Stage Editor
  2. Preview view
    1. Render Setup Selection and Editing
    2. Preview Selection Menu
      1. Physical
      2. Design Preview
      3. Disable Preview
      4. Options
    3. Machine ID Selection
    4. Design Preview
    5. All Outputs
    6. Connector Selection
  3. Render Setups view
The Stage Editor enables previewing of different Screens, Previs Screens and Compositions as well as outputs and other machines inside a Cluster. Furthermore you are able to switch, edit and create Render Setups quickly.
The Stage Editor has two tabs: The Preview view, with selections of different Screens and Compositions and the Render Setups view to create and manage the Render Setups.
Preview view
Also in the Preview view it is possible to quickly select your Render Setups from the drop down menu. Use the to get inside the Render Setup Editor and edit the currently selected Render Setup.
For creating a new Render Setup, switch to the Render Setups view as explain later downwards.
When working with a previs scene the Composition preview may show content with a strange aspect ratio; this is not a bug but rather a technical limitation. This is due to the Render Order, at the point of previewing the Composition the engine doesn't know the design size set by the canvas. It will fall back to the Aspect Ratio set in the Project Properties window.
Physical
This previews the physical device output. Depending on the setting Enable All Outputs, it behaves differently.
Enable All Outputs Behavior
On Previews the output of the device as configured in the Device Configuration.
Off Previews DUMMY Outputs as configured in the Render Setup output mapping tab.
Inputs can be previewed if configured inside your Device Configuration.
Design Preview
Disable Preview
Options
Enable All Outputs: Will use all physical screens currently configured as outputs inside your Device Configuration and render your scene on it, except the screen with Designer open. When disabled, the Preview Renderer will render the Physical Outputs as configured in the active Render Setup, instead of the Device Configuration.
Bezel Color: Change the rendered bezel color as well as the transparency by using the alpha values below the color wheel.
Preview at System SDR Level: Whith HDR mode on: Sets the SDR white-level of the preview renderer to the Windows SDR level of the Windows Display Settings.
Preview with Tone Mapping: Whith HDR mode on: Performs a bt2390 rgb display transform to tone map linear HDR to SDR.
Use the broom icon to display what is used with your current machine ID, which is configured on the general tab inside the configuration tab inside the Configuration editor. Or Preview other machines outputs from your network with the corresponding ID. With all all machines can be previewed in Design preview or with the All Outputs preview.
Design Preview
All Outputs
Configuration of both Inputs and Outputs can be done inside the Device Configuration. When all is selected in machine selection, All Outputs previews all outputs from all machines in the cluster. Be aware of perfomance demand. Lower Resolution for Previs can reduce the preview resolution for the All Outputs preview.
Connector Selection
Render Setups view
To create, edit and mange the Render Setups switch to the Render Setups view of the Stage Editor.
The active Render Setup is highlighted in orange and when selected the tick is selected. To activate a different one, select it and activate the tick (7). To edit a Render Setup, double click 2x  the name of a Render Setup or press the pencil icon (4). To add a new one, the plus icon (1). Rename a selected Render Setup with a on the name or with button (6). Button (2) imports a Render Setup from a file from disk. Button (3) opens the Render Setups directory. Button (5) duplicates a selected Render Setup. And button (8) deletes the selected one.
  • Previs Screens
  • Screens
  • Compositions
  • Canvases
