ST2110 is a very complicated and expensive technology. Always check if using traditional SDI and fiber optics hardware can do the job cheaper. Especially debugging an ST2110 installation can be challenging, and learning to master ST2110 is expensive in itself. ST2022-7 Seamless Protection Switching might double the cost of your network infrastructure on top of that.
ST2110 and NMOS are a set of "standards" that try to give you real-time uncompressed video transmission over IP hardware. This is very different from video streaming in the following way:
ST2110 defines how the pixels are transmitted over the IP network. It is based around the idea of transmitting video, audio and ancillary as independent "essences" so it is possible to process the smaller audio and ancillary streams without needing the fat video stream. This also means that we need 3 sets of configuration parameters.
Optionally, ST2110 allows to use "Seamless Protection Switching" (SPS via ST2022-7). As packet loss can be a problem with IP switched networks, all data is send to two independent networks with independent switching infrastructure, and all receivers will get IP packets from both networks, hoping that at least one actually arrives. Most high-end broadcast installations rely on this level of reliability, doubling the cost of the network infrastructure, and doubling the number of configuration parameters that need to be managed.
NMOS is a web-based system that allows to register, discover and switch ST2110 devices. This allows to create software where you can browse all registered ST2110 devices, get the network parameters of a sender and tell a receiver to listen to that sender. Most high-end broadcast installations will choose the NMOS information to go over a network that is separate from the "media network" that handles the high bandwidth video / audio / ancillary streams.
So in total we often have 3 networks in an ST2110 installation : two specialized high-bandwidth media networks for ST2110 and one control network for NMOS and other non-time-critical services like other web- and operating system services. With Ventuz one might add a cluster clock network and may be one needs networks for Dante audio.
As mentioned, we need a lot of configuration information to set up an ST2110 stream. This information is usually stored in SDP files, an old text-based format that contains IP addresses and video / audio parameters. Usually, an ST2110 stream has a video, an audio and an ancillary essence, each described in their own SDP file. If 2022-7 SPS is used, information about both networks are stored in the same SDP file.
In Ventuz, ST2110 can be used with or without NMOS. It is recommended to first try ST2110 without NMOS, and add NMOS installation later.
In Ventuz, ST2110 streams are handled like SDI and other video devices. All we need to add is the network related information. This falls into two parts : the device settings and the per-stream settings.
For each device, we need to set the network interface settings:
You can read-back the actual internet settings in the live options with the EthConfigReadback property.
In addition to that, you can configure the PTP (precision time protocol)
On BMD only, you can check the chosen PTP Grandmaster in the live options with the PtpNegotiatedGrandmaster property.
For input and output streams, you can set a combined SDP file in the device config.
This file is created by concatenating the SDP files of the 3 essences together, in any order. You may add comment lines with '#' to make things more readable, but that is not required. This might look like this:
# video v=0 o=- 21 21 IN IP4 192.168.200.200 t=0 0 m=video 10000 RTP/AVP 96 c=IN IP4 239.0.5.1/32 a=source-filter:incl IN IP4 239.0.5.1 192.168.200.200 a=rtpmap:96 raw/90000 a=fmtp:96 sampling=YCbCr-4:2:2; depth=10; width=1920; height=1080; exactframerate=60; colorimetry=BT709; PM=2110GPM; SSN=ST2110-20:2017; TP=2110TPN; a=ts-refclk:ptp=IEEE1588-2008:00-00-00-00-00-00-00-00:127 a=mediaclk:direct=0 a=ssrc:0 cname:319b3fe6-0 # audio v=0 o=- 31 31 IN IP4 192.168.200.200 t=0 0 m=audio 14000 RTP/AVP 97 c=IN IP4 239.0.5.1/32 a=source-filter:incl IN IP4 239.0.5.1 192.168.200.200 a=rtpmap:97 L24/48000/2 a=ptime:1 a=ts-refclk:ptp=IEEE1588-2008:00-00-00-00-00-00-00-00:127 a=mediaclk:direct=0 a=ssrc:0 cname:319b3fe6-0 # anc v=0 o=- 41 41 IN IP4 192.168.200.200 t=0 0 m=data 18000 RTP/AVP 98 c=IN IP4 239.0.5.1/32 a=source-filter:incl IN IP4 239.0.5.1 192.168.200.200 a=rtpmap:98 smpte291/90000 a=fmtp:98 a=ts-refclk:ptp=IEEE1588-2008:00-00-00-00-00-00-00-00:127 a=mediaclk:direct=0 a=ssrc:0 cname:319b3fe6-0
This file is parsed by Ventuz by looking at lines that start with "v=", and that's where the 3 essences are split. The "m=" and "a=fmtp" lines are used to identify video, audio and ancillary.
Not all lines of these files are actually used:
Parsing SDP files can be tricky, as this is not a modern file format. for Deltacast, Ventuz parses the SDP file and any problems with that can be fixed by us. For BMD, the Blackmagic driver parses the SDP file and any incompatibility can only be fixed by Black Magic.
A sender without any SDP file will automatically guess some reasonable defaults.
There are live options that relay the current configuration in the form of the combined SDP file of the 3 essences. These are created by putting together information found in the IP device options, traditional stream configuration and SDP file provided in the stream configuration. You can copy this from a Ventuz ST2110 sender and paste it in the device configuration of a Ventuz ST2110 receiver. You can also start a sender without SDP file, copy what Ventuz put together from the live options, change it to your liking and set as the final sender SDP in the device config. This is the simplest way to set up ST2110 senders and receivers without NMOS.
NMOS is handled by software provided by the device manufacturer. This will override the stream configuration on the fly per NMOS commands. This is completely transparent and does not require additional configuration on the Ventuz side. The "SDP Readback" options represent the new settings as provided by NMOS.
ST2110 integration is under active development by the hardware vendors as well as by Ventuz. Expect more frequent driver updates as usual from the Ventuz side to accommodate the quickly changing ST2110 ecosystem
| Model | Media Interface | SPS 2022-7 | Control Network | Channels |
| Delta-ip-ST2110 10 | 10GB SFP+ | yes | Host PC | 4x3G in |
| Delta-ip-ST2110 01 | 10GB SFP+ | yes | Host PC | 4x3G out |
| BMD Decklink IP HD | 10GB RJ45 | no | over media interface only | 2x3G in and out simultaneously |
| BMD Decklink IP HD Optical | 10GB SFP+ | no | over media interface only | 2x3G in and out simultaneously |
| BMD Decklink IP/SDI HD | 10GB RJ45 | no | over media interface only | 2x3G in and out simultaneously |
| BMD Decklink IP 100G | 100GB QSFP28 | yes | over media interface only | 8x12G in and out simultaneously |
Each vendor does different things on how configuration and NMOS are integrated:
How to set up IP Adress of the interfaces:
The DELTA-ip-ST2110 board can be configured as input only or output only board via firmware update.
Deltacast has currently a few limitations. A firmware update expected late 2026 should allow us to solve these problems, but for now be aware:
