Alpha Testing
Alpha Testing This node tests if a pixel has to be drawn. This depends on the alpha value of this pixel.
The Alpha Testing Node is an Alias of the Material Node. It changes one of the tests that is performed to decide whether a fragment of an object is rendered or not. The Material Node has other options that are documented on the respective pages (see table below for more information).
Material User Interface
Generally these tabs exist:
Standard
Alpha Options
Lighting Model
Material Stages
Shadow Options
Shadow Options
Drawing Style
Draw Mode
Blending
Color Write
Alpha Blending
Testing
Alpha Testing
ZBuffer
Icon and Decoration
Rendered Preview
Dedicated Option Icon
Extraction
Material Definition
Material Options
Alpha Testing Options
Similar to the Z-Testing and Stencil Testing nodes, the alpha value of a fragment can be used to reject it before the respective pixel is drawn.
You can Inherit the Alpha Testing, turn it On or Off or provide a custom Alpha Test (Advanced). When set to On the test will fail if the Alpha is not greater than 0 - this effectively saves performance by not rendering any invisible pixel. If you need all fragments rendered change the alpha test function with the Advanced option or turn the test Off. If turned Off the test will never fail and the current fragment is always rendered.
Advanced
The Alpha Testing compares the alpha value of the fragment (after it has been lit and textures have been blended) to the value specified in RefAlpha using the operation set in Function:
  • Always: The fragment always passes the test.
  • GreaterEqual: The fragment passes the test if its alpha value is greater than or equal to the reference value.
  • NotEqual: The fragment passes the test if its alpha value is not equal to the reference value.
  • Greater: The fragment passes the test if its alpha value is greater than (not equal) to the reference value.
  • LessEqual: The fragment passes the test if its alpha value is less than or equal to the reference value.
  • Equal: The fragment passes the test if its alpha value is equal to the reference value.
  • Less: The fragment passes the test if its alpha value is less than (not equal) to the reference value.
  • Never: The fragment never passes the test.
  • Material Node
  • Alpha Blending node
  • Z-Testing node
  • Stencil Testing nodes
