VisualsIndexer
Visuals IndexerThe Visuals Indexer determines the Data Pool of a Visuals URI.
The Visuals Indexer Node takes a Uniform Resource Identifier (URI) and determines the Data Pool of the Visuals URI. The incoming URI is then passed to one of the output properties ImagesUri , TexturesUri, MoviesUri, StreamUri, ScenesUri, AudioUri, SoundUri, GeometriesUri or PageUri. The output IsUriInvalid indicates if the URI is valid or not and can be used to block unused elements. In that case that the input Uri is invalid or could not be assigned to a specific type it is provided by the InvalidUri property. Beside the common audio-visual DataPools the VisualIndexer Node can also handle a special URI to switch to LiveVideo
internal://LiveVideo/0
  • URL Node
  • HowToCreateAVisualsLoaderNode
