Random Points
Random Points This node provides random point clouds of different shapes.
In order to make the Points visible a Color Node must be added before the Random Points Node. If a Material Node is used it has to have an Emissive component. An ambient lighting makes the Points visible as well. This is different to the behavior of the other geometry nodes because the Points do not have any surface.
For ways to change how the individual points are rendered, see Draw Modes.
  • Nodes and Bindings
