Severe Limitations:
Limited Use:
VideoMGPU: , Cluster:
  1. Live Video
    1. Configuring Ancillary Data (Timecode, etc)
      1. Interpreting AFD Information
  2. Movie Clip
    1. Overview
    2. Configuration
      1. Buffers
      2. Interlacing
      3. Color Space
      4. Advanced
    3. Property Description
    4. Animation Control
    5. Image Sequences
    6. Synchronous Seeking in a Cluster
    7. ErrorCodes
  3. Movie Stream
    1. Supported Protocols
    2. Unsupported Protocols
  4. Movie Frame
    1. Image Sequences
    2. Configuration
    3. Smooth Loops
    4. Performance
  5. Limitations
Live Video
LTC_ LTC timecode RP 188 Deltacast, DVS, Black Magic
VIT1 VITC timecode field 1 RP 188 Deltacast, DVS, Black Magic
VIT2 VITC timecode field 2 RP 188 Deltacast, DVS, Black Magic
0000 0 undefined 1 undefined
0001 2 reserved 3 reserved
0101 10 reserved 11 Reserved
0110 12 reserved 13 Reserved
0111 14 reserved 15 Reserved
1100 24 reserved 25 reserved
Movie Clip
Overview
The Movie Clip node gives the Ventuz operator more control over initialization and playback of movie clips. It provides frame accurate playback for use in Ventuz Cluster setups and is able to play the most common video container formats like WMV, AVI, MOV and MKV. Moreover, it is capable of playing Quicktime movies in Ventuz. For all full list of supported video codecs, see Supported Video Formats. The video decoder in this node is based on the ​FFMPEG project and provides the best performance compared to pre-installed DirectShow and WMF decoders.
Configuration
Buffers
  • Normal buffering is sufficient for normal playback and point looping. The number of buffers used can be adjusted. More buffers means more memory usage but improved reliability, especially with poorly encoded streams. Using the Loop feature will double the amount of buffers needed.
  • Reverse Play will do additional buffering to allow backward playback with the Scrub property. The number of buffers and the amount of memory used will be tripled! Note: The reverse playback does not loop for technical reasons.
  • Buffer All will decode the entire clip into memory, allowing to seek immediately to any frame, at a high memory cost.
Interlacing
Color Space
With Color Space the automatically detected color space from the file can be overwritten. Ventuz converts from the read out color space to the Project Color Space. Standard setting is Auto to read out the metadata. With Unspecified Ventuz skips the conversion and uses the color values as they are. The other listed modes like BT.709 are presets for specific primaries, a transfer function and matrix, which also can be set independently.
Advanced
Disable Threading
  • Playing many clips: enable the flag
  • Playing one large clip and multiple small ones: it is the best to disable threading for the small ones and keep threading enabled for the large clip.
Enable Audio Compensation
Ignore Clip Duration
Audio Stream
Animation Control
Type Description
Play starts the movie playback at a given time that can be set by the keyframe value
Pause pauses the movie clip at the time set in the keyframe value
Stop stops the movie playback at the given time. It does not carry a time but looks to its right and left to seek to the needed frame. Sample 1 and Sample 2 at the bottom explain the behavior in detail.
Sample 2 behaves a little different, in this case the movie starts playing, but when it hits the Stop keyframe it will seek to the position of the Pause keyframe to it's right. It would show the same behavior at the Stop keyframe if the right one would be a Play instead of a Pause.
Sample 1
Sample 2
Image Sequences
ErrorCodes
Ok Everything is fine
NoVideo No video stream found
Movie Stream
Supported Protocols
Movie Frame
Image Sequences
  • all images have the same size, file and pixel format
  • all files are in the same folder
  • the folder must reside in the project folder (auto-import of an image sequence to the Project currently does not work)
  • all files must have the same file extension for known image formats (e.g. png, jpg, tif)
  • filenames must be indexed starting from zero or one
  • the index portion must have a constant number of digits (e.g. 0000 to 2421)
  • the indexed number must be continuous (without breaks) (e.g. 00 to 59 = 60 files)
  • filenames must be equal (except the index portion)
Configuration
  • Normal buffering is sufficient for normal playback and four point looping. The number of buffers used can be adjusted. More buffers means more memory usage but improved reliability, especially with badly encoded streams. Using the Loop feature will double the amount of buffers needed.
Smooth Loops
Performance
  • Configure reverse play.
  • Enable lots of buffers, at least 30. Backward play will be slower than forwarding. If you use more buffers, the difference will shrink.
  • The number of buffers must be larger than the size of a GOP (group of picture).
  • The more buffers you configure, the longer it will take for the movie to resync should it run out of the buffered range.
  • uncompressed video
  • Quicktime Animation or other simple RLE codecs
  • I-Frame (keyframe/Intraframe) only clips
  • short-GOP (2-3 frames) clips
  • Configure normal play if you don't intend to play reverse. Configure few buffers. Both will speed up the seeking.
Limitations
  • Texture node
  • ​FFMPEG
