Composition Projector
Composition Projector Projects a Compostion Layer orthogonal onto one or multiple Screens in a Previs Scene.
The Composition Projector creates an orthogonal projection of a Composition Layer. A Canvas can be bound to the Output of this virtual projector a Screen.
The mapping of this projection is calculated using Ventuz world transformation values of both the projector and the Screens to which the Composition Projector is mapped.
Different View Options are available for this Node. The options are similar to the properties that control Cameras inside of Ventuz:
View
Setting Description
Tracking Allows for connecting this Previs Projector to an external tracking data
CompositionBinds a Composition to this Projector. In 'real world' terms, it is setting the source or input of the projector
ResolutionWidth/HeightChanges the output resolution of the Projection if
OverrideResolutionEnables the resolution Width and Height changes set in the above options
IsMovingIs used to continually recalculate the internal render target in the event the Projector is 'physically moving' inside of the previs scene. If the Screen is static, only this flag needs to be set. If both the Screens and the Projector are moving, both must be set
  • Render Setup
