Ventuz 5 Quick Guide
Ventuz 5 Designer
Ventuz 5 Node Reference
  • Point Options
  • Render Options
  • FFT Audio Analysis
Ventuz 5 Director
  • PropertyGroups
Hierarchy Editor Shortcuts
View
 drag Pan
 wheel Scroll vertically
CTRL  wheel Scroll horizontally
Selection
click  Node Select Node with children
CTRL click  Node Add Node without children
SHIFT click  Node Add Node with children to selection
CTRL + SHIFT click  Node Add Node without children to selection
UP selected Node Select upper sibling Node
DOWN selected Node Select lower sibling Node
LEFT selected Node Select parent Node
RIGHT selected Node Select first child Node
Editing
DELETE selected Nodes Delete/Unlink selection
click  Node Collapse/Expand children
CTRL + L selected Nodes Collapse/Expand children
CTRL + A selected Nodes Toggle Inactive state
CTRL + B selected Nodes Toggle Blocked state
CTRL + R selected Nodes Set Render Point
Naming
double  Node Edit name
F2 selected Node Edit name
Annotations
CTRL + E no selection Edit Container Annotation
Containers
click Navigate Next over Container Navigate into Container (down)
double  Container root Navigate one Container level up
click Navigate Back free area Navigate one Container level up
click  free area Select current Container
click  free area Show Container overview
CTRL + M selected Nodes Merge selection to new Container
CTRL + SHIFT + X selected Node Expose Icon to upper level
Drag&Drop
 drag selected Nodes Drag selection special
Drag&Drop Hierarchy Nodes from same or other Scene, Repositories or Toolbox
drop Drop-Target (arrow) Copy/Move
drop special Drop-Target (arrow) Special operation
SHIFT drop Drop-Target (arrow) Move
CTRL drop Drop-Target (arrow) Copy
CTRL + SHIFT drop Drop-Target (arrow) Link
CTRL + ALT drop Drop-Target (arrow) Reference Copy
All drop operations for Nodes allow to stamp Nodes to the drop target multiple times by clicking  while holding
hold  hover Node Select Node
  • Shortcuts: Content Editor
