Alpha Blending
  1. General
    1. Icon and Decoration
  2. Extraction
    1. Material Definition
    2. Material Options
  3. Color Write
  4. Alpha Blending Options
    1. Off
    2. Simple
    3. Advanced
Color Write Allows you to enable/disable the RGBA Channels separately.
Blending This node modifies the blending rules for superposed pixels with industry standard presets.
The Color Write and Blending Nodes are Aliases of the Material Node. They change the blending of the following geometries to the background. The Material Node has other options that are documented on the respective pages (see table below for more information).
Alpha Blending is a technique used to specify how a pixel being drawn by a triangle (source) and the pre-existing color value in the render output (destination) are mixed. It is commonly used to simulate transparency effects, see Introduction to Realtime Rendering.
When a fragment has passed all tests (see 3D Mask Nodes , Z-Testing Node, Alpha Testing Node, Stencil Nodes), its color is applied to the render output and overwrites any value previous set by other objects. With alpha blending, the final pixel color can be a combination of both the fragment (source) pixel color and alpha as well as the pixel color and alpha in the pre-existing render output (destination).
Material User Interface
Generally these tabs exist:
Standard
Alpha Options
Lighting Model
Material Stages
Shadow Options
Shadow Options
Drawing Style
Draw Mode
Blending
Color Write
Alpha Blending
Testing
Alpha Testing
ZBuffer
Icon and Decoration
Rendered Preview
Dedicated Option Icon
Extraction
Material Definition
Material Options
Color Write
The Color Write options of the Material Node enable the user to choose which channels should be affected by the current fragment.
The Material Node has different ways of defining the blending of the current fragment. These can be changed with the according Property Groups. One is offering you very simple presets, the other will give you full control over the blending but is harder to handle.
Off
When set to Off the fragment will simply overwrite the destination.
Even when the Blending is set to Off the fragment will only be drawn if it has passed all tests before (occlusion test, alpha test etc.).
Simple
Preset Color Function Alpha Function Note
Overwrite SourceColor SourceAlpha Same as setting the blending to off.
Normal SourceColor + DestinationColor * (1-SourceAlpha) SourceAlpha + DestinationAlpha * (1-SourceAlpha) Blends the colors as usual - regarding the Alpha value of the current fragment.
LinearDodge (Add) SourceColor + DestinationColor SourceAlpha + DestinationAlpha * (1-SourceAlpha) Adding the color to the destination which will effectively brighten the background linearly by the current fragment.
Screen (SourceColor + DestinationColor) - (SourceColor * DestinationColor) SourceAlpha + DestinationAlpha * (1-SourceAlpha) This will multiply the inverses of color and alpha and invert it again. This results in a similar result as linear dodge as it produces a brighter image, but in contrast will not have results brighter than white. So it will not produce clamping like linear dodge (which still might make sense e.g. in HDR mode).
Subtract Rendering from Background SourceColor - DestinationColor SourceAlpha + DestinationAlpha * (1-SourceAlpha) Like linear dodge it will linearly darken the image by subtracting the source fragment from the destination.
Subtract Background from Rendering DestinationColor - SourceColor SourceAlpha + DestinationAlpha * (1-SourceAlpha) This is the reverse Subtraction that will darken the source fragment instead of the background.
Multiply SourceColor * DestinationColor SourceAlpha + DestinationAlpha * (1-SourceAlpha) Multiplying two colors will always result in a darker image - this is the reverse operation of Screen blending as it will not create clamping below 0 (black).
Multiply X2 SourceColor * DestinationColor * 2 SourceAlpha + DestinationAlpha * (1-SourceAlpha) Similar to multiply, but this will result in a darker color than the destination when the current source fragment is darker than mid-grey and in a lighter color if the source is lighter than mid-grey. Good for e.g. exaggerating bright and dark spots in the image.
Glow SourceColor + DestinationColor DestinationAlpha Similar to linear dodging but completely ignores the source alpha.
The shaders in Ventuz make sure the source color is pre-multiplied with the source alpha. This is why the formula for normal blending does not multiply the SourceColor with SourceAlpha, this has already happened in the shader. The same is true for all other blending modes.
Advanced
Compared to the Simple Property Group you have access to the full capability of the graphics card for greater flexibility. Both the source and destination color are treated as a 4-dimensional vector (red, green, blue, alpha) which is multiplied with a blend factor before applying the chosen operation.
  • One: Multiply each component by one.
  • Zero: All channels of the color are multiplied by zero
  • BlendFactor: Multiply each component by the respective component of the color specified in the BlendFactor property.
  • InverseBlendFactor: Multiply each component by the respective inverse component of the color specified in the BlendFactor property.
  • BothInverseSourceAlpha: The source color is multiplied by one minus the source alpha and the destination color is multiplied by the source alpha
  • SourceAlphaSaturated: The red, green and blue channel are multiplied with the min(alpha_source, 1 - alpha_destination), alpha is multiplied by one. This can only be used for Source and will override the value set in Destination.
  • InverseDestinationColor: Multiply each component with one minus the respective component in the destination color.
  • DestinationColor: Multiply each component with the respective component in the destination color.
  • InverseDestinationAlpha: Multiply all channels with one minus the destination alpha.
  • DestinationAlpha: Multiply all channels with the destination alpha.
  • InverseSourceAlpha: Multiply all channels with one minus the source alpha.
  • SourceAlpha: Multiply all channels with the source alpha.
  • InverseSourceColor: Multiply each component with one minus the respective component in the source color.
  • SourceColor: Multiply each component with the respective component in the source color.
  • Add: Result = Source + Destination
  • Maximum: Result = MAX(Source, Destination)
  • Minimum: Result = MIN(Source, Destination)
  • ReverseSubstract: Result = Destination - Source
  • Substract: Result = Source - Destination
To recreate the presets from the Simple Blending, enable SeparateAlpha and use these settings. They are also available as presets for the Advanced Blending:
Overwrite (SourceColor * One) ADD (DestinationColor * Zero) (SourceAlpha * One) ADD (DestinationAlpha * Zero)
Normal (SourceColor * One) ADD (DestinationColor * InverseSourceAlpha) (SourceAlpha * One) ADD (DestinationAlpha * InverseSourceAlpha)
LinearDodge (Add) (SourceColor * One) ADD (DestinationColor * One) (SourceAlpha * One) ADD (DestinationAlpha * InverseSourceAlpha)
Screen (SourceColor * InverseDestinationColor) ADD (DestinationColor * One) (SourceAlpha * One) ADD (DestinationAlpha * InverseSourceAlpha)
Substract Rendering from Background (SourceColor * One) ReverseSubtract (DestinationColor * One) (SourceAlpha * One) ADD (DestinationAlpha * InverseSourceAlpha)
Substract Background from Rendering (SourceColor * One) Subtract (DestinationColor * One) (SourceAlpha * One) ADD (DestinationAlpha * InverseSourceAlpha)
Multiply (SourceColor * DestinationColor) ADD (DestinationColor * Zero) (SourceAlpha * One) ADD (DestinationAlpha * InverseSourceAlpha)
Multiply X2 (SourceColor * DestinationColor) ADD (DestinationColor * SourceColor) (SourceAlpha * One) ADD (DestinationAlpha * InverseSourceAlpha)
Glow (SourceColor * Onw) ADD (DestinationColor * One) (SourceAlpha * Zero) ADD (DestinationAlpha * One)
  • Material Node
  • Alpha Testing node
  • Layer Blend Modes
  • ​MSDN: Blend Factors
  • ​MSDN: Blend Operators
  • ​Wikipedia: Blend Modes
