Rectangle Geometries
All here listed Rectangle types, except the Gradient Rectangle, will provide their geometry for the Geometry Renderer. The differences for each Rectangle type can be found in the following sections.
Rectangle
Normalization
Rounded Rectangle
Texturing
  • Flat: Zero to one flat mapping over the whole area of the rectangle.
  • Wrap: The texture coordinates flow around the border. This is great to add a spot light effect and have it animate around an object.
  • Stretch2x2: Imagine the texture to be split into 4 quadrants. Each quadrant is used for the respective corner and the pixel exactly on the border are stretched to fill the straights between the corners.
  • Stretch4x4: Similar to Stretch2x2 but assumes the texture is split into 16 quadrants. The corners are used to texture the corner areas of the Rounded Rectangle and the 2 quadrants between any two corners are used to texture the straight between the same corners on the Rounded Rectangle.
Gradient Rectangle
  • Nodes and Bindings
