Render Point
  1. Isolate Hierarchy subtrees
  2. Isolate a Layer
  3. Camera Shortcuts
The isolate Mode is basically the Render Point functionality. Doubleclick  doubleclick any object in the Render Window. This will set a Render Point for the selected Object, all other parts of the scene tree are ignored. The navigation and shortcuts are listed below. Doubleclick  doubleclick the selected object again to leave the Isolate Mode
Selecting a node and pressing CTRL + R will set the Render Point to that Node. Additionally you can activate the Render Point in the Hierarchy/- Toolbar or select the Set Render Point from the context menu with a  click on the selected Node. The Render Point defines teh isolated subtree in the Hierarchy. For the following screenshot it means the V_Mesh02 is isolated and centered in your Rendering Window.
Isolate a Layer
To isolate a Layer from its composition select it and press CTRL + R. You can also press the Isolate button on the Layer Tool Bar. It allows you to view and edit the Layer outside the context of your already finished composition without changing the actual surrounded logic.
Camera Shortcuts
Move the camera:
 drag Rotate object
ALT +  drag Orbit around object
 drag Rotate camera
Ctrl + ALT + drag Roll camera
ALT +  drag Pan camera
ALT +  drag Zoom camera
 doubleclick Leave Isolation Mode / Remove Render Point
