Ventuz 5 Quick Guide
Ventuz 5 Designer
Ventuz 5 Node Reference
  • Point Options
  • Render Options
  • FFT Audio Analysis
Ventuz 5 Director
  • PropertyGroups
Value Buffer
Value Buffer This node buffers values until they are needed for further processing.
Float, Int, Boolean, Byte, String, Matrix, URI and Object.
Whenever a value of an Output changes, the Changed event is fired. In a similar fashion, the Passed event is fired whenever the output changes, either because Pass was triggered or Bypass is active a value changed.
Type Default
Float 0
Int 0
Bool false
String null
Byte 0
Matrix Zero
Uri null
Object null
  • Ticker Node
