![]() | Effect | Applies an Image Post Processing Effect to a part of the Hierarchy Tree. |
With the
-Button you can add Effects or effect groups to this node as they are documented in IPP Color Corrections, IPP Distortions, IPP Filters and IPP. All effects that are available for layers are also available for the Effect Node.
