2D Layers
  1. General information about 2D Layers
  2. Color Layer
  3. Gradient Layer
  4. Image Layer
  5. SVG - Scalable Vector Graphics
    1. Usage
    2. Limitations
  6. Movie Clip Layer
  7. Movie Frame Layer
  8. Movie Stream Layer
  9. Live Video Layer
  10. Gradient Texture Layer
  11. Texture Loader Layer
  12. Texture Property Layer
  13. Spout Receiver Layer
  14. NDI Receiver Layer
  15. Common Layer Properties
    1. Blending
      1. Mode
      2. Opacity
      3. Blocked
      4. BlockedOnFullTransparency
      5. Layer Mask
        1. Mask
        2. Texture Loader
        3. Loader
        4. IPP
        5. Lighting and Shaders
          1. Lighting
          2. Shaders
        6. Texture Property
        7. 1D Gradient
        8. SVG Loader and SVG Text
        9. Other
        10. Texture Array Loaders
          1. Flipbook Loader
          2. Strip Loader
        11. Flipbook
        12. QR Code Generator
        13. LUT's
          1. Mask Properties
        14. Mask Vignette
        15. Mask Border
    2. Layout
    3. Mapping
    4. Effects
      1. Blending
      2. Mask
    5. Mask Self
      1. Effect
      2. Effect Group
      3. Color Correction
      4. Filters
      5. Distortion
    6. Layer
Color Layer Fills the Layer with a Solid Color
Gradient Layer Creates a Gradient filled Layer - The gradient can be edited and reoriented
Image Layer Creates a simple Layer with an Image - for more properties choose the Texture Loader Layer
SVG File Layer Creates a layer to load SVG drawings
SVG Text Layer Creates a layer that is completely filled with a SVG drawing coming in as XML text
Movie Clip Layer Creates a layer to load in a Movie Clip
Movie Frame Layer Creates a layer to load in a Movie Clip and specify a single Frame inside the Properties
Movie Stream Layer Creates a layer to load in a Streaming Video Clip like a RTSP
Live Video Layer Creates a layer to show Live Video Streams - these Video Inputs have to be configured in the Ventuz Config Editor
Gradient Texture Layer Creates a Gradient Layer with a Gradient Texture node attached inside the Content Editor Area
Texture Loader Layer Creates a Texture Layer with a Texture Loader node attached inside the Content Editor Area
Texture Property Layer Creates a Texture Property Layer only - you need to connect any source node inside the Content Editor Area
Spout Receiver Layer Receives a RGBA texture via ​SPOUT
Color Layer
Gradient Layer
Image Layer
The Image Layer loads standard images and layouts them in Full Size per default. You would preferably use the Image Layer to bring images on screen because it does not generate MipMaps nor does it apply any kind of multisampling. While using the Image Layer you can adjust the Gamma and how to handle the Alpha Channel by changing the Property called TextureHint.
Gamma
Alpha
Usage
Example:
      <g id="g14">
        <g id="g16">
        </g>
      </g>
    </g>
  </g>
</svg>
Output:
Limitations
Movie Clip Layer
Movie Frame Layer
Movie Stream Layer
Live Video Layer
The Live Video Layer offers a simple and effective way to add any configured live video to be feed into Ventuz. To use the Live Video Layer with your Webcam or SDI-Board, you would need to setup the Video Input Source in the Device Configuration. With the Live Video Layer you are able to create very quick side by side Video Feeds simply by adjusting the Layout of the layer itself. To select a specific Ordinal you can either click the Layer Icon or use the Ordinal drop down menu in the Video Property. You can Enable and Disable the Live Video by clicking the buttons in the Video Control section.
Variable Meaning
!{0}, !{4} Position of the color keys
!{1}, !{5} Red-Value of the color keys
!{2}, !{6} Green-Value of the color keys
!{3}, !{7} Blue-Value of the color keys
!{8}, !{10} Position of the Alpha keys
!{9}, !{11} Value of the Alpha keys
The difference with the Image Layer is that the Texture Loader Layer also adds a Texture Loader Node to the Content Area. To load an image into the Layer you would need to specify it in the Texture File Property. The TextureHint is a multi-option drop-down menu used for setting how image Gamma and Alpha channel information are loaded.
Gamma
Alpha
The SPOUT Receiver Node receives an RGBA Texture that can be bound to e.g. a Material Node.
Every SPOUT Sender available is added to a List, with the Sender Name Property you can select the sender you want to receive the Texture from. In the outputs you get a list of all currently available senders. This list is updated once during initialization of the node. If needed you can update the list again using the Update Sender List Method.
Not a Color Textures loaded with this option will not be touched or converted internally into any other colorspace
2.006 RGBA
NDI Receiver Layer
The NDI Receiver provides the texture of a chosen NDI source together with several meta data. The Source property defines which NDI source to use - it can be provided either as a string or using the dropdown menu that is accessed by  clicking the arrow on its right.
Low Bandwidth limits the input to 640x360 pixels which saves bandwidth between the source and Ventuz and is meant to be used e.g. for preview cases. Low Latency disables frame buffering that is used to stabilize the incoming framerate. If enabled it may cause stuttering on the input depending on the NDI source and the network environment, but the frames will be processed by Ventuz without any delay.
Audio Stream
Blending
Blending
Mode
Opacity
Blocked
Layer Mask
Mask
Texture Source
Texture Loader
Texture Loader Presets
Loader
Image/Texture
Description
Internal resource name
Image/Texture
Description
Shape Circle
Shape Triangle
Shape Pentagon
Shape Cross
Spike Star
Checker
internal://images/checker.png
Checker Blue
Checker Dots
internal://images/dots.png
Lines
internal://images/lines.png
Noise
internal://images/noise.png
Alpha Glow Full
Alpha Glow Half-Full
Alpha Glow
Alpha Glow Half-Sharp
Alpha Glow Sharp
Square Blur Sharp
Square Blur Sharp
Square Blur Medium
45 Degree
Linear In/Out
Linear
internal://Images/linear.png
Dimple
internal://images/dimple.png
Pimple
internal://images/pimple.png
Liquid
internal://images/liquid.png
Woodchip
IPP
Image/Texture
Description
Image/Texture
Description
Lensflare Ghost Colors
Lensflare Star
Lensflare Dirt
Lighting
Image/Texture
Description
Image/Texture
Description
Incidence 1D Lambert
Incidence 1D Rainbow
Incidence 1D Specular
Incidence 2D Smooth
Incidence 2D Steps
Incidence Diffuse
Incidence Diffuse Anisotropy
Incidence Specular
Incidence Blue Back
Celshading Steps
Shaders
Image/Texture
Description
Image/Texture
Description
Hatch Lines
Hatch Curves
Hatch Letters
Texture Property
1D Gradient
Gradient Presets
SVG Loader Presets
Other
Image/Texture
Description
Ventuz Logo SVG
internal://images/ventuz.svg
Flipbook Loader
Strip Loader
Gradient Presets
Flipbook
Image/Texture
Description
Flipbook Clock
QR Code Generator
ECC Level
  • Level L ~7%
  • Level M ~15%
  • Level Q ~25%
  • Level H ~30%
LUT's
Color Space:
Source:
Target:
Mask Properties
Mask Vignette
Mask Border
Layout
Mapping
Effects
Blending
Mask
Mask Self
Effect
Effect Group
Color Correction
Filters
Distortion
Layer
  • Gradient Editor
  • Texture Node
  • LUTs
  • ​SPOUT
