Ventuz 5 Quick Guide
Ventuz 5 Designer
Ventuz 5 Node Reference
  • Point Options
  • Render Options
  • FFT Audio Analysis
Ventuz 5 Director
  • PropertyGroups
Cylinder
Cylinder This node provides a cylinder (and tube) geometry.
Renders a cylinder with adjustable dimensions and, optionally, a hole if the Hole property is set to a non-zero value. By decreasing the Angle property, partial cylinders or pie wedges can be created.
  • Nodes and Bindings
