To open the Render Setup editor, open the Configuration Editor and open the Configuration tab, on the left side you will find a entry called Render Setups. Now select the Project this setup should be for. Create a new Render Setup by clicking the button on the right side of the window.
It is possible to Import and Export existing Render Setups to and from Projects and to import from previous versions of Ventuz when using the Migration assist tool.
To export a Render Setup, hover over the "Download" button and click. Save the file in a desired folder on your hard drive.
To Import an existing Render Setup file, Click on "New...", in the pop-up select "Import Render Setup" and navigate to the location the desired Render Setup file is stored.
Once the new Render Setup is created, the Render Setup window will automatically open in the Layout Mode.
To edit an existing Render Setup click on the Pencil Icon inside of the existing Render Setup.
Generally speaking this is the mode where you set the stage for you presentation, add screens and use compositions to set the frame for your rendering. To learn more about the handling of our new output system read this page.
1. Mode Change:
2. Previs:
3. Close and Save:
4. Machine Selection:
5. Compositions:
8. Contextual Controls:
9. Mode Selection:
10. View Options:
11. Property Editor:
12. Workspace:
13. Measurement Tool:
14. Import Compositions:
1. Color
2. Name
3.Fit to Screen
4. Dimension
5. Lock
6. Render Order
7. Rotation
8. Units of measurement
9. Pixel Density
10. Physical Size
11. Diagonal
12. Blend Mode
13. Blend Amount
14. Allow Scaling
1. Color
2. Name
3. Resolution
4. Pixel Density
5. Physical Size
6. Diagonal
7. Bezel
8. Allow Scaling
9. Render Filter
10. Rotation
1. Color
2. Name
5. Physical Size
By using the measurement button in the lower right corner the user is able to measure distances between different elements in centimeters or inches. Clicking on the measurement button will toggle all measurements on and off.
Set a measurement:
on an edge or corner of an element and drag it over to a second point to create a measurement.
To adjust existing points, hold CTRL and click&drag on a point to adjust.
Holding SHIFT while dragging a point, they will snap lines at 45° increments while drawing them.
All of the markers are sticky; they will stay attached to the same point on an object if you change the size, rotation or pixel density.
Deleting Measurements:
By on a existing measurement and hitting DEL will delete the measurement line. Alternatively you can also hold CTRL and drag a point into empty space to delete it.
With the measurement info box it is possible to measure different objects with different DPI or Px/cm and the different pixel distances.
1: Info Box Button
2: Names
3: Current Dots per inch / pixel per cm
4: Show button
5: Delete all measurements
When stacking Compositions on to each other it may be necessary to change their render order. To do that, simply drag and drop the Composition to the desired place in the Tree view. As always in Ventuz, the Render order starts from the top down.
Solid: No blending is used
Alpha: Enables Alpha Blending
Add: Additive RGB blending
Instancing Compositions can be used to show the same content multiple times, in different positions or different resolutions. When "Allow Scaling" is enabled, Ventuz will render the scene elements one time and scale them to fit the corresponding Compositions. Scaling saves system resources. Ensure the aspect ratio is correct for these instanced Compositions; otherwise, your content might end up stretched or squished.
The Default Composition inside the Render Setup Editor behaves differently than other ones.
This Composition will automatically scale with screens that are inside this Composition. The Name of the Default Composition can't be changed.
In order to free screens of the automatic scaling inside the Default Composition uncheck the "Fit to Screen" property on the Default Composition or use the scaling handles of the composition and remove the Screen from it. Deleting the Default Composition inside the Render Setup Editor will not break anything inside the Designer. Still the Default Composition Layer will be present when another Composition layer is inserted but can be safely ignored.
With the Mapping mode it is possible to assign Screens to Outputs, add new machines, or shape and warp Outputs.
1. Mode Change:
2. Previs:
3. Close and Save:
4. Mode Selection:
5. View Options:
6. Add machines:
7. Import Device Configuration:
8. Shaping & Warping:
9. Property Editor:
10. Machine Options:
11. Add Outputs:
13. Output Workspace:
14. TUIO Touch inputs:
15. Workspace:
16. Selected Machine/Group:
17. Adding cuts:
18. Reset of the view:
19. Maximize output:
20. Moving of outputs:
After clicking on the Device Configuration Import button you will be greeted with this small helper pop up.
