Ventuz 5 Quick Guide
Ventuz 5 Designer
Ventuz 5 Node Reference
  • Point Options
  • Render Options
  • FFT Audio Analysis
Ventuz 5 Director
  • PropertyGroups
Filter
Mirror FilterThis node can restrict which objects are rendered to a Mirror.
Clip Plane FilterThis node can restrict which objects are clipped by a Clip Plane
Cubemap Filter The Cubemap Filter can restrict which objects are rendered to a Cubemap.
Rank Filter The Rank Filter is used in Chroma Keying mode to render parts of the Hierarchy to the Background, Foreground or Garbage Matte.
Shadow Filter Filters Objects for the Shadow Map Rendering.
3D Layer Reference Filter Filters objects for each rendering of a 3D Layer issued by 3D Layer References.
Mirror Filter
Condition Description
Always Rendered and visible in the Mirror
BehindMirror Not rendered but visible in the Mirror
BeforeMirror Rendered but not visible in the Mirror
Clip Plane Filter
Cubemap Filter
Always Rendered and visible inside the reflection
InReflection Not rendered but visible inside the reflection
Outside Rendered but not visible inside the reflection
Rank Filter
Shadow Filter
  • Mirror Node
  • Clip Plane Node
  • Render Cubemap Node
  • Shadow from Lightsource
  • Shadow Options
