Ventuz 5 Quick Guide
Ventuz 5 Designer
Ventuz 5 Node Reference
  • Point Options
  • Render Options
  • FFT Audio Analysis
Ventuz 5 Director
  • PropertyGroups
String Splitter
The split is performed at every occurrence of the string specified in Custom. If Lines or Tabs are checked, additional splits will be performed at the end of each line or at each tab respectively.
  • String Operation Nodes