1: Device Configuration:
2: Collapse all:
3: Configuration Overview:
4: Choosing a machine to import to:
5: Choose to overwrite or add:
For a Cluster Configuration Imports, only the currently active configurations from the machines inside that group can be used. Also note that you have to choose the correct group before opening a new Render Setup for that cluster!
The maximum visual resolution for a GPU currently is 16384 x 16384 pixels!
Elements can be selected by simply click. Multi selection is possible by dragging a selection frame drag around elements inside the All mode.
| Moving is done by dragging and dropping, scaling can be done by the indicator on the Compositions. Selecting items in the tree view also changes the modes accordingly | | Rotations can be snapped to 10° or 5° using CTRL(10) or ALT(5) |
| Use the All mode to quickly move a bunch of elements | | Scaling only works for Compositions and TUIO Touch Areas, to resize screens use the Property Editor |
To create an equal bezel or overlap between multiple elements, use the grid function when creating new screens. You can choose to add them using centimeter values or pixels.
It is also possible to do it like it was in Version 6 where all selected screens are properly aligned when the bezel was added. This only works when it matches the following requirements:
Or you can pull them apart using the arrow's appearing when having selected more then one screen. This also comes with some limitations:
Uses a single screen on the output. Assign a screen by drag + drop from the left pane onto the desired output on the right.
It is possible to use the same screen multiple times by applying them to multiple times to the same output. Notice how the original size of the Screen set in the Layout cant be overwritten by this. You can also choose which portion should be rendered, change this by changing the screen position in the left view.
It is also possible to hold down the SHIFT key when dragging screens onto a output to tile it to the desired size automatically.
In general as soon as one uses either the Grid or Manual mode the output will be cut into multiple pieces. Indicated by the label in the middle. For the Grid mode this will show 1.1 1.2 and so on depending on there position in the output. For Manual tiling it will simply count upwards.
M0 = Machine + ID
1:
2:
3:
4:
5:
6:
7:
8:
9:
Without separation groups:
With separation groups:
With the split button you can easily tile a screen or split them to the desired count. Or split of a specific portion of the screen. This menu is available in the properties or by onto a screen.
Creating Tuio Touch area inside the layout mode is a purely visible helper until the touch are is assigned inside the Mapping mode.
In order to assign a Tuio Touch area to a specific part of a output/screen or to the touch area directly you have to first hit the Add Tuio Touch button and then choose the wanted screen/output or Touch area. This has to be done per individual Touch area and per machine if there are multiple.
Open the Mapping mode by clicking on "Mapping" in the top left corner to assign those Screens to the outputs we want to use. The Composition in this case is defining the area which we want to render content, therefore we need to have screens to assign to the outputs.
As you can see on the left, Ventuz doesnt know about the second screen yet, which is indicated by the white dotted line (the machine boarder). To assign it, we need to add another output to the machine, we can also directly assign the screen to it by using the drop down menu inside the pop up window. Or drag + drop screens from the left on to empty output slots on the right. If placing a screen on an output that has a screen already assigned to it, the existing screen will be replaced by the new one.
| View | ||
| Middle mouse button+drag | Pan | |
| Middle mouse wheel | Zoom | |
| R | Reset view | |
| double click | Outputs | Maximize / Restore view |
| Selection | ||
| click | Select | |
| click+drag | Rectangle Selection | |
| click | Context Menu | |
| CTRL click | Multi Selection | Add/Remove to/from selection |
| CTRL+A | Select all elements depending on the selected mode | |
| CTRL+ click+drag | Disable snapping | |
| SHIFT+ +drag | Perpendicular measurements in 45° steps | |
| Editing | ||
| move | Move selection | |
| SHIFT move | Move selection without snapping | |
| CTRL + C | Copy selection | |
| CTRL + V | Paste | |
| CTRL + SHIFT + C | Copy Composition instance | |
| CTRL + SHIFT + V | Paste Composition instance | |
| CTRL + Z | Undo | |
| CTRL + Y | Redo | |
| ←, →, ↑, ↓ | Move selection by 10 pixel | |
| CTRL + ←, →, ↑, ↓ | Move selection by 1 pixel | |
| SHIFT + ←, →, ↑, ↓ | Multi Selection | Change distance by 10 pixel |
| CTRL + SHIFT + ←, →, ↑, ↓ | Multi Selection | Change distance by 1 pixel |
| + drag + CTRL | Rotation | 10° snapping |
| + drag + ALT | Rotation | 5° snapping |
| CTRL+S | Save changes | |
