cmd };
stream.Write(bytes, 0, 1);
/// <summary>
/// Send a command to the pipe, with data struct
/// </summary>
public static void SendCommand<T>(Stream stream, PipeCommand cmd, T para)
int size = Marshal.SizeOf(para);
byte[] arr = new byte[size+1];
arr[0] = (byte)cmd;
var h = GCHandle.Alloc(arr, GCHandleType.Pinned);
Marshal.StructureToPtr(para, h.AddrOfPinnedObject()+1, false);
h.Free();
stream.Write(arr, 0, arr.Length);
/// <summary>
/// Make uint FourCC from four characters
/// </summary>
public static uint FourCC(char a, char b, char c, char d) => ((uint)a << 24) | ((uint)b << 16) | ((uint)c << 8) | ((uint)d);
/// <summary>
/// Entry point here
/// </summary>
static void Main(string[] args)
Console.WriteLine("Ventuz video stream pipe receiver example\n");
// The pipe name is "VentuzOutA" (or B etc for additional outputs), local only.
// You can connect to the pipe as many times as you wish (eg. once per client you serve),
// or you can connect once and handle distribution yourself.
using (var stream = new NamedPipeClientStream("VentuzOutA"))
Console.WriteLine("Connecting...\n");
// connect to the pipe
stream.Connect();
// try to get first chunk
var chunk = ReadStruct<ChunkHeader>(stream);
if (chunk.fourCC != FourCC('V', 'V', 'S', 'P'))
throw new Exception("invalid header from pipe");
// get header
var header = ReadStruct<PipeHeader>(stream, chunk.size);
if (header.hdrVersion != PipeHeader.VERSION)
throw new Exception("wrong protocol version");
// check codecs
// let's only accept h.264 here, but it works the same with HEVC
if (header.videoCodecFourCC != FourCC('h', '2', '6', '4') || header.audioCodecFourCC != FourCC('p', 'c', '1', '6'))
throw new Exception("unsupported video or audio codec");
Console.WriteLine($"video: {header.videoWidth}x{header.videoHeight} @ {(float)header.videoFrameRateNum / header.videoFrameRateDen}fps");
Console.WriteLine($"audio: {header.audioChannels}ch @ {header.audioRate}Hz");
Console.WriteLine("Press ESC to quit.\n");
// video should always start with a full IDR frame (key frame with decoder reset,
// contains metadata such as picture and sequence information). Let's check if this is true.
bool expectIDRFrame = true;
float bytespersec = 0;
// let's open some files to dump the streams into. You can open the .264 file with
// VLC or Media Player Classic, or mux video and audio using FFMpeg.
FileStream videoFile = null;
FileStream audioFile = null;
try
var temppath = Path.GetTempPath();
videoFile = File.Create(temppath + "test.264");
audioFile = File.Create(temppath + "test.pcm");
catch (Exception ex)
Console.WriteLine($"ERROR: Can't create output file(s): {ex.Message}\n");
// now let's receive some stuff! Forever!
bool quit = false;
while (!quit)
while (Console.KeyAvailable)
var rk = Console.ReadKey();
var key = rk.Key;
// On second thought, quit if esc is pressed.
if ( key == ConsoleKey.Escape )
quit = true;
break;
else if (key == ConsoleKey.Spacebar)
// If the space bar is pressed, request an IDR frame
// (not setting expectIDRFrame here; it might take a frame or two until the IDR frame arrives)
SendCommand(stream, PipeCommand.RequestIDRFrame);
else if (key == ConsoleKey.F1)
// simulate a singular touch
var para = new TouchPara
id = 12345,
x = 100,
y = 100,
SendCommand(stream, PipeCommand.TouchBegin, para);
SendCommand(stream, PipeCommand.TouchEnd, para);
else if (rk.KeyChar >= '1' && rk.KeyChar <= '9')
// numeric keys: switch encoder bitrate to 1 mbit per key :)
SendCommand(stream, PipeCommand.SetEncodePara, new EncodePara
Mode = EncodePara.RateControlMode.ConstRate,
BitrateOrQP = ((uint)rk.KeyChar - '0') * 1000,
else
// forward all other keys to Ventuz
SendCommand(stream, PipeCommand.Char, new KeyPara
Code = rk.KeyChar
try
// frame header first
if (chunk.fourCC != FourCC('f', 'h', 'd', 'r'))
// skip unknown chunks
var _ = ReadBytes(stream, chunk.size);
continue;
var frameheader = ReadStruct<FrameHeader>(stream, chunk.size);
if (expectIDRFrame)
if (!frameheader.flags.HasFlag(FrameHeader.FrameFlags.IDR_FRAME))
throw new Exception("IDR frame expected");
expectIDRFrame = false;
// read video data
if (chunk.fourCC != FourCC('f', 'v', 'i', 'd'))
throw new Exception("video frame expected");
byte[] videoFrame = ReadBytes(stream, chunk.size);
// read audio data
if (chunk.fourCC != FourCC('f', 'a', 'u', 'd'))
throw new Exception("audio frame expected");
byte[] audioFrame = ReadBytes(stream, chunk.size);
// calc video bitrate (exponential moving average over packet size times frame rate)
bytespersec += 0.1f * ((float)videoFrame.Length * header.videoFrameRateNum / header.videoFrameRateDen - bytespersec);
// print stuff and dump streams into files
if (frameheader.flags.HasFlag(FrameHeader.FrameFlags.IDR_FRAME))
Console.WriteLine($"Received IDR frame {frameheader.frameIndex} ");
Console.Write($"got frame {frameheader.frameIndex}, {bytespersec * 8 / 1000.0f}kbits/s \r");
videoFile?.Write(videoFrame, 0, videoFrame.Length);
audioFile?.Write(audioFrame, 0, audioFrame.Length);
catch (Exception e)
Console.WriteLine($"pipe read failed: {e.Message}");
break;
Console.WriteLine("good bye.");
videoFile?.Close();
audioFile?.Close();
