![]() | Mover | This is a multi-purpose node for generating values within a specific range. |
![]() | Alternator | This node alternates values by true or false. The duration of each state can be specified. |
Function defines the mathematical function used by the Mover to calculate the values in one period. The duration of a single period is defined by the Duration property. The Sine and Cosine functions result in smooth ease-in and ease-out animations. The Linear function produces constant animations, whereas the Alternator mode switches between Min and Max values. The Random function produces random values within the specified range - one new value in each period. Infinite will run indefinitely from 0 on in a linear manner. Each period the result will increase by the given range.
Enabling Swing will produce a continuous and smooth curve. With the functions Alternate, Random and Infinite the Swing property has no effect.
Immediately upon completion of one period, the OnRepeat event is fired and a new period begins. If the mode Random is selected the randomness can be controlled by the Seed property. If Seed is set to 0 the random value sequence will be always a different one. If Seed is not 0 the random sequence will always be the same for all Movers with the same Duration, Min and Max values. This e.g. makes it possible to get same random sequences across multiple machines in a Ventuz Cluster.
The AutoResetMode property is useful in OneShot mode to create an (inverse) sawtooth function:
Use the Presets Sawtooth OneShot and Sawtooth Inverse OneShot to configure the Mover node accordingly. The use of the AutoResetMode is needed because the Mover node usually sets its output to the Min value when the scene is loaded. Additionally the Mover stays on the Max value after Nudge has been triggered in a non-swinging mode.
Only movers in Absolute mode are synchronous in a Ventuz Cluster.
The Infinite function will produce issues in regards to the Cluster Clock if it is used in Absolute mode. Because of the floating point number precision this will eventually lead to inaccurate results on systems that are running in long term.
