Z-Testing
Z-Testing This node modifies the depth information that is written by geometries into the depth buffer (Z-Buffer).
The Z-Testing Node is an Alias of the Material Node. It changes one of the tests that is performed to decide whether a fragment of an object is rendered or not. The Material Node has other options that are documented on the respective pages (see table below for more information).
Material User Interface
Generally these tabs exist:
Standard
Alpha Options
Lighting Model
Material Stages
Shadow Options
Shadow Options
Drawing Style
Draw Mode
Blending
Color Write
Alpha Blending
Testing
Alpha Testing
ZBuffer
Icon and Decoration
Rendered Preview
Dedicated Option Icon
Extraction
Material Definition
Material Options
The default behavior is to accept pixels that have a Z-value that is smaller or the same as the value in the Z-Buffer, making objects closer to the camera occlude objects which are farther away. While it may seem weird at first to ever use something that is different from the default (and in the majority of cases this is the best option), using different comparison functions can be used to create interesting rendering effects or prevent rendering artifacts from happening.
Z-Testing Options
The Z-Testing Node can influence the above decision in multiple ways. You can either use a simple set of options or an advanced one.
Simple
The Test property can be deactivated to do no Z-testing at all for all children nodes. The Write property can be deactivated to just perform the Z-test but not update the values in the Z-buffer once a pixel is rendered.
In certain situations like rendering a wireframe overlay over a solid object, visual artifacts due to Z-fighting problems can be avoided by adding a small offset to the Z value calculated for a pixel. This offset is only used for the Z-testing comparison. If the pixel is drawn and updates the Z-Buffer, the original Z-value will be used. This offset is specified by a fixed offset called Bias.
Advanced
The Advanced Z-Testing options can change the test function itself to one of the following settings:
  • Inherit: The comparison function is inherited from a parent Z-testing node or the default (Less Equal) if non exists.
  • Always: A pixel is always drawn, no comparison to the value in the Z-Buffer is performed.
  • GreaterEqual: A pixel is drawn if its depth value is greater than or equal to the corresponding value stored in the Z-Buffer.
  • NotEqual: A pixel is drawn if its depth value is not the same as the corresponding value stored in the Z-Buffer.
  • Greater: A pixel is drawn if its depth value is greater (not equal) than the corresponding value stored in the Z-Buffer.
  • LessEqual: A pixel is drawn if its depth value is less than or equal to the corresponding value stored in the Z-Buffer.
  • Equal: A pixel is drawn if its depth value is exactly equal to the corresponding value stored in the Z-Buffer.
  • Less: A pixel is drawn if its depth value is less than the corresponding value stored in the Z-Buffer.
  • Never: A pixel is never drawn.
Slope can be used similar to Bias. It is multiplied with the maximum depth value of the triangle being rendered. It can be used to adapt the offset with the distance from the camera, countering Z-Buffer resolution issues.
Write Normals can be turned off to prevent normals from being written. This normally is turned off only if the Write property is set to off as well. Normals are used e.g. by the Screen-Space Ambient Occlusion (SSAO) effect on 3D Layers. The SSAO would not be rendered for areas behind transparent objects, because only the depth and normals of the transparent object's surface is known. By turning off writing both Depth and Normals the SSAO is now calculated for objects behind (but not for the transparent object in the front).
Z-Write YES NO NO
Normal-Write YES YES NO
