Color Picker
Color Picker Samples pixels on a given texture and Outputs their color.
The Output Color value is in the Project Color Space, except the Layer is set to Standard Engine Mode in the Layer's root node. Then it's always in sRGB.
  • Texture Loader Node
  • Layer Layout Properties
